Homebrew PCBs
Mimimum track spacing
2015-02-04 by lists
I am currently designing a 10-300V, 100mA bench PSU. The transformer is a
300-0-300 from an old valve power amplifier.
What is the minumum track spacing I can use for 300V AC and the resulting
420V DC?
Stuart Winsor
Tools With A Mission
sending tools across the world
http://www.twam.co.uk/
Re: [Homebrew_PCBs] Mimimum track spacing
2015-02-04 by Stefan Trethan
Depends on a number of factors such as expected pollution, humidity,
operating altitude, etc.
Something under 0.5mm will possibly result in immediate failure.
Something like 1mm would probably be my design minimum.
Obviously this is functional insulation only, in other words if this
insulation breaks down nothing bad must happen except a blown fuse.
For any kind of safety insulation you would need much more than that.
ST
On Wed, Feb 4, 2015 at 11:06 AM, lists
Stuartlists@... [Homebrew_PCBs]
> 420V DC?
> Stuart Winsor
> Posted by: lists <Stuartlists@...>
> http://groups.yahoo.com/group/Homebrew_PCBs
> Yahoo Groups Links
2015-02-04 by Randall Morgan
On Wed, Feb 4, 2015 at 4:26 AM, Stefan Trethan stefan_trethan@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
ST
> 420V DC?
> Stuart Winsor
> Yahoo Groups Links
If you ask me if it can be done. The answer is YES, it can always be done. The correct questions however are... What will it cost, and how long will it take?
2015-02-04 by lists
In article
<CAMmT-dZ57vncGCgRHDD29pyeAYmBVdzfeGtpKwEnCbW1147aqA@...>,
Thanks. I noted that the 2u2 450V* capacitors I bought had a 0.2" pin
spacing and I would have thought more than this would be required. I have
adopted a 0.2" minimum pitch for the tracks and the 0.1" dia pads for the
capacitor means a minimum of 0.1" or 2.5mm between them.
* Input capacitors are a pair of 100uF 250V in series with 330k voltage
equalising resistors.
Stuart Winsor
2015-02-04 by Jean-Paul Louis
> On Feb 4, 2015, at 8:57 AM, lists Stuartlists@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
> In article
> Stuart Winsor
