Homebrew PCBs
drill pcb
Re: [Homebrew_PCBs] drill pcb
2016-02-22 by DJ Delorie
"rfmicrowave1@... [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com>
writes:
> hello to the group I wanted to know what would be a low cost-effective
> solution to drill pcb ? I had found this on ebay
You can't beat free...  (assuming you have the dremel already)
http://www.delorie.com/pcb/dremel-stand/
2016-02-22 by casy_ch@tbwil.ch
Hello Roberto
For the price it is really a machine which should work for PCB drilling.
Should it have a bit of wobble, you can still change the chuck against a
good self tightening chuck closing down to almost zero. If I did not
already had a precision machine for drilling my pcb's, I would buy it
and replace the UK power plug - hihi. Thanks for the link.
I am sure that this drilling machine is far, far better than the Dremel
assembly of Mr. Delorie.
Rgds
Jean-Claude
Am 21.02.2016 um 10:09 schrieb rfmicrowave1@... [Homebrew_PCBs]:
> solution to drillpcb ? I had found this on ebay
> PCB Art Mini Bench Drill Press 6mm Chuck Fully Adjustable Speed 100080
> <http://www.ebay.it/itm/PCB-Art-Mini-Bench-Drill-Press-6mm-Chuck-Fully-Adjustable-Speed-100080-/271937853002?hash=item3f50c2564a:g:8NoAAOSwjVVVsK7e>
> image
> PCB Art Mini Bench Drill Press 6mm Chuck Fully Adjustabl...
> in | eBay
> View on www.ebay.it
> Preview by Yahoo
> Thank
> Roberto
Re: drill pcb
2016-02-22 by bobledoux@...
This drill is sold in the USA by Harbor Freight. I have one. I use it for drilling PCB's.
There is too much run out for carbide bits. It works well with steel bits. The chuck will hold .020 or 0.5mm drill bits or larger bits.
My speed control quit working. So I wired it as a switch. So mine operates as a single speed motor, but it has variable speed adjustment with the belt pulleys.
Re: drill pcb
2016-02-22 by craigl2@...
How much runout does it have? And, how much runout is too much.?
I ask this because while I was in the process of building a inverted drill (to drill PCBs from the bottom up) at one point I had a runout of at least .01 inches. This is probably much more than your average Dremel. Despite this I was able to drill holes down to .0225 (#74 drill) using carbide drills without breaking any bits. Admittedly I was using 45X magnification to align the board and was watching as the drill broke through, therefore I did not plunge the drills to half or more of their length.
I seriously doubt that the problem people are having with drill breakage using Dremels is due simply to runout. I also don't doubt that they are having better results with other tools such as Proxxon rotary tools.
The reason I mention this is that it would be difficult for the average person to improve the runout of tools such as the Dremel but if another cause for drill breakage was found perhaps that could be easily corrected.
Craig
Re: [Homebrew_PCBs] Re: drill pcb
2016-02-22 by <n0tt1@...>
The Harbor Freight models don't look the same as the one from GB.
Do you have a HF model number of the one you have?
Charlie
On 22 Feb 2016 06:25:46 -0800 "bobledoux@... [Homebrew_PCBs]"
<Homebrew_PCBs@yahoogroups.com> writes:
for drilling PCB's.
2016-02-22 by Harvey White
Some of this you can see. (for the too much)  My opinion is that if
you can see the drill wobble, (and especially if the very fine drill
wobbles more than its own diameter), that's too much.
Runout in such a design can come from at least four sources:  1) drill
being bent; 2) collet wobble; 3) bearing wobble; and 4) mount wobble.
I built one, too (and highly recommend the design if you can do it).
1) bent drills are unlikely in carbide
2) collets made from aluminum (dremel) are more likely to be deformed
and inaccurate, while hardened steel chucks or steel collets (example:
proxxon) are less likely to be deformed.  I also suspect that proxxon
engineers to a higher standard.
3) ditto on the bearings
4) I used a linear table, one dimension, and relatively thick aluminum
(at least 1/4 inch) for support.  I also used a linear stepper for the
drive, so it was not a factor (the table would have swamped any
variation).
Given that (and that the depth of penetration is settable), I've had
no problems with drill breaking.
Yep.  The mounts for the drills, if unsteady, and allowing sideways
movement while drilling, will also cause problems.
Ancient fix for car problems:  remove licence plates, replace
intervening material, replace licence plates.
I'd say that if the collets and chucks can't be improved, and
replacement of the tool is not desired, then I would concentrate on
the mount for wobble.
Harvey
>Craig
Re: drill pcb
The real problem run out caused for me was the drill wandering before biting in and therefore being "off target". This was still a problem although less when I temporarily used a high-end spindle with a run out of less than .0005".
The runout is still present with the six dollar hobby RC motor I'm currently using but I found a way around the problem. Simply drilling through a .007' thick piece of cardboard helps somewhat but the drill would still wander off sometimes as much as .005".
The solution I found was to use a guide bushing positioned about .01" from the PCB. This results in the hole being drilled to .001" accuracy or better.
I am using a 1/8 inch thick piece of flat stock steel as the drill table. This provides three benefits:
1. Magnets hold the table to the frame so it can be quickly and easily removed for more open access to change the drill bits.
2. Two 3/8" X 3/8" neodymium magnets placed on top of the PCB allow it to be slid around for positioning but hold it (hands free) in place firmly for drilling. These may be a little stronger than necessary.
3. I made small bushings with a short 3/16" piece of steel drilled through with the appropriate size drill. These were pressed into a 1/8" thick plastic disk and four 1/8" X 1/8" neodymium magnets were pressed through 1/8" holes every 90 degrees. When I change to a different drill size I slip the appropriate size bushing down over the drill, replace the tabletop and slowly raise the drill until the magnets attach the bushing disk in perfect alignment to the underside of the table. Because there is still some runout of the drill there is a small countersunk area in the bushing facing the drill to guide it into the hole.
Craig
Re: drill pcb
I stand corrected. I did not get my drill press from harbor Freight.
This is the model I have:
http://www.jetsinc.com/index.php?main_page=product_info&products_id=1644
I purchased it four years ago.
It has a three speed pulley system. On ebay they go for $65 to $120 US. I see it for $75 with free shipping.
http://www.ebay.com/itm/MINI-DRILL-PRESS-COMPACT-DRILL-PRESSES-BENCH-JEWELER-HOBBY-3-SPEEDS-MAX-8500-RPM-/190586354986?hash=item2c5fd4fd2a:g:OHkAAOSwmUdUVnf7
2016-02-22 by Michael Young
Aside from runout, feeds and speeds can be the culprit. FSWizard Pro gives the following for a 0.03" 2-flute, uncoated carbide drill in FR4.
RPM 20k
SFM 150 ft/min
Feed rate: 29 in/min
Torque and breaking torque are listed as equal.
In pure copper, RPM is 40k at roughly the same feed rate, for half the chip load. I don't have any thoughts on what this might mean for copper clad FR4.
Also check that the spindle mount is rigid and on axis with the feed. Strict perpendicularity to the work might not be so critically important, but can help reduce wander when starting the hole. A shorter bit is more gooderer, but they the bits seem to come in only one length.
I use a rotozip clamped to a linear guide. It develops 20k+ rpm and very seldom breaks bits. I attribute this mostly to the high RPM and the relatively rigid mount and guide. Any slop or flex in the mount is sure to cause problems. Hand held is definitely out of the question (I didn't read the entire thread, so maybe this isn't an issue).
Mike.
