Homebrew PCBs
Custom G10 copper clad
2016-03-17 by Brad
Hey guys,
Some of you might remember my queries about trying to get 'correct' looking
single side copper clad PCBs for my vintage TV Typewriter project.  I think
I may have found a source, and I wanted your opinions to make sure I'm
getting the right thing and can do what I want to do.
The company I found is American Micro:
http://www.americanmicroinc.com/g10-fr4/
According to Don Lancaster, he used 'G10 Green' boards.  The above appears
to be more or less that.  Then what AM will do is add the copper cladding.
It will cost me $400.00USD to yield the following:
2 pcs - 9"x7"
6 pcs - 5"x7"
Plus remainder from sheet after cutting.
Now, they are specifying .010" .. I've no idea what thickness the original
TVT boards were, but I'm guessing they were probably thicker (.06ish?).
Thoughts?
I think the price is higher than what those pieces would cost via suppliers
on ebay, etc.  However I'm not bothered by that - the important thing for
this project is that the boards look correct and have the correct grain and
colour.  In searching various single side PCB suppliers, the colours are too
fancy or modern and the grain doesn't look right.
For a refresher, here's a shot of one of the original boards:
http://i1381.photobucket.com/albums/ah216/unclefalter/tvtboards2_zpssy81hx8b
.jpg~original
What do you guys think?  Also, is there anything I need to be wary of in the
process that they use to affix the copper cladding to the boards?  I'm
hoping to use the toner method of etching to get these done.
Thanks again!
Brad
Re: [Homebrew_PCBs] Custom G10 copper clad
2016-03-17 by rolohar@...
"On Behalf of Brad";
Excuse my lack of knowledge.........but why is it important to use GIO epoxy-glass PCB material
for the Lancaster TV typewriter circuit board(s).
I remember this circuit was published in one of the hobby electronics magazines, and Lancaster
subsequently published a paperback on building this item.
Best,
Roland F. Harriston, P.D.
From: "'Brad' unclefalter@yahoo.ca [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com>
To: "Homebrew PCBs" <Homebrew_PCBs@yahoogroups.com>
Sent: Wednesday, March 16, 2016 7:05:21 PM
Subject: [Homebrew_PCBs] Custom G10 copper clad
Hey guys,
Some of you might remember my queries about trying to get ‘correct’ looking single side copper clad PCBs for my vintage TV Typewriter project. I think I may have found a source, and I wanted your opinions to make sure I’m getting the right thing and can do what I want to do.
The company I found is American Micro: http://www.americanmicroinc.com/g10-fr4/
According to Don Lancaster, he used ‘G10 Green’ boards. The above appears to be more or less that. Then what AM will do is add the copper cladding. It will cost me $400.00USD to yield the following:
2 pcs – 9”x7”
6 pcs – 5”x7”
Now, they are specifying .010” .. I’ve no idea what thickness the original TVT boards were, but I’m guessing they were probably thicker (.06ish?). Thoughts?
I think the price is higher than what those pieces would cost via suppliers on ebay, etc. However I’m not bothered by that – the important thing for this project is that the boards look correct and have the correct grain and colour. In searching various single side PCB suppliers, the colours are too fancy or modern and the grain doesn’t look right.
For a refresher, here’s a shot of one of the original boards: http://i1381.photobucket.com/albums/ah216/unclefalter/tvtboards2_zpssy81hx8b.jpg~original
What do you guys think? Also, is there anything I need to be wary of in the process that they use to affix the copper cladding to the boards? I’m hoping to use the toner method of etching to get these done.
Thanks again!
Brad
RE: [Homebrew_PCBs] Custom G10 copper clad
2016-03-17 by Brad
What I am trying to achieve is as close to a copy of the original prototype boards Don made that I can muster.  When I asked him what the material was, all he said was ‘G10 green’.  When I look at the material I’ve found with this company, it looks as close as I can tell to what Don would have used, which I imagine is similar to what the later SWTPC kit boards also used.  But I’m guessing.. this was all before my time. :)
From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com]
Sent: Wednesday, March 16, 2016 7:31 PM
To: Homebrew PCBs <Homebrew_PCBs@yahoogroups.com>
Subject: Re: [Homebrew_PCBs] Custom G10 copper clad
Best,
  _____
From: "'Brad' unclefalter@... [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com>
Hey guys,
2 pcs – 9”x7”
6 pcs – 5”x7”
Thanks again!
