Homebrew PCBs
help with pcb
help with pcb
2015-04-06 by chris.yln@...
Hi I need to know how to flip a PCB layout so that it ok to use with press and peal method
to make the pcb. the layout is in Adobe Reader if I use it as is it will end up the wrong way round
thanks Chris
RE: [Homebrew_PCBs] help with pcb
2015-04-06 by K5ESS
There are many ways depending on what your PC operating system is and what
software you have.  Here's one way assuming you are using Windows.
Using the snapshot tool in Adobe reader take a snapshot of the layout.
Paste this snapshot into the Windows Paint accessory.  Under Image; Rotate;
select Flip Horizontally.  You may have to use the resize to adjust it to
the right size.
Mike N.
From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com]
Sent: Sunday, April 05, 2015 11:05 PM
Subject: [Homebrew_PCBs] help with pcb
and peal method
thanks Chris
Re: [Homebrew_PCBs] help with pcb
2015-04-07 by Ameer Khan
Dear friends,
While using Paint for processing the PCB layout, there is the
possibility of change to the size of the PCB lay out.
If you use " Irfan View" to process the PCB image we can take the print
in the correct required size. It has option for printing in the required
size.
73
VU3SQM
On 4/7/2015 3:00 AM, 'K5ESS' k5ess.nothdurft@... [Homebrew_PCBs]
> what software you have.  Here\u2019s one way assuming you are using Windows.
> layout.  Paste this snapshot into the Windows Paint accessory.  Under
> Image; Rotate; select Flip Horizontally.  You may have to use the
> resize to adjust it to the right size.
> Mike N.
> *From:*Homebrew_PCBs@yahoogroups.com
> *Sent:* Sunday, April 05, 2015 11:05 PM
> *To:* Homebrew_PCBs@yahoogroups.com
> *Subject:* [Homebrew_PCBs] help with pcb
> thanks Chris