Craig
RE: [Homebrew_PCBs] drill pcb
2016-02-23 by keith printy
Only problem I see with this besides the shipping cost to the united states is ,it requires 220 volts
From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com]
Sent: Sunday, February 21, 2016 4:09 AM
Subject: [Homebrew_PCBs] drill pcb
hello to the group I wanted to know what would be a low cost-effective solution to drill pcb ? I had found this on ebay
PCB Art Mini Bench Drill Press 6mm Chuck Fully Adjustable Speed 100080 <http://www.ebay.it/itm/PCB-Art-Mini-Bench-Drill-Press-6mm-Chuck-Fully-Adjustable-Speed-100080-/271937853002?hash=item3f50c2564a:g:8NoAAOSwjVVVsK7e>
 <http://www.ebay.it/itm/PCB-Art-Mini-Bench-Drill-Press-6mm-Chuck-Fully-Adjustable-Speed-100080-/271937853002?hash=item3f50c2564a:g:8NoAAOSwjVVVsK7e> image
	 <http://www.ebay.it/itm/PCB-Art-Mini-Bench-Drill-Press-6mm-Chuck-Fully-Adjustable-Speed-100080-/271937853002?hash=item3f50c2564a:g:8NoAAOSwjVVVsK7e> PCB Art Mini Bench Drill Press 6mm Chuck Fully Adjustabl...
PCB Art Mini Bench Drill Press 6mm Chuck Fully Adjustable Speed 100080 in | eBay
 <http://www.ebay.it/itm/PCB-Art-Mini-Bench-Drill-Press-6mm-Chuck-Fully-Adjustable-Speed-100080-/271937853002?hash=item3f50c2564a:g:8NoAAOSwjVVVsK7e> View on www.ebay.it
Preview by Yahoo
Thank
Roberto
RE: [Homebrew_PCBs] Re: drill pcb
2016-02-23 by Jeff Heiss
This sounds interesting.  Are there any pictures avaible?
Sent: Monday, February 22, 2016 12:34 PM
Subject: [Homebrew_PCBs] Re: drill pcb
Craig
2016-02-23 by craigl2@...
I do not currently have any photographs. I may be able to take some within the next few days. Are there any aspects of the drill you are particularly interested in?
Craig
Re: drill pcb
A feed rate of 29 in./min. equates to drilling through a PCB in a little over 1/10 of a second. Are you really drilling through them this quickly?
Craig
RPM 20k
SFM 150 ft/min
Re: drill pcb
2016-02-23 by jim.strohm@...
International voltage converters are widely available in the states.
73
Jim N6OTQ
2016-02-23 by mikewhy
Me personally, the 1/2" per second or so leaves a large margin even with bits already starting to dull. Someone else with a slower spindle might find the margin not nearly as large as intuition might suggest. Breaking torque was the limit in the FSWizard figures I gave. For 5000 rpm, a seemingly safe and slow feed of 1/8" per second exceeds the recommended feed rate of 7.05 in/min.
Mike.
-------- Original message --------
From: "craigl2@earthlink.net [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com>
Date: 2/23/2016 11:16 AM (GMT-06:00)
Craig
RPM 20k
SFM 150 ft/min
2016-02-23 by Roger Blair
FYI... 110V, USA.
http://www.ebay.com/itm/MINI-DRILL-PRESS-COMPACT-DRILL-PRESSES-BENCH-JEWELER-HOBBY-3-SPEEDS-MAX-8500-RPM/190586354986?_trksid=p4069.c100039.m2059&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20140107094819%26meid%3D8798deee68494a4f924698bb53d5a287%26pid%3D100039%26rk%3D3%26rkt%3D4%26mehot%3Dag%26sd%3D272029555215
Roger
On 2/22/2016 4:25 PM, 'keith printy' keethpr@...
> *From:*Homebrew_PCBs@yahoogroups.com
> *Sent:* Sunday, February 21, 2016 4:09 AM
> *To:* Homebrew_PCBs@yahoogroups.com
> *Subject:* [Homebrew_PCBs] drill pcb
> helloto the group I wanted to know what would be a low cost-effective
> image
> Adjustabl...<http://www.ebay.it/itm/PCB-Art-Mini-Bench-Drill-Press-6mm-Chuck-Fully-Adjustable-Speed-100080-/271937853002?hash=item3f50c2564a:g:8NoAAOSwjVVVsK7e>
> in | eBay
> View on *www.ebay.it*
> Preview by Yahoo
> Thank
> Roberto
2016-02-23 by Dennis Shelgren
Yea, just using the feeds and speeds calculator, I typically go as fast (rpms) as I can manage. Of course I have an air drill for pcbs. 56k rpms max.
On Feb 23, 2016 1:26 PM, "Roger Blair Roger.Blair@... [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com> wrote:
FYI... 110V, USA.
Roger
Preview by Yahoo
Thank
Roberto
What kind of air drill?  Those are some impressive RPMs.
Sent: Tuesday, February 23, 2016 4:30 PM
Subject: Re: [Homebrew_PCBs] drill pcb
FYI... 110V, USA.
http://www.ebay.com/itm/MINI-DRILL-PRESS-COMPACT-DRILL-PRESSES-BENCH-JEWELER-HOBBY-3-SPEEDS-MAX-8500-RPM/190586354986?_trksid=p4069.c100039.m2059 <http://www.ebay.com/itm/MINI-DRILL-PRESS-COMPACT-DRILL-PRESSES-BENCH-JEWELER-HOBBY-3-SPEEDS-MAX-8500-RPM/190586354986?_trksid=p4069.c100039.m2059&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20140107094819%26meid%3D8798deee68494a4f924698bb53d5a287%26pid%3D100039%26rk%3D3%26rkt%3D4%26mehot%3Dag%26sd%3D272029555215> &_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20140107094819%26meid%3D8798deee68494a4f924698bb53d5a287%26pid%3D100039%26rk%3D3%26rkt%3D4%26mehot%3Dag%26sd%3D272029555215
Roger
On 2/22/2016 4:25 PM, 'keith printy' keethpr@ameritech.net [Homebrew_PCBs] wrote:
Preview by Yahoo
Thank
Roberto
I’m intrigued by the interchangeable bushings.  Maybe one of the bushings, or motor, linear slide or overall unit?
Jeff
Sent: Tuesday, February 23, 2016 12:07 PM
Subject: RE: [Homebrew_PCBs] Re: drill pcb
Craig
2016-02-24 by keith printy
Aren’t most of these converters to convert 220 down to 120 ?
Sent: Tuesday, February 23, 2016 12:35 PM
73
Jim N6OTQ
2016-02-24 by Dennis Shelgren
Just a super cheap one from harbor freight. A much better option would be dental gear. Seriously, most dentists are also home machinists! You need at least 30k rpm for dental mills and old bits might be free! My dentist was super suprised I loved machining. We talked for an hour straight!
On Feb 23, 2016 1:40 PM, "'Jeff Heiss' jeff.heiss@comcast.net [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com> wrote:
FYI... 110V, USA.
Roger
Preview by Yahoo
Thank
Roberto
Re: drill pcb
2016-02-24 by craigl2@...
I will try to get some photographs within the next few days (it's in the workshop area I have on the other side of town).
In the meantime this is the motor I am using:
http://www.robotshop.com/en/rs-550-motor-19300rpm-12v-6249oz-in.html
It draws about 1.1 amps with no load and 1.9 amps when drilling with a #65 drill. Using a current clamp on my Fluke multimeter, set to capture the minimum and maximum values, the start up current draw is about 7.6 amps. A 12 volt 4 amp power supply bought from the above source only causes the motor to stutter, a 12 volt 15 amp power supply from the above source works but only if the switch is on the correct side of the power supply (I believe I had it on the output side). The problem with both of these supplies appear to be due to protection circuitry and the initial start up draw. Currently I am using 12 volt 3.5 amp power supply from a Nintendo Game Cube which works well however, I'm a little concerned it may eventually fail due to the large initial power draw.
I think this is the same motor for a couple dollars cheaper:
http://www.goldmine-elec-products.com/prodinfo.asp?number=G21086
This is the chuck I am using:
http://www.amazon.com/Water-Brass-3-17mm-Motor-2-5mm-3-17mm/dp/B00NXSETD0/ref=sr_1_1?ie=UTF8&qid=1456280385&sr=8-1&keywords=Gold+Tone+Brass+3.17mm+1%2F8%22+Motor+Shaft
They are also available on eBay.