Brad
Brad:
Can I assume that the quest for G10-epoxy glass material is for cosmetic purposes only?
"What I am trying to achieve is as close to a copy of the original prototype boards Don made that I can muster. "
2016-03-17 by Norm
On 3/16/2016 7:05 PM, 'Brad' unclefalter@... [Homebrew_PCBs] wrote:
\ufffd
\ufffd
Now, they are specifying .010\ufffd .. I\ufffdve no idea what thickness the original TVT boards were, but I\ufffdm guessing they were probably thicker (.06ish?).\ufffd Thoughts?
\ufffd
Way back then (60's-70's), the very thin boards were used for commercial production.\ufffd Hobby boards were thicker - 0.062"\ufffd probably most common.\ufffd I recall using 0.12" boards for things (like keyboard substrates) that required mechanical strength.
Norm
w6nim since 1952
2016-03-17 by Stefan Trethan
I didn't follow the conversation before, but $400 for a couple pieces regular FR4 seems pretty crazy to me.
ST
On Thu, Mar 17, 2016 at 3:05 AM, 'Brad' unclefalter@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
Hey guys,
2 pcs – 9”x7”
6 pcs – 5”x7”
Thanks again!
Brad
I'd guess the 0.01" boards might be intended for multilayer...
ST
On Thu, Mar 17, 2016 at 3:41 PM, Norm w6nim@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
Way back then (60's-70's), the very thin boards were used for commercial production. Hobby boards were thicker - 0.062" probably most common. I recall using 0.12" boards for things (like keyboard substrates) that required mechanical strength.
Norm
w6nim since 1952
2016-03-17 by camillus
Are those boards gold plated or something???
$400.00 sure that'snot a typo???
cb
On 3/17/2016 3:57:52 PM, Stefan Trethan stefan_trethan@... [Homebrew_PCBs] <homebrew_pcbs@yahoogroups.com> wrote:
ST
On Thu, Mar 17, 2016 at 3:05 AM, 'Brad' unclefalter@yahoo.ca [mailto:unclefalter@...] [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com]> wrote:
Hey guys,
The company I found is American Micro: http://www.americanmicroinc.com/g10-fr4/ [http://www.americanmicroinc.com/g10-fr4/]
2 pcs – 9”x7”
6 pcs – 5”x7”
For a refresher, here’s a shot of one of the original boards: http://i1381.photobucket.com/albums/ah216/unclefalter/tvtboards2_zpssy81hx8b.jpg~original [http://i1381.photobucket.com/albums/ah216/unclefalter/tvtboards2_zpssy81hx8b.jpg~original]
Thanks again!
Brad
2016-03-17 by Harvey White
I think what they're doing is taking G10 and laminating the copper
directly on it, a one-of custom job.
That's for bare boards, not even made and drilled.  I think he's going
to have to make those boards himself.  I'd be tempted to do
photoresist and the original negatives *if* I had the process down and
working to my satisfaction.
Toner transfer may or may not give the same look and feel, although
that could be debated.
What I would certainly do is make at least one with conventional FR4
just to see what it looked like.  It probably will not be exact, but
it would be a good test of the design.
Then I'd start working on the boards.  If I remember it properly, the
average board was 0.062 in thickness, with some of the backplanes
being about .125 or so.  It depended on what was attached to them and
how much flexing was tolerable.
I've got board stock from that era, but most of it is about 4 by 5 or
so, and I have no idea if it's G10 or not. Likely it's FR2 or 3.  How
might I tell?  If I had the stock in the right size, I'd be happy to
give you some (for postage).
Harvey
>cb
>\ufffd
>ST
>On Thu, Mar 17, 2016 at 3:05 AM, 'Brad' unclefalter@... [mailto:unclefalter@...] [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com]> wrote:
>Hey guys,
>Some of you might remember my queries about trying to get \ufffdcorrect\ufffd looking single side copper clad PCBs for my vintage TV Typewriter project. I think I may have found a source, and I wanted your opinions to make sure I\ufffdm getting the right thing and can do what I want to do.
>According to Don Lancaster, he used \ufffdG10 Green\ufffd boards. The above appears to be more or less that. Then what AM will do is add the copper cladding. It will cost me $400.00USD to yield the following:
>2 pcs \ufffd 9\ufffdx7\ufffd
>6 pcs \ufffd 5\ufffdx7\ufffd
>Now, they are specifying .010\ufffd .. I\ufffdve no idea what thickness the original TVT boards were, but I\ufffdm guessing they were probably thicker (.06ish?). Thoughts?
>I think the price is higher than what those pieces would cost via suppliers on ebay, etc. However I\ufffdm not bothered by that \ufffd the important thing for this project is that the boards look correct and have the correct grain and colour. In searching various single side PCB suppliers, the colours are too fancy or modern and the grain doesn\ufffdt look right.
>For a refresher, here\ufffds a shot of one of the original boards: http://i1381.photobucket.com/albums/ah216/unclefalter/tvtboards2_zpssy81hx8b.jpg~original [http://i1381.photobucket.com/albums/ah216/unclefalter/tvtboards2_zpssy81hx8b.jpg~original]
>What do you guys think? Also, is there anything I need to be wary of in the process that they use to affix the copper cladding to the boards? I\ufffdm hoping to use the toner method of etching to get these done.
>Thanks again!
>Brad
Re: Custom G10 copper clad
2016-03-17 by hrconsult@...
Hi guys,
I have been following this group for many months, and I am very excited to see the quality of the discussions presented here.
I have not contributed until now because I had little to add. I made boards as a teenager in the '60s and then into the '70s. In those days I used G-10 board. A some point FR-4 crept in, and became the standard for PWBs. Recently, I have become interested in making boards again, and am delighted to have discovered this group.
My 2 cents: I think the train has become derailed on the subject for G-10 vs. FR-4. It seems to me that the stated goal was to get boards that look like Don Lancaster's green G-10. There are several companies making unclad G-10 and FR-4. You only need to look at the websites to see that both are the same color when purchased as natural. The only difference between them is the addition of a small amount of Bromine to make
the FR-4 boards flame retardant. Check this out: http://www.acculam.com/data-chart.html. Other places on this website (Accurate Plastics, inc) show samples of the material, and it can be seen that the color is the same. The color of the G-10 from American Micro Industries is the same.
The "green" color is called natural. Back in those days, the only color that glass/epoxy boards came in was natural or "green." The shade did vary between manufacturers, probably because of differences in the epoxies they used.
Since the color is the same and the goal is to provide the same looking boards, I think that the solution is to use FR-4, and specify "natural" color for the base material.
(Another) Harvey
Re: [Homebrew_PCBs] Re: Custom G10 copper clad
On 17 Mar 2016 12:03:01 -0700, you wrote:
>Hi guys,
I like the name.
The main thing I saw between the two grades was exactly what you
mentioned, the addition of bromine to make the board less flammable.
I think that if the board is solder masked (and I don't remember if
they were or not), the color of the solder mask will generally
override the board color.
The thickness of the board also determines the depth of color as well.
Harvey
>(Another) Harvey
2016-03-17 by Brad
Yes, the TVT design I think is basic enough it’d work on virtually any single side copper clad PCB.  I’m just being particular because this is a ‘replica’.
Sent: Wednesday, March 16, 2016 9:00 PM
Brad:
  _____
2016-03-18 by Harvey Altstadter
I just looked at some old boards that I still have.\ufffd They are about the same color as the current material, maybe a shade or two darker.\ufffd To my mind, it makes no sense to go to great expense to custom laminate copper clad boards with current G-10 material, as they will come out looking just like common FR-4.\ufffd My best guess is that the original boards were 0.062" thk, give or take a mil or two.\ufffd Back in the 1960's I was working in an electronic surplus house in New York.\ufffd The only copper clad material we ever had in those days was nominal 1/16" (0.0625).\ufffd I don't remember any finished boards we received, including military surplus having solder mask until much later. The military boards were covered with a conformal coat of one sort or another.\ufffd
(Another) Harvey
On 3/17/2016 12:17 PM, Harvey White madyn@... [Homebrew_PCBs] wrote:
\ufffd
>Hi guys,
I like the name.