The motor shaft has about .00025" runout. There is about a .004" runout with the chuck as measured on the drill shaft. I am unclear why this is since it's a straight through .125" hole so there is no problem with concentricity as there would be trying to connect a motor with a different size shaft to a standard carbide PCB drill. My first attempt at making my own connector drilling and reaming a brass rod and using set screws was only slightly better with about .003" runout. In any case using the guide bushings makes this a nonissue.
I used a linear stage probably by Del-Tron but unmarked. Most of these are not meant to be used in a vertical position but so far it hasn't failed. If it does I will probably replace it with a small linear rail from eBay. Neither of these are cheap but you can find something suitable on eBay for 20-30 dollars, maybe less if you are not in a hurry. The cheaper linear rails likely have somewhat more friction but should still result in a very sensitive feel as long as they use ball bearings and not simple plastic slides. Although you may get by with 1/2" of travel 1" or so gives more leeway in construction. The finished drill press has a much more sensitive feel than my Cameron micro drill ( http://cameronmicrodrillpress.com/manual-micro-drill-presses/cameron-164-series/cameron-164/ ) or an Albrecht sensitive drill adapter used in a regular drill press.
Craig
Jeff
Craig
2016-02-24 by Jeff Heiss
Can standard 1/8” shank PCB drill bits fit in a dental drill?  Are there adapters to fit them if not?
From: Homebrew_PCBs@...m [mailto:Homebrew_PCBs@yahoogroups.com]
Sent: Tuesday, February 23, 2016 9:59 PM
Subject: RE: [Homebrew_PCBs] drill pcb
On Feb 23, 2016 1:40 PM, "'Jeff Heiss' jeff.heiss@... [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com> wrote:
On Feb 23, 2016 1:26 PM, "Roger Blair Roger.Blair@Comcast.net [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com> wrote:
FYI... 110V, USA.
Roger
Preview by Yahoo
Thank
Roberto
2016-02-24 by Tony Smith
They’re about $30 or so, I’ve got mine clamped to a mini-mill.  They work well.  For the price they work very well.
If you do decide to clamp it to something do it at the ends, not the middle.
Tony
Sent: Wednesday, 24 February 2016 1:59 PM
FYI... 110V, USA.
Roger
 <http://www.ebay.it/itm/PCB-Art-Mini-Bench-Drill-Press-6mm-Chuck-Fully-Adjustable-Speed-100080-/271937853002?hash=item3f50c2564a:g:8NoAAOSwjVVVsK7e> Image removed by sender. image
Preview by Yahoo
Thank
Roberto
2016-02-24 by jim.strohm@...
Depends. Most of them are autotransformers. In this case, the full winding is used for 220 and it's tapped halfway down for 110. I got my last two for free on CraigsList.
2016-02-24 by rolohar@...
Not an "autotransformer"
You probably want to stay away from an "autotransformer" in this situation because of line isolation factors.
A simple "step down" of "step up transformer would be a safer choice, where there is a primary and
a secondary winding configuration.
Do your homework before delving into this transformer application.
Roland F. Harriston, P.D.
From: "jim.strohm@... [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com>
To: "Homebrew PCBs" <Homebrew_PCBs@yahoogroups.com>
Sent: Wednesday, February 24, 2016 9:29:25 AM
Aren’t most of these converters to convert 220 down to 120 ? International voltage converters are widely available in the states.
Re: drill pcb
2016-02-25 by craigl2@...
Since you would normally be plugging the drill into a 220 wall outlet directly how is plugging it into an autotransformer any less safe?
Craig
2016-02-25 by rolohar@...
Perhaps I do not understand exactly how the autotransformer would be used with the tool you are
planning to use.
A "real" autotransformer has only one winding, therefore there is no isolation between the power source and the
tool you are using, so it is possible that the user could be exposed to the full power from the source.
Please explain how you plan to use the "autotransformer" in this application....which is (I believe) to
operate a 220 volt tool and a 120 volt power source.
Or, perhaps, the term "autotransformer" is not an accurate name of the device you want to use.
A step up or step down transformer would be cool.
Roland
From: "craigl2@... [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com>
Sent: Wednesday, February 24, 2016 6:45:40 PM
Craig
2016-02-25 by Stefan Trethan
The point he makes, correctly, is that the tool does not need isolation since it is designed to operate directly on 220V anyway.
Many of the 220->110 and 110->220 converters sold are autotransformers.
ST
On Thu, Feb 25, 2016 at 2:57 AM, rolohar@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
planning to use.
Roland
Craig
From: "jim.strohm@... [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com>;
2016-02-25 by keith printy
An autotransformer is similar to how a variac works. I have several of those here ,even some 220 volt ones you would need to make sure the switch is in the line that is 220 volts above the neutral
These can deliver up to 280 volts at full setting so one would need to be careful with not setting it too high
Sent: Wednesday, February 24, 2016 8:58 PM
To: Homebrew PCBs
Subject: Re: [Homebrew_PCBs] Re: drill pcb
planning to use.
Roland
  _____
From: "craigl2@... [Homebrew_PCBs] <mailto:craigl2@...%20[Homebrew_PCBs]> " <Homebrew_PCBs@yahoogroups.com>
Craig
  _____
From: "jim.strohm@... [Homebrew_PCBs] <mailto:jim.strohm@...%20[Homebrew_PCBs]> " <Homebrew_PCBs@yahoogroups.com>
Disadvantages of an Autotransformer
    * The main disadvantage of an autotransformer is that it does not have the primary to secondary winding isolation of a conventional double wound transformer. Then autotransformer’s can not safely be used for stepping down higher voltages to much lower voltages suitable for smaller loads.
    * If the secondary side winding becomes open-circuited, current stops flowing through the primary winding stopping the transformer action resulting in the full primary voltage being applied to the secondary terminals.
    * If the secondary circuit suffers a short-circuit condition, the resulting primary current would be much larger than an equivalent double wound transformer due to the increased flux linkage damaging the autotransformer.
    * Since the neutral connection is common to both the primary and secondary windings, earthing of the secondary winding automatically Earth’s the primary as there is no isolation between the two windings. Double wound transformers are sometimes used to isolate equipment from earth.
From: "Stefan Trethan stefan_trethan@... [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com>
Sent: Wednesday, February 24, 2016 7:20:50 PM
ST
On Thu, Feb 25, 2016 at 2:57 AM, rolohar@... [Homebrew_PCBs] < Homebrew_PCBs@yahoogroups.com > wrote:
planning to use.
Roland
From: " craigl2@... [Homebrew_PCBs]" < Homebrew_PCBs@yahoogroups.com >
To: "Homebrew PCBs" < Homebrew_PCBs@yahoogroups.com >
Craig
From: "jim.strohm@... [Homebrew_PCBs]" < Homebrew_PCBs@yahoogroups.com >
2016-02-25 by K5ESS
Autotransformer Rebuttal
“The main disadvantage of an autotransformer is that it does not have the primary to secondary winding isolation of a conventional double wound transformer.”  Well it’s a disadvantage only if you need isolation.  Where is the need for isolation to operate a 220v drill press via a step-up autotransformer from 110v?
“Then autotransformer’s can not safely be used for stepping down higher voltages to much lower voltages suitable for smaller loads.”  Patently false.  Variable autotransformers have been safely used for years to step down voltages.  Any electrical device used incorrectly can be a safety hazard.  When used properly an autotransformer is completely safe.  One primary use for autotransformers is as a variable AC voltage source.  Here are examples of commercial autotransformers versions of which have been used for years.
http://www.variac.com/staco_Variable_Transformer_Map.htm?gclid=CPKuw8b7kcsCFQctaQodlooPpQ
http://www.danaherspecialtyproducts.com/uploadedFiles/Siteroot/Superior_Electric/Products_and_Solutions/POWERSTAT%C2%AE_Variable_Transformers/powerstat%20cat.pdf
One use for small autotransformers “sometimes called Variacs (a tradename)  is in the restoration of old radios.  It is recommended that you connect the radio to a “Variac” and slowly bring up the applied voltage so as to not overstress the old components.  The problem here is that some of these old radios have the chassis connected to one side of the AC line (mains to some non-US folks).  This can result in a hazard if the power plug is inserted incorrectly leaving the radio chassis at line potential and a shocking hazard should you touch the chassis and a ground.   This is an instance where an autotransformer doesn’t provide protective isolation if the radio is connected improperly.