Harvey
>(Another) Harvey
2016-03-18 by Harvey White
On Thu, 17 Mar 2016 21:09:42 -0700, you wrote:
>I just looked at some old boards that I still have.  They are about the
>same color as the current material, maybe a shade or two darker.  To my
>just like common FR-4.  My best guess is that the original boards were
>0.062" thk, give or take a mil or two.  Back in the 1960's I was working
>in an electronic surplus house in New York.  The only copper clad
>material we ever had in those days was nominal 1/16" (0.0625).  I don't
Thinking of all the HP and Tek equipment I have that dates from that
time, I'll agree with you.  No solder mask (although I've seen some, a
different style, generally green if nothing else.  I think it was
likely spray paint, candy apple green or the like, and you either
soldered through it or you actually had a mask).  The conformal
coating was an epoxy dip.
Even military boards (of that time) did not have a silk screen (much)
or a solder mask as I remember.
And 1/16th was about right, unless you had a motherboard made that
someone was going to be plugging stuff in, and I've seen that be 1/8th
thick.  (old southwest technical stuff).
Harvey
>(Another) Harvey
>> >Hi guys,
>> to make
>> I like the name.
>> Harvey
>> >(Another) Harvey
RE: [Homebrew_PCBs] Re: Custom G10 copper clad
2016-03-18 by Brad
Thanks for this very excellent explanation.  It’s doubly hard being a newbie but also trying to understand how things were done back in the day.
Because this is a replica, the correct look is very important to me.  It would have been much easier to take the offerings available on mouser or ebay.. but the colours look wrong and the boards themselves too modern.  Further, for some bizarre reason, most of the manufacturers don’t bother taking a picture of the actual PCB.. just the copper side, so you can’t ever be sure what color it is.  It’s funny how one does that and then they all do.
So yeah, the reason I went to these guys is, it looks like we have the right ‘grain’ and right colour.  I don’t care so much about fire resistance, but it seems like all the G10 I’ve found in my color is FR4 regardless.
When you guys were doing these boards in the 70s.. they were single side copper clad photo sensitive right?  I tried asking Don exactly what format the boards he used came in (ie if they were just the PCB or had copper affixed), but he tends to be cryptic in his responses.
From: Homebrew_PCBs@...m [mailto:Homebrew_PCBs@yahoogroups.com]
Sent: Thursday, March 17, 2016 12:03 PM
Subject: [Homebrew_PCBs] Re: Custom G10 copper clad
Hi guys,
(Another) Harvey
2016-03-18 by Brad
With photoresist though, the boards have to be bought pre-sensitized right?
Here is an example of the artwork Radio Electronics offered in their
construction kit for those who were going full DIY:
http://www.swtpc.com/mholley/TV_Typewriter/page_18.pdf
Will laser really make a difference?
I'm looking at another company that sells already made natural coloured
copper clad:
http://www.currentcomposites.com/html/electrical_grade_laminates.html
The thing that I find confusing is some companies seem to use FR4/G10
interchangeably, even though they mean two different things..
Sent: Thursday, March 17, 2016 8:55 AM
Harvey
>cb
>ST
>Hey guys,
may have found a source, and I wanted your opinions to make sure I'm getting
>2 pcs - 9"x7"
>6 pcs - 5"x7"
Thoughts?
.jpg~original
b.jpg~original]
process that they use to affix the copper cladding to the boards? I'm hoping
>Thanks again!
>Brad
2016-03-18 by Cecil Bayona
A place to look for reasonable prices is eBay, I buy my PCBs there at reasonable prices, photos are included, several times I have seen PCB in .010 size, I have never bought that but I have bought and used .018 size because it's inexpensive and easy to cut.
Hi guys,
(Another) Harvey
Posted by: "Brad"
Cecil - k5nwa
http://thepartsplace.k5nwa.com/
2016-03-18 by Stefan Trethan
You can buy pre-sensitized boards or apply your own photoresist, as a liquid varnish or film.
Most people are going to look at you as if you are crazy for wanting a specific colour and weave of material. That is because you are crazy of course, and nothing to worry about.
It will not help your quest at all, but consider buying double sided laminate (with copper on both sides). I found it much easier to obtain and just etch one side away completely for single sided boards. Of course it makes impossible to see the inside.
Also mind that in any case the copper on the other side will severely change the colour you see, even if the seller provides a photo of the board side. The copper layer is actually a dark red underneath, completely different colour from the shiny top surface.
ST
On Fri, Mar 18, 2016 at 5:13 PM, 'Brad' unclefalter@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
Here is an example of the artwork Radio Electronics offered in their construction kit for those who were going full DIY:
I’m looking at another company that sells already made natural coloured copper clad: http://www.currentcomposites.com/html/electrical_grade_laminates.html
The thing that I find confusing is some companies seem to use FR4/G10 interchangeably, even though they mean two different things..
so, and I have no idea if it's G10 or not. Likely it';s FR2 or 3. How
Harvey
>cb
>ST
>On Thu, Mar 17, 2016 at 3:05 AM, 'Brad' unclefalter@... [mailto:unclefalter@yahoo.ca] [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com]> wrote:
>Hey guys,
>2 pcs – 9”x7”
>6 pcs – 5”x7”
>Thanks again!
>Brad
On Fri, 18 Mar 2016 09:03:23 -0700, you wrote:
>Thanks for this very excellent explanation.  It\ufffds doubly hard being a newbie but also trying to understand how things were done back in the day.
>Because this is a replica, the correct look is very important to me.  It would have been much easier to take the offerings available on mouser or ebay.. but the colours look wrong and the boards themselves too modern.  Further, for some bizarre reason, most of the manufacturers don\ufffdt bother taking a picture of the actual PCB.. just the copper side, so you can\ufffdt ever be sure what color it is.  It\ufffds funny how one does that and then they all do.
The colors are biased by the board material (now available in all
sorts of colors, black is particularly nice for displays), and the
silk screening.
Silk screening of that era, if present was more than likely the same
standard green.
The look of the board is far more how the parts are laid out, the vias
(if any), and whether or not the board was computer generated or tape
laid out.
Used to be that you decided on the size of your board, then drew a 2x
master on grid paper (there were parts templates).  Then you'd put a
layer of acetate over that and lay down the pads, then connect them
with black crepe tape.  You'd then photograph that (backlit) with a
view camera using Kodalith film (with the two solution developer)
which develops the film to pretty much transparent or complete black
(you had to get the one that did come used for photographs, you wanted
the line version).  That produced a life sized negative, transparent
where there was to be copper.  (and I'm doing this for single sided or
double sided without plated through holes).
Then you coat the board (or have it coated) with Kodak KPR (nasty
stuff), expose it under short wave UV, develop it, dye it to see how
it came out, then etch it.
Very different look from today's boards, mostly due to the lack of
solder mask (some) and definitely the layout techniques on the lines.
so photoetch from the template or toner transfer from the template
will get you very close.
I'd recommend doing a single sided (I think it was) board using toner
transfer on standard FR4, and then see how close you really are.
That would give you a test model at the least.
Harvey
>So yeah, the reason I went to these guys is, it looks like we have the right \ufffdgrain\ufffd and right colour.  I don\ufffdt care so much about fire resistance, but it seems like all the G10 I\ufffdve found in my color is FR4 regardless.
>Hi guys,
>(Another) Harvey
Hit return too quickly.
All the G10 is likely FR4, I don't see a real difference in color or
grain.
Single or double side, optionally photosensitive.
The people who were making the board material could laminate the
boards with copper foil, but you never bought the bare fiberglass
unless you staked in terminals and wired that way.
His boards were likely silk screened (common in the 60's and 70's for
relatively non-complicated boards).  Toner transfer would give you an
equivalent look.
Photoetched was a complicated process, more commercial than not, and
may not have been all that prevalent in the hobby side.  I did it, but
I had access to the chemicals, a view camera and the darkroom needed.
Toner transfer was not possible (no laser printers, depending up to
when, that you could have yourself).  Copy centers, businesses,
likely, but not home use.
Harvey
>Hi guys,
>(Another) Harvey
Re: [Homebrew_PCBs] TV Typewriter: Custom G10 copper clad
2016-03-18 by rolohar@...