“If the secondary side winding becomes open-circuited, current stops flowing through the primary winding stopping the transformer action resulting in the full primary voltage being applied to the secondary terminals.”  Well in the case we’re talking about (an autotransformer that steps up the 110v line to 220v for the drill press) that would not result in any overvoltage damage since the “full primary voltage” of 110v would be applied to the 220v drill press.  In addition, the remaining autotransformer winding would present a series inductance that would reduce the applied voltage by an amount determined by the load.
“If the secondary circuit suffers a short-circuit condition, the resulting primary current would be much larger than an equivalent double wound transformer due to the increased flux linkage damaging the autotransformer.”  That’s why we use fuses.  Transformers are generally very tolerant to overload so a short period of overload (before the fuse blows) is unlikely to damage it. Wellllll that assumes the autotransformer is fused which it should be.
Since the neutral connection is common to both the primary and secondary windings, earthing of the secondary winding automatically Earth’s the primary as there is no isolation between the two windings. Double wound transformers are sometimes used to isolate equipment from earth  In the US power wiring has three connections, LINE, NEUTRAL, GROUND.  I think most countries follow this standard now.  It appears that the drill press in question has a three prong plug so that it adheres this standard.  Any autotransformer used to power this drill press from US standard power should carry through all three connections, LINE, NEUTRAL, GROUND.
mnothdurft
Sent: Wednesday, February 24, 2016 8:41 PM
To: Homebrew PCBs
  _____
ST
planning to use.
Roland
  _____
Craig
  _____
YOU ALWAYS NEED "SAFETY" WHEN WORKING WITH POWER LINE ELECTRICITY!
TV "cheater cords" once used in repairing TV sets were known as "Suicide Cords" because the defeated the
isolation between the TV set and the power outlet.
Autotransformers and Variacs are often referred to as "Widow Makers" because they also do not isolate the
user from being exposed to the full potential of the voltage source.......be it 120 or 220 or whatever.
Mark My Words!
Get a step-up or step-down transformer that has the primary winding completely isolated from the
secondary winding and works on the concept of INDUCTION rather that direct hard wired connection
to whatever power source you are using.
RFH
From: "'K5ESS' k5ess.nothdurft@... [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com>
Sent: Wednesday, February 24, 2016 9:41:55 PM
“ The main disadvantage of an autotransformer is that it does not have the primary to secondary winding isolation of a conventional double wound transformer.” Well it’s a disadvantage only if you need isolation. Where is the need for isolation to operate a 220v drill press via a step-up autotransformer from 110v?
mnothdurft
To: Homebrew PCBs
From: "Stefan Trethan stefan_trethan@... [Homebrew_PCBs]" < Homebrew_PCBs@yahoogroups.com >
ST
On Thu, Feb 25, 2016 at 2:57 AM, rolohar@comcast.net [Homebrew_PCBs] < Homebrew_PCBs@yahoogroups.com > wrote:
planning to use.
Roland
To: "Homebrew PCBs" < Homebrew_PCBs@...m >
Craig
From: " jim.strohm@... [Homebrew_PCBs] " < Homebrew_PCBs@yahoogroups.com >
Re: drill pcb
They also make 110 V to 110 V isolation transformers. You could buy a bunch and plug them into all the outlets in your house instead of plugging anything directly into the outlet. Just for "safety"…
Craig
Mark My Words!
RFH
2016-02-25 by Andrew Volk
I wonder if your added runout is due to the hole being not EXACTLY 0.125”, or one or both of the shafts being a smidge small.   Also, if you use set screws only on one side, you may distort the coupler enough for 0.004” runout.  Collets, after all, go to a lot of trouble to grip the drill shaft on all sides equally.
Andy
Sent: Tuesday, February 23, 2016 8:03 PM
http://www.amazon.com/Water-Brass-3-17mm-Motor-2-5mm-3-17mm/dp/B00NXSETD0/ref=sr_1_1?ie=UTF8 <http://www.amazon.com/Water-Brass-3-17mm-Motor-2-5mm-3-17mm/dp/B00NXSETD0/ref=sr_1_1?ie=UTF8&qid=1456280385&sr=8-1&keywords=Gold+Tone+Brass+3.17mm+1%2F8%22+Motor+Shaft> &qid=1456280385&sr=8-1&keywords=Gold+Tone+Brass+3.17mm+1%2F8%22+Motor+Shaft
Craig
Jeff
Craig
You know just enough to be dangerous.
None of your statements are correct.
Cheater cords are not dangerous because they defeat the isolation between the TV and power outlet - there is no isolation between the TV and power outlet. They are dangerous for other reasons (chiefly miswiring).
Autotransformers and variacs are not generally referred to as widowmakers any more than all tree limbs are referred to as widowmakers. The proposed use here is safe and in compliance with the relevant standards.
You are dealing with lethal voltages at the output, no matter if it is ground referenced or not.
ST
On Thu, Feb 25, 2016 at 6:30 AM, rolohar@...t [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
Mark My Words!
RFH
2016-02-25 by K5ESS
Another Rebuttal
OK!!!!!
isolation between the TV set and the power outlet.  How did they defeat the isolation between the TV set and the power outlet?  Old TVs had their power cords physically attached to the rear cover, preventing a means to service the set without another means to power the set.  Cheater cords provided a way to power the TVs with the rear cover removed and had nothing to do with isolation between the TV and the power outlet.
user from being exposed to the full potential of the voltage source.......be it 120 or 220 or whatever.  So what “protects” the user from being exposed to the full potential of the voltage source in the absence of an autotransformer?  As I stated “Any electrical device used incorrectly can be a safety hazard. When used properly an autotransformer is completely safe.”
mnothdurft
Sent: Wednesday, February 24, 2016 11:30 PM
To: Homebrew PCBs
Mark My Words!
RFH
  _____
From: "'K5ESS' k5ess.nothdurft@... [Homebrew_PCBs]" <Homebrew_PCBs@...m>
mnothdurft
To: Homebrew PCBs
  _____
ST
planning to use.
Roland
  _____
Craig
  _____
2016-02-25 by Cecil Bayona
Don't ever get in a car, about 50,000 people a year die in automobiles, let's all be safe, we need the government to protect us from life..
Craig
Mark My Words!
RFH
Cecil - k5nwa
http://thepartsplace.k5nwa.com/
Re: drill pcb
All good points.
I have a Mitutoyo digital micrometer which measures to .00005" but, I have difficulty in getting repeatable measurements to less than .0002–3" accuracy. The motor shaft seems to measure .1248" sometimes and .1250" at other times. It is only about .33" long but as near as I can tell there is no taper or out of roundness. I did not think to measure the drill shanks as they are standard 1/8" carbide PCB drills.
Although I used a .124" reamer followed by a .125" reamer the hole is somewhat larger than .125" , a .1250" gage pin fits in, a .1255" pin does not (both are + or "go" types). The coupling was made of brass, I am thinking of trying to make another out of steel and lapping it to size.
Set screws can be used to hold something in very a precise position as evidenced by end mill holders, but possibly not with a coupling of this diameter / wall thickness.
Craig
Andy
2016-02-25 by symons391@...
I hope this helps for those not familiar with transformer terminology.
The most common type of transformer has a winding for the mains & the output voltages are separate windings or separate windings with various taps on those windings.
That gives isolation between the mains & the output voltages.
An Autotransformer has a single winding.
One end of the winding is a common for the mains & the output for the neutral or cold connection.
For it to be a step up transformer then the other mains connection (active or hot) is a tap part way up the winding & the output voltage is at the far end.
For a step down transformer, one end of the winding is still a common for the mains but the the output is the tap part way along while the other mains connection (active or hot) is at the far end of the winding.
Autotransformers are cheaper to produce because they use less winding ie copper & possibly less iron as well.