Yeah
And besides, there are scant few folks around in hobby electronics nowadays that have ever actually
laid eyes on a finished (or unfinished) Lancaster TV Typewriter. It is totally obsolete by todays standards and state
of the art.
And, as Lancaster envisioned, the thing was to be enclosed in a kind of wooden desk-top enclosure, so
nobody sees the circuit boards anyway.
Too bad that a search can't somehow be made on the internet, inquiring if there is some
"old-timer" (like me) that has a Lancaster TV Typewriter in a dusty pile of forgotten projects,
and that way, you could get the "real" item and bring it back online.
These are just suggestions.........now, don't everbody jump on me with snide remarks.
Regards.
From: "Stefan Trethan stefan_trethan@... [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com>
Snip:
ST
RE: [Homebrew_PCBs] TV Typewriter: Custom G10 copper clad
2016-03-18 by Brad
I agree with much of what you said in principle.  For me, this project is just about creating something you cannot buy.  There is only one prototype TVT and it resides at the Computer History Museum.  Strangely, the museum has never photographed the insides of that unit.  Which to me is odd, because, you know, that’s what the project was really about.. not the case.  And from what I’ve heard, the bottom is open (for easy access).  The boards mount upside down with the switches on the back of the motherboard facing up.  The museum was very helpful giving me measurements and stuff, but they can’t/won’t flip the unit over because it’s bolted to its display shelf.  I asked when it might be possible and they guessed in about 10-20 years.
I did have an exchange going with Don Lancaster at one point.  Don is the one who told me the original boards were ‘G10 Green’.  However on my third email (spaced about six months apart), he stopped replying.  And he would not answer questions about the case design either.  I still don’t know if the top of the case is wood or metal.  I’m hoping I’ve not offended him – ie. maybe he doesn’t want a replica of his prototype out there.
I’d happily buy an original TVT board set in any condition, but they just don’t come available.  I’m still kicking myself for missing that board set that came up some months ago.  It only went for $38 too!  Don’t know if they’re original or not, but based on the silkscreening I think they were vintage 1973 boards from the kit the magazine offered, made by SWTPC.
Anyway, I know I could get away with being inexact here.  But the point of the exercise is to get as close to original as possible, which is why I went to the trouble of getting 1973 vintage chips.  I’d also like to duplicate the process a hobbyist of that day would have used also, for my own education and experience.  The experience is a big part of this.  I want to be able to do what the museum can’t/won’t, let people see and use and get the feel for the thing.  The museum will never show the most important part of the TVT, the boards, but I can with mine.  And because I can I will, and I guess for that reason I want them to look right.
Sent: Friday, March 18, 2016 10:35 AM
Subject: Re: [Homebrew_PCBs] TV Typewriter: Custom G10 copper clad
Yeah
of the art.
Regards.
  _____
Snip:
ST
2016-03-18 by Brad
Also on the original front – I don’t think anyone harboring an original TVT project would be willing to give it up for less than lots of money, given how rare and important historically they are.  So that’s why I’m not holding my breath there.
Yeah
of the art.
Regards.
  _____
Snip:
ST
Anyone Interested:
Before spending a lot of time and frustration in trying to build the old
Don Lancaster TV-Typewriter project in any of
the several iterations, please read the information in the URL below.
http://everything.explained.today/TV_Typewriter/
Looking at the Lancaster design now........in 2016..............it
hardly looks like a intelligent investment in time nor money.
Arguments, contradictions, profanity, etc. are welcomed.
Roland F. Harriston, PD
Subject: RE: [Homebrew_PCBs] TV Typewriter: Custom G10 copper clad
Brad,
I will address how I did things back in Medieval times below. First, I
will tell you how to get natural color FR-4.
I did a little detective work by going to the website of Frys
electronics (frys.com), a US electronics chain that I know carries PWB
materials and chemicals.   Their website shows that they carry board
material and chemicals from MG Chemicals. A trip to their website,
mgchemicals.com, shows that they sell non sensitized and photo
sensitized single and double sided FR-4 material.  Further thrashing
around their site yielded some training videos, one of which is called
"The Etching Process." Lo and behold, the color of the board that comes
out of the etch tank is "natural."  From this, I conclude that their
boards are just the color you want them to be. The website also lists
world wide distributors for their materials. As a double check, you
could always ask them what color the boards are.
There were several ways we made our boards back in the Dark Ages. Many
commercial boards were made by using photo sensitized boards and
exposing/developing them with a process similar to processing B & W
prints (Photolithography).  Others were made by silk screening etch
resist onto the board, drying it and etching. I did photo process by
buying non sensitized boards and using an aerosol spray photo resist
from one of the chemical companies.  The actual material was Kodak KPR,
a negative acting photoresist.  I prepared my artwork 1:1 on clear
acetate film using precision cut tape and pad patterns from Bishop
Graphics.  The artwork was a positive of the final copper pattern.
Everything I have described so far was very expensive.  The artwork was
contact printed onto Kodalith film.  This is a lithography film that
displays almost no gray scale.    The output from this was a negative
with dense blacks and clear areas.  The negative was contact printed
onto the sensitized board and exposed to UV light. The developer washed
away the parts of the resist where the copper was to be etched away.
That explains how it was supposed to work.
Problems in the garage lab:
1. The KPR spray had to be done in semidarkness.  It had a purple dye,
so it could be seen in low light.  I used a low wattage yellow bug light
for my safe light. It was very difficult to spray a thin coating of
uniform thickness on the board in the low light.  Uneven thickness
interfered with the development process, so that parts of the board
didn't clean off properly in development. KPR was also available as a
very thick liquid.  This would be dispensed into the approximate center
of a board mounted horizontally on a spinner. With vacuum holding the
board down, it would be spun until the resist distributed itself evenly
on the board, and all the surroundings.  This probably worked quite
well, but was too difficult to implement in the garage.
2. Kodalith was an excellent product when it was fresh. Unfortunately,
the smallest quantity I could buy it in was 25 sheets.  Since I was
making boards only occasionally, it took me a long time to use this up.
After some period of storage, the dense blacks became dark grays, and no
longer performed adequate masking.
3. Ditto for the photo processing chemicals.
4. On top of this, the development process required some reasonable
degree of temperature control.  I was doing this in an unheated garage
in New York, winter and summer.
5. My sources of UV light were varied.  I tried the bulbs that were used
for lighting up fluorescent posters in Discos.  They worked, but the
light was too uneven.  I tried the recommended photoflood bulbs in a 15"
reflector.  This worked, but it was intensely hot, and the board had to
be moved far enough away that the resist would not melt and stick to the
negative.  The lamps only had a four hour life, and if you jostled them
at any point the filaments broke.  Did I mention that they were also
expensive.  I built a small light box with 4" UV fluorescents. This
worked but was limited to very small boards.
6. The photo process gave excellent alignment for two sided boards, but
the problems of etching both sides evenly made it a grim undertaking.  I
won't even try to describe the handstands I did to get that to work.
Getting a really good board out of this was as much a matter of luck as
science.  Most boards had at least a few jumper wires repairing traces,
and a few scratch marks where bridges had to be removed.
We also had resist pens that were like blunt Sharpies, and gave out with
a black tar.  This worked but was very sloppy, and was only for one off
boards. Other processes for one off boards was the placement of pads and
tape directly on the copper, and then etching.  This was very tedious,
and suffered from undercutting where the tape went over the pad.
It wasn't easy in the bad old days.
(Another) Harvey
On 3/18/2016 9:03 AM, 'Brad' unclefalter@... [Homebrew_PCBs] wrote:
> Thanks for this very excellent explanation.  It\u2019s doubly hard being a
> manufacturers don\u2019t bother taking a picture of the actual PCB.. just
> the copper side, so you can\u2019t ever be sure what color it is.  It\u2019s
> right \u2018grain\u2019 and right colour.  I don\u2019t care so much about fire
> resistance, but it seems like all the G10 I\u2019ve found in my color is
> FR4 regardless.
> *From:*Homebrew_PCBs@yahoogroups.com
> *Sent:* Thursday, March 17, 2016 12:03 PM
> *To:* Homebrew_PCBs@yahoogroups.com
> *Subject:* [Homebrew_PCBs] Re: Custom G10 copper clad
> Hi guys,
> (Another) Harvey
I built one to replace my clunk model 45 Teletype, eventually I replaced it with a Televideo 950.