Autotransformers have two disadvantages.
1. There is no isolation between the mains input & the output because they share the winding.
2. If there is winding fault then the output can be directly connected to the mains input & receive the mains voltage.
If the autotransformer is stepping the voltage up then the output device will be running on a lower voltage but if the autotransformer is stepping the voltage down then the output will get over voltage. The fault may be a winding failure but even just a bad screw connection or a broken wire. An example of the major problems this can cause is if a non-USA person is using an autotransformer stepping down 220V or 240V to 110V for a USA appliance then the failure will cause the 110V appliance to cop the full 220V or 240V & this may even spectacularly destroy it.
2016-02-25 by Harvey White
It used to be that to get power to a radio (the all American 5) one
side of the AC line was connected directly to the chassis, and the
other side was rectified to produce power.  The plastic knobs and case
were used to protect the user from the AC line.  The particular
difficulty with this design is that the original cable could be
plugged in backwards.  The radio would work, but the chassis was now
sitting at full line potential.
Any television so wired (and there were some) would suffer from the
same difficulty.  I once modified a small color TV to be a monitor.
Unfortunately, it had the same kind of power supply and required an
isolation transformer to be used safely because the chassis was now
directly exposed.
In measuring equipment, typically oscilloscopes, the chassis is
connected to the AC ground pin.  Thus the probe ground is equivalent
to the safety ground at the wall.  This prohibits using the scope in a
"floating" mode where the ground/chassis would be at an elevated
potential.
Some people simply cut the ground pin on the scope power cord in an
effort to permit this kind of measurement.  That results in the
metallic chassis of the scope being at elevated potentials.  There's
also the problem when the device being measured has a fault that can
elevate its chassis above ground.  There are some scopes where the
chassis is isolated and the scope is battery powered.  These are
specifically made for such kinds of measurements (Tektronix 200
series).
The isolation transformer would help run the device in this situation
and prevent possible difficulties.  In fact, there is a piece of test
equipment that combines an isolation transformer with a variac, and
has metering to detect leakage to ground in the device plugged in.
This is not a common piece of equipment, though.
As a note, the back of the TV set used to have the power cable
attached directly.  Remove the back of the TV and the power cable was
disconnected.  A cheater cord was this power cable that did not have a
back attached.
Harvey
>ST
>On Thu, Feb 25, 2016 at 6:30 AM, rolohar@... [Homebrew_PCBs] <
>> Mark My Words!
>> Regards,
>> RFH
Re: drill pcb
2016-02-25 by jim.strohm@...
Roland, let's say (for instance) that you had a 220V device that you plugged directly into a Euro 220V outlet.
Then let's say you had a comparable 110V device that you plugged into a 110V American outlet.
What would be the difference in isolation between the two? Now let's say you were to use an autotransformer to use the 110V device on the 220V outlet, and (after disconnecting, of course) used the autotransformer to use the 220V device on the 110V outlet?
Assuming no exposed mains wiring, what would be the isolation differences between those four cases?
73
Jim N6OTQ
A "cheater cord" was (is) dangerous because it allowed a person access to the TV chassis when the back of the
TV set was removed. The original power cord on the TV set was configured so that if the back of the TV was
removed, the power cord came off with the back of the TV set. The "back" of TV sets in those days was
usually made of some non-conductive material like fiberboard or other paper-based material, to
ISOLATE the user from the voltage potential of the chassis.
The power cord was permanantly anchored to this back, so that it was not possible (normally) to remove the back
without disconnecting the power cord.
TV repair men made "cheater" cords that would allow them to power up the TV set with the back removed.
They lovingly named these cheater cords "suicide cords" because they allowed the repairman to be
exposed to the live, powered-on TV chassis, and if he was not careful, he could do damage to himself.
Variacs and autotransformers only have one winding. There is no primary/secondary winding
configuration. There is no iron core to facilitate induction between the primary and the secondary
windings. Autotransformers and Variacs and Rheostats were lovingly referred to as "Widow Makers"
for the same reason..............the user is not isolated from the power source as in a "regular"
transformer. An Isolation transformer generally performs NO step up or step down function.
It merely ISOLATES the user and the circuitry from the power line.
Four or five minutes spent reading any of the literature on Variacs (a trade name, actually) and
auto transformers (which really are not "transformers" in the true technical sense) will reveal the
precautions that must be observed when employing these devices.
There are many, many appliances made that will allow one to use 220 volt equipment on 110 volt
sources, and vice-versa. These devices are constructed in such a way as to isolate the user
(and whatever is plugged into them) with complete isolation from the power source. The are
often simply called "Converters". There are probably many circuit configurations that are used
in these devices.
There are also very elaborate "converter boxes" that are used in more sophisticated applications.
Some have metering and monitoring features, and be the type of device that would be applicable
to machine tools, etc.
Please review the definitions of:
Variac
Autotransformer
Rheostat
Step-Up and Step-Down TRANSFORMERS!
Isolation TRANSFORMER
Inductance
Be Careful,
From: "Harvey White madyn@... [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com>
Sent: Thursday, February 25, 2016 6:24:49 AM
directly exposed.
potential.
series).
back attached.
Harvey
>ST
>> Mark My Words!
>> Regards,
>> RFH
Re: drill pcb
2016-02-25 by duwaynes@...
While I was in the military, I had several assignments to countries that used 220 volts.
First thing after getting there was to purchase several 220-110 volt converters for my 110 volt devices.
These were always simple auto-transformers. They were either a metal or plastic box ( depending on power rating) with a grounded Euro 220 v plug on a cord. On the box was a polarized grounded 3 prong 110 volt socket. If everything is plugged in the way it should be there are no problems with auto transformers.
DuWayne
KV4QB
Symons:
Thanks for the dissertation.
It is obvious that you have done your homework.
2016-02-25 by Brad Thompson
On 2/25/2016 10:39 AM, rolohar@... [Homebrew_PCBs] wrote:
<snip>
windings.
<snip>
Hello--
There's most definitely an iron core in an AC-line autotransformer!
There has to be because otherwise there would be
no transformer action to step up or step down the incoming line voltage.
As for troubleshooting older "hot chassis" equipment, for safety's sake
always power the equipment with an AC-line
isolation transformer. If you need to power a 120VAC item from a 240 VAC
line (or vice versa), you can use
a transformer **with isolated windings** designed exactly for this
purpose. These are sometimes referred to as
"industrial control transformers".
73--
Brad  AA1IP
2016-02-25 by Boman33
I have been ignoring the back and forth arguing but here is an undiscussed warning:
That a VARIABLE auto-transformer (Variac) works stepping down 220V to 110V does not mean that it can be wired backwards and step up 110V to 220V.
If it is turned down, the output voltage will get higher and higher and it will eventually short the 110V input line.  Lots of fireworks and destroyed equipment.
This does not apply to fixed ratio auto-transformers.
Bertho
I remember the all American 5. My grandmother had one in a metal case. The plug was not polarized and if you plugged it in the wrong way and touched the radio you got “bit”
Sent: Thursday, February 25, 2016 10:39 AM
To: Homebrew PCBs
transformer. An Isolation transformer generally perfor! ms NO step up or step down function.
in these devices.
        Variac
        Autotransformer
        Rheostat
                                             &n! bsp;                    Inductance
Be Careful,
  _____
Any television so wired (and there were some)! would suffer from the
directly exposed.
potential.
series).
back attached.
Harvey
>ground referenced or not.!
>ST
>> Mark My Words!
>> Regards,
>> RFH
I remember the scope being grounded.if I was taking measurements on hot
chassis equipment I did not use the scope ground connection to that
equipment without using some type of isolation transformer. You can buy
isolation transformers that can be wired for either voltage so you would
wire one side for 120 the other for 220  I built an isolation box when I
worked at a previous employer so they could test carrier current equipment
and block the rf from going out on the power lines . it used this type
transformer and I had to make sure I wired for the correct voltage.
Sent: Thursday, February 25, 2016 8:25 AM
directly exposed.
potential.
series).
back attached.
Harvey
>ST
>> Mark My Words!
direct
>> Regards,
>> RFH
Cheater cords to not defeat the isolation between the set and power. They were used for making repairs by techs that usually knew what they were doing. In reality all it is defeting is the interlock that removes the power from the set when a user takes the back off
Sent: Thursday, February 25, 2016 1:08 AM
ST
On Thu, Feb 25, 2016 at 6:30 AM, rolohar@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
Mark My Words!
RFH
Bringing up an old radio slowly will only work if it has solid state rectifiers . with a tube rectifier by the time you get its cathode hot enough to work you will be too close to full power to safely not stress the capacitors that need time to form up
Sent: Wednesday, February 24, 2016 11:42 PM
mnothdurft
To: Homebrew PCBs
  _____
ST
planning to use.
Roland
  _____
From: "craigl2@...t [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com>
Craig
  _____
Re: [Homebrew_PCBs] Re: drill pcb (autotransformer notes)
2016-02-25 by Charles R. Patton
Not correct.  An autotransformer absolutely does have a core.  The
advantage of an autotransformer is in the size of the windings and core
for a given power level. For example:
1) Assume a standard 110V to 110V  isolation transformer with a 1 amp
rating.   So 110V/1A  to 110V/1A rating.
2) A simple wiring connection of the two windings in series gives a
220V  ability.  At the junction of the windings is a 110V 2A connection!
3) To achieve this with a 220V/110V isolation transformer the windings
would be a 220V/1A winding plus a 110V/2A winding, requiring about twice
as much copper and a larger core to allow the larger size of the
windings.  This is the economic reason for the auto-transformer
construction .
Charles R. Patton
> windings.
2016-02-25 by pierreraymondrondelle
Keep in bed, both hands flat on the mattress. Should you need light, use a candle, of course matches aren't for you, ask a nurse !
Wall switches, sockets and usual devices powered by the mains are far too dangerous for you !
Please, don't take this as a criticism but as a recommendation instead.
Good luck
Mark My Words!
RFH
2016-02-25 by Jean-Paul Louis
Additional warning for rolohar@...:
Do not use a candle, you could burn yourself to death. Instead wait for day light, it will be safer.
and as pierreraymondrondelle said
“Please, don't take this as a criticism but as a recommendation instead.
Good luck"
Jean-Paul
N1JPL
> On Feb 25, 2016, at 1:43 PM, pierreraymondrondelle pierreraymondrondelle@yahoo.fr [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
> Good luck
>> Mark My Words!
>> Regards,
>> RFH
2016-02-25 by casy_ch@tbwil.ch
Pierre Raymond
Good luck what for? He is using transformers with primary and secondary
completely isolated.
By the way it is the real way to transform the tension.
Jean-Claude, HB3YDH
Am 25.02.2016 um 19:43 schrieb pierreraymondrondelle
pierreraymondrondelle@... [Homebrew_PCBs]:
> Good luck
>> Mark My Words!
>> Regards,
>> RFH
Please remember that most domestic and industrial power outlets, etc., are designed to provide
ISOLATION between the user and the electrical power "within".
Ever hear of Underwriters Laboratory, and the many other private and government organizations
that devote a lot of time and money to assure that the ISOLATION is adequate for all of us,
and who test, inspect, and approve such apparatus for ISOLATION safety.
There will be exceptions........ those moronics among us that stick knives and forks and paper clips into the
power outlets.
Yes Virginia...........ISOLATION is real.
From: "Jean-Paul Louis louijp@... [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com>
Sent: Thursday, February 25, 2016 2:56:31 PM
Good luck"
Jean-Paul
N1JPL
> On Feb 25, 2016, at 1:43 PM, pierreraymondrondelle pierreraymondrondelle@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
> Good luck
>> Mark My Words!
>> Regards,
>> RFH
Roland,
I looked for you on LinkedIn and didn't find you.
Do you mind telling us what "P.D." stands for, and give us an idea of your experience and credentials?
Me, I am just a regular guy but you can look up my ham call on QRZ.com and then look up my name on LinkedIn. If it matters....
73
Jim N6OTQ
What is "LinkedIn" ?
From: "jim.strohm@gmail.com [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com>
Sent: Thursday, February 25, 2016 4:04:17 PM
Roland,
73
Jim N6OTQ
2016-02-26 by Will
It's for those folks who earn too much money for their brainpower.
Can we drop this saga please.
Will
2016-02-26 by rolohar@...
YES!
Let's drop it.
But...........................stay ISOLATED!
Electrically.......that is.
From: "Will zl1tao@... [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com>
Sent: Thursday, February 25, 2016 5:08:25 PM
Will
2016-02-26 by Jean-Paul Louis
Roland,
I fail to understand why you believe that an autotransformer is less isolated that the mains outlet.
An autotransformer properly built has a power cord to connect to the local mains, and an outlet for the other voltage.
What’s unsafe about that?
Please enlighten us, and also tell us what P.D. after your name mean. Is that an acronym for Pixie Dust?
If you had at least a minimum of engineering knowledge, you would know about LinkedIn which is the largest professional network on the western world Internet.
It you want to check my own credentials, you can look me up on the FCC database with my callsign (N1JPL)
and on linkedIn under my full name that you will find on the FCC database.
Jean-Paul
N1JPL
> On Feb 25, 2016, at 7:14 PM, rolohar@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
> YES!
> Let's drop it.
> Cheers,
> Will
I don't think you actually know what the term "isolation" means
in the context of this discussion.
A power cord plug does not imply isolation. It merely indicates that the device (whatever it is)
connects to a power source in a rather conventional manner.
Are you familiar with: Two-pronged electrical appliance plugs with no polarization?
Two-pronged plugs with polarized prongs?
Three pronged plugs?
Ground-Fault Interruption (GFI) outlets?
And why we have these configurations??
And...............
If "P.D." means "pixie dust" to you............I'm comfortable with that.
I thrive on flattery and unsolicited praise.
Suggestion: There a number of videos on YouTube about the subject.
Sit for a few minutes and view some of them.
Also, try to comprehend the significance of "ISOLATION" in the context of electrical power sources and
the application of electrical power to an electrical device.
And.....yes.
There will be questions on both the mid-term and the final exams on this subject.
All the best to you!
Sent: Thursday, February 25, 2016 7:30:18 PM
Roland,
Jean-Paul
N1JPL
> YES!
> Let's drop it.
> Cheers,
> Will
2016-02-26 by alienrelics@...
Yes, I think this has run its course. Please take this to Electronics_101 if you wish to continue.
Steve Greenfield AE7HD
Your friendly neighborhood moderator
> On Feb 25, 2016, at 10:59 PM, rolohar@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
That is exactly my point. There is no need for isolation when using autotransformer. Just a safe connecting device. Like a three prong cable to the mains (110V AC), and a three prong outlet for the 220V AC where the european device will be plugged in.
> And...............
The only meaning that was making sense to me, as written after a name was a sort of a title, but the only title that I could find was Pharm. D. for a doctorate in Pharmacy, which would not qualify for expertise in Isolation (except maybe in clean room isolation).
P.D. as Police department does not make sense in this context as well as most of the 218 acronyms using PD.
as listed in http://www.abbreviations.com/Pd
Youtube, as well as wikipedia are not reference sources. They can be right or wrong as they are very loosely controlled for that purpose.
Isolation as electrical power sources are concerned is not required by UL. Only medical devices in contact with a human body require isolation from mains,
I have been working for over thirty years in telecommunications equipment manufacturing, so isolation is something I had to deal with daily for a very long time.
> And.....yes.
Maybe P.D. stands for Pompous Demagogue that was not in the website listed above
All the best to you too,
Jean-Paul
N1JPL
> From: "Jean-Paul Louis louijp@yahoo.com [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com>
> Roland,
> Jean-Paul
> N1JPL
> > YES!
> > Let's drop it.
> > Cheers,
> > Will
2016-02-27 by Jean-Paul Louis
Thanks Steve.
73 de Jean-Paul
N1JPL
> On Feb 26, 2016, at 5:05 PM, alienrelics@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
Re: drill pcb
2016-02-28 by craigl2@...
I uploaded several photos of the drill press I built to a new album named Craig L's Photos. Some details, including the magnetically attached drill guide bushings, are in a previous message.
The frame is made of 8020 aluminum extrusions but could just as easily be made of MDF. The handle has a 3/4" by 2" rod on it held in place with a set screw to counterbalance the mechanism. In the photographs this weight is way down near where the rod attaches and could be much smaller (it was sized for a heavier spindle that I was using previously). The lifting mechanism consists of a disk pivoting on a bearing with another bearing riding on the top connected to the linear slide mechanism. The bearings are not absolutely necessary, previously it pivoted on a rod riding in a plastic block with a rod riding on the top. The bearings however further reduce the friction.
The scope is a small centering microscope I use on a small milling machine. A USB webcam work just as well however, I don't have a convenient computer in my work shop area.
Craig
2016-02-28 by Stefan Trethan
One of those cheap toy microscopes with the LCD screen instead of the eyepiece might work fine for this and not require a computer.
ST
On Sun, Feb 28, 2016 at 9:17 AM, craigl2@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
Craig
2016-02-28 by casy_ch@tbwil.ch
Hi Craig
Lovely drill press.
By the way where did you get the small centering microscope from.The
larger ones are very expensive. It would be nice to use on my cnc router
to set the X+Y-zero. Thank you.
Jean-Claude
Am 28.02.2016 um 09:17 schrieb craigl2@... [Homebrew_PCBs]:
> machine. A USB webcam work j ust as well however, I don't have a
> Craig
2016-02-28 by Harvey White
Second hand surveillance camera with a carefully selected lens.  You
want the ones with removable lenses, a telephoto lens, etc.  The one I
use is 24vac or 12vdc (I picked the 12vdc), and selected a lens that
gave me enough distance between the board and lens, and enough
magnification.
Look for them surplus, hamfest, or the like.
Harvey
>ST
>> Craig
Re: drill pcb
I got it off eBay used and it still wasn't cheap. You can find them new from Enco. The adjustment is a little sloppy. Although mine was used I saw a comment on the web by someone else who said there were problems with his when he got it new that he needed to fix.
If you search the web you can find plans on how to build one from an inexpensive binocular.
Craig
---In Homebrew_PCBs@yahoogroups.com, <casy_ch@...> wrote :
Hi Craig
Lovely drill press.
By the way where did you get the small centering microscope from.The larger ones are very expensive. It would be nice to use on my cnc router to set the X+Y-zero. Thank you.
Jean-Claude
2016-02-28 by Cristian
Enco's is interesting but Enco doesn't export, that means is hard for me to get it in Romania
Could you give me an link, please?
Cristian
A link, please.
Cristian
Hello Cristian
Have you tried through Ebay Germany or may be from Shenzen?
Jean-Claude
Am 28.02.2016 um 17:45 schrieb Cristian crissstian@... [Homebrew_PCBs]:
\ufffd
Cristian
Thank you for the reply.
I have one here but it is far too long to use it on my cnc router!
At the beginning I had quite a time to focus as the enlargement is quite
big. I had the idea to measure a 3M sponge with pad and it is exactly
the height very close to the focus, so I have no problem to focus
quickly and this without the danger of hurting the front lense.
Jean-Claude
Am 28.02.2016 um 16:16 schrieb craigl2@... [Homebrew_PCBs]:
> Craig
> Hi Craig
> Lovely drill press.
> Jean-Claude
2016-02-28 by crissstian
I curentul buy from eBay
No such Enco there.
Cristian
Trimis de pe dispozitivul meu Samsung
-------- Mesaj original --------
De la: "'casy_ch@tbwil.ch' casy_ch@tbwil.ch [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com>
Date: 28.02.2016 18:59 (GMT+02:00)
Către: Homebrew_PCBs@yahoogroups.com
Subiect: Re: [Homebrew_PCBs] Re: drill pcb
Hello Cristian
Jean-Claude
Am 28.02.2016 um 17:45 schrieb Cristian crissstian@rdslink.ro [Homebrew_PCBs]:
Cristian
Re: drill pcb
I believe the centering scope in question is made in Korea.
Craig
Hello Cristian
Jean-Claude
Re: drill pcb
This is the one I was referring to:
https://sites.google.com/site/pjoptical/home/centering-microscope
Also check out:
http://www.chaski.org/homemachinist/viewtopic.php?f=24&t=97737&sid=5b8aa66990aab263ec5027ae7d0f1378
(You may have to copy and paste the above link into your browser for some reason it doesn't work for me from yahoo groups)
Much of the same information is also here:
http://joyofprecision.tumblr.com/tagged/toolmaking
And, Google Books - Popular Science Jan 1949 pg. 226:
https://books.google.com/books?id=YyQDAAAAMBAJ&printsec=frontcover&dq=Popular+Science+Jan+1949&hl=en&sa=X&ved=0ahUKEwit-5nXh5vLAhVCbz4KHfM6C04Q6AEIHDAA#v=onepage&q=Popular%20Science%20Jan%201949&f=false
Hemingway Kits has a kit available:
http://www.hemingwaykits.com/acatalog/Centering_Microscope.html
I doubt this is very accurate but may be simple to make and fit some needs:
http://swarfrat.com/MillSpindleCenteringScope.htm
This is the sort of thing I think 3-D printer would come in handy for. That is, for fabricating some of the parts. But, not having experience with one I may be wrong. I would be interested in hearing other people's opinion on this since building a 3-D printer is one of the projects I have in mind.
Craig
Cristian
I recently bought a 3D printer kit and made some lens extensions for a microscope, it works well for small parts like that.
It needs some work still to make it print ABS, but the kit is fine for PLA.
Keep in mind that many items can be made faster and stronger with simple (hand) tools from raw stock, however the printer can make unusual parts which would be dificult to machine, and it can work unattended.
It requires a change of mindset from subtractive machining, which I still struggle with, but has other limitations instead (such as bridging and overhang angle).
Approach it as a hobby and do not expect it to pay off any time soon. My main motivation was actually wanting to learn 3D drawing.
(I hope nobody remembers my deprecatory remarks about 3D printing made many years ago on this very list. At the time the first repraps were just spitting out globs of molten hot-snot and I was basically saying "it will never fly". Turns out I was slightly wrong, like that IBM man...)
Actually it would be fairly easy to make a CNC that can 3D print and mill/drill PCBs...
ST
On Sun, Feb 28, 2016 at 8:06 PM, craigl2@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
Craig
2016-02-28 by Brad Thompson
On 2/28/2016 2:52 PM, Stefan Trethan stefan_trethan@...
> <snip>
> mill/drill PCBs...
Hello, Stefan--
Thank you for the pointer to the printer. If you have a few spare
minutes, would it be possible for
you to try printing PLA plastic as etchant resist on a piece of
copperclad board and then reporting the results?
Thanks, and 73--
Brad  AA1IP
I would be happy to do that for you, but I don't need to, because I
know already that it will not work. When the print is finished and the
bed cools down the PLA comes off, it only sticks while the bed is hot.
I print directly on aluminium, roughened up with scotch brite, like
you would prepare a toner transfer PCB.
Even the single layer trace that is printed at the start of a job
around the outside, to get things going, comes off way too easily to
survive any etching.
That is only the first problem. If you actually could get it to stick
there is also the problem that the first layer has a very poor
quality. It is not as dimensionally accurate as subsequent layers
because the bed/board is never perfectly level. Also I don't think the
line width is fine enough for PCBs, but that really depends on the
application.
Generally the bottom layer is not perfect, even with a good setup
there is a structure to it with tiny voids along the extruded beads.
This is an extremely bad example, but I have not seen a perfectly
smooth bottom surface:
<https://umgallery.ultimaker.com/uploads/gallery/album_1778/gallery_39565_1778_136353.jpg>
So even if you can find a material or surface preparation that sticks,
I don't think this will ever work well. You have a greater chance with
fitting a plotter pen, but I've been there, tried that with a plotter,
it sucks.
ST
On Sun, Feb 28, 2016 at 10:00 PM, Brad Thompson brad.thompson@...
> Thanks, and 73--
> Brad  AA1IP
On 2/28/2016 4:20 PM, Stefan Trethan stefan_trethan@...
> know already that it will not work. <snip>
> it sucks.
Hello, Stefan--
Thank you for your comments, which I very much appreciate.
Re: using a plotter-- IIRC, some years ago it was possible to buy a superior
acid-resistant plotter ink which disappeared from the market because one
ingredient was toxic or carcinogenic (I don't recall which, but it may have
been a red-colored ink).
Thanks again!
73--
Brad  AA1IP
2016-02-29 by rolohar@...
Brad Thompson:
My stupid error!
Of course, there is a "core" in an autotransformer or "Variac". Often, not exactly like the "E" and "I" core elements in a conventional transformer, but nevertheless........there is a core.
My comments regarding "isolation" are valid, and one must take caution when using an autotransformer.
As mentioned, there are several very good (very valid) videos on YouTube regarding the use, and mis-use
of variacs, autotransformers, etc.
They deal mostly with the anatomy of 3-Phase power distribution systems, which most of our domestic
power services are connect to, and how "Isolation" is an important factor to deal with, espcecially
when connecting certain pieces of test equpment and certain power tools.
"Isolation" vs "Insulation".
Regards.
From: "Brad Thompson brad.thompson@... [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com>
Sent: Thursday, February 25, 2016 9:15:15 AM
<snip>
windings.
<snip>
Hello--
73--
Brad AA1IP
2016-02-29 by Stefan Trethan
As far as I know Staedtler Lumocolor red is the best resist ink.
It is still available and I am not aware of any change in the formulation?
ST
On Sun, Feb 28, 2016 at 11:38 PM, Brad Thompson brad.thompson@...
> Thanks again!
> 73--
> Brad  AA1IP
Strictly speaking there are differences between an industrial control
transformer and an isolation transformer.
The isolation is often stronger with a dedicated isolation
transformer, sometimes the windings are even physically separated in
different chambers or on different shanks, instead of on top of each
other.
As a result coupling capacitance is lower with an isolation
transformer, but also magnetic coupling is worse.
So in some situations you may require an actual isolation transformer.
Many high quality control transformers fulfill the minimum
requirements for a safety isolation transformer, but always check the
datasheet.
ST
On Thu, Feb 25, 2016 at 5:15 PM, Brad Thompson
> 73--
> Brad  AA1IP
Stefan Trethan:
I don't know how often the members of this group will encounter the type of industrial transformers that
you describe. But I do know that isolation (not insulation) is a factor to be considered,,,,,,,,,often when
connecting your test equipment up to equipment that you might be troubleshooting, designing, etc.
Refer to the conventional three-phase configuration that most of us encounter.
From: "Stefan Trethan stefan_trethan@gmx.at [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com>
Sent: Sunday, February 28, 2016 10:14:10 PM
other.
datasheet.
ST
> 73--
> Brad AA1IP
2016-02-29 by Harvey White
On Mon, 29 Feb 2016 05:38:39 +0000 (UTC), you wrote:
>Stefan Trethan:
In the US, Line, neutral, line is not three phase, it's more two phase
since the two lines are 180 degrees out of phase with each other, thus
adding (120-0-120) give 240.
True three phase power is three lines, each 120 degrees apart.  You'll
find it in aircraft and industrial plants.  It can be wired with a
common (wye) or with an implied center (delta).  It does require
special transformers, and the voltages are not always what you expect.
You'll frequently find military surplus/aviation equipment with true 3
phase power, and it's annoying to convert *IF* it will even run on
60/50 Hz.  Some test equipment is rated to run from 50/60 to 400 Hz,
but that was generally an option.
BTW: the whine you might hear when boarding a commercial aircraft
frequently comes from the 400 Hz power, not the engines (although that
can be there, too).
Harvey
>Regards,
>----- Original Message -----
>other.
>datasheet.
>ST
>> 73--
>> Brad AA1IP
Re: drill pcb
2016-02-29 by wb8nbs@...
Great idea, drill from the bottom, sight from the top.
I'm having a bizarre idea this morning. There are lots of 1950s jig saws like http://www.vintagemachinery.org/photoindex/detail.aspx?id=10644 available for cheap. The platform could be converted into your type of drill by raising the table a few inches and mounting the drill motor on the lower chuck. Attach a lever to the drive pulley and install a USB microscope in the spring tower.
There is an exploded drawing in Sears | Craftsman - Publication Reprints - 103.20720 Craftsman 18-inch Jig Saw | VintageMachinery.org
Re: drill pcb
2016-02-29 by craigl2@...
I really think you'd be a whole lot better off building the frame from scratch. I used 8020 exclusions because I have some available from a project I decided not to currently pursue and they allowed me to easily make adjustments as I was trying out various options and configurations. The frame and most of the rest of the parts can be made with hand tools although a standard drill press would be useful. You could also buy extrusions from:
http://openbuildspartstore.com/
They are little smaller but should work fine and are cheaper than 8020 extrusions. A rigid box-like frame out of MDF were also work.
The tabletop was a 6 inch wide piece of flat stock steel (not plate) purchased by the inch (cut to size) from Speedy Metals.
Craig
2016-02-29 by casy_ch@tbwil.ch
And how to transform the motor axle to turn vertically? In the original
state it drives an excenter.
Jean-Claude
Am 29.02.2016 um 16:01 schrieb wb8nbs@... [Homebrew_PCBs]:
> saws like
> <http://www.vintagemachinery.org/pubs/detail.aspx?id=2156>
> Jig Saw | Vintag...
> <http://www.vintagemachinery.org/pubs/deta%0A%20il.aspx?id=2156>
> View on www.vintagemachinery.org
> Preview by Yahoo
Plotter ink as resist? (was: Re: [Homebrew_PCBs] Re: drill pcb)
2016-02-29 by Brad Thompson
On 2/28/2016 11:55 PM, Stefan Trethan stefan_trethan@...
"As far as I know Staedtler Lumocolor red is the best resist ink.
It is still available and I am not aware of any change in the formulation?"
Hello, Stefan--
Thanks for your question.
IIRC, the ink may not have been a Staedtler product. The topic arose
around the time
that HP introduced its 7470 desktop plotter (early 1980s), and various
experimenters were trying
direct-writing PC resist application. One red ink in particular proved
to work relatively well but then was
withdrawn and reformulated which degraded its performance as resist.
Maybe it's time to dig out those mothballed HP plotters and try again....
Thanks again, and 73--
Brad  AA1IP
RE: Plotter ink as resist? (was: Re: [Homebrew_PCBs] Re: drill pcb)
2016-02-29 by Dave G4UGM
> Sent: 29 February 2016 16:26
> Subject: Plotter ink as resist? (was: Re: [Homebrew_PCBs] Re: drill pcb)
> Hello, Stefan--
> IIRC, the ink may not have been a Staedtler product. The topic arose around
> the time that HP introduced its 7470 desktop plotter (early 1980s), and
> various experimenters were trying direct-writing PC resist application. One
> red ink in particular proved to work relatively well but then was withdrawn
I have a number of plotters and plotting with a Staedtler Narrow Red gives enough etc resistance for reasonable boards, but a Narrow Red isn't very narrow, and is rally only suitable for pitches down to 0.05 or so.
I personally wouldn't use it on anything fine.  I must say I also have a 3d printer with an attachment to allow me to Mill PCBs with a Dremel but I have yet to try that in anger.
I built it to drill holes for switches for a computer project...
> Brad  AA1IP
Dave
G4UGM
2016-02-29 by keith printy
Just a thought , anyone thought of using nail polish ? it is a laquer  and you could likely dilute it so the printer can spray it on the boards.
Sent: Monday, February 29, 2016 11:26 AM
Hello, Stefan--
around the time
Brad AA1IP