To: Homebrew PCBs
Yeah
of the art.
Regards.
From: "Stefan Trethan stefan_trethan@gmx.at [Homebrew_PCBs]"
Snip:
ST
Posted by: "Brad"
Cecil - k5nwa
Roland,
I don't think it is about time or money.  This is a challenge and a
learning experience.  Stuff we do for fun.
When I first saw this thread, I went into my archives, and after blowing
away the cobwebs, I tried to find my copy of Don Lancaster's TV
Typewriter Cookbook.  I was hoping that the information might be in
there.  I didn't find it, but with a web search I was able to find it
available for download at no cost.  A quick perusal didn't turn up the
missing info.  The board photos were in B & W, so color could not be
determined.  I also found color pictures of several of the SWTP boards,
which show that their boards were natural in color.
(Another) Harvey
On 3/18/2016 1:48 PM, rolohar@... [Homebrew_PCBs] wrote:
> Anyone Interested:
> Regards,
> *From: *"'Brad' unclefalter@...
> *Subject: *RE: [Homebrew_PCBs] TV Typewriter: Custom G10 copper clad
> Also on the original front \u2013 I don\u2019t think anyone harboring an
> that\u2019s why I\u2019m not holding my breath there.
"'Brad' unclefalter@... :
And there are several "Show-And-Tell" videos about the TV Typewriter on YouTube,
plus several Internet postings under Radio Electronics magazine (TV Typewriter)
that show the "innards" of the device, including photos of the motherboard and the
4 pr 5 other PCB's that comprise the complete unit.
Additionally, I wonder where one could obtain the special keyboard (Lancaster design, later
manufactured by SWTP). And I think I have seen several versions of the "motherboard"
that were both epoxy-glass and XXXP paper material.
Lancaster spent his last days in a "home" for seniors, and I'm not sure that he was in
a position to correspond with the general public.
His projects and publications were inspiring to a lot of people........including me.
I still have a few of his publications, and I still refer to them when I get "stuck".
Good luck on this project!
a
My last and final blab about Lancaster's TV Typewriter enterprise:
Shows a basic or "motherboard" as we would call it in modern times, and this one appears to be
low-cost paper-phenolic material, which was very common during this time frame.
The other PCB's seem to be a mix of several materials.
http://www.swtpc.com/mholley/TV_Typewriter/Rethemeyer.htm
Onward.
From: "Harvey Altstadter hrconsult@... [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com>
Sent: Friday, March 18, 2016 2:12:02 PM
Roland,
I don't think it is about time or money. This is a challenge and a learning experience. Stuff we do for fun.
When I first saw this thread, I went into my archives, and after blowing away the cobwebs, I tried to find my copy of Don Lancaster's TV Typewriter Cookbook. I was hoping that the information might be in there. I didn't find it, but with a web search I was able to find it available for download at no cost. A quick perusal didn't turn up the missing info. The board photos were in B & W, so color could not be determined. I also found color pictures of several of the SWTP boards, which show that their boards were natural in color.
(Another) Harvey
On 3/18/2016 1:48 PM, rolohar@comcast.net [Homebrew_PCBs] wrote:
Anyone Interested:
2016-03-18 by Brad
The only original photos of the PCBs that I’ve found are the black and whites that appear in the magazine article.  And unfortunately apart from color, I wasn’t able to confirm that those were the actual boards in the prototype.  There is a possibility they may be the SWTPC production boards.  The picture is hard to discern, but I don’t think I see any silkscreening, so we could be right.  But why in 40 years nobody has taken some color photos of the prototype’s boards is beyond me.
I didn’t realize Lancaster was in a home (although I kind of thought he must be getting up there age wise).  He was pretty detailed in some of his responses and he maintains a website (tinaja.com).  I tried the best I could not to pester him too much, sending an email only when necessary and months apart.  But yeah, I suppose maybe it’s getting difficult for him to answer.
Not to get too off topic, but I already have the keyboard.  Well, sort of.  In other articles there are pictures of similar keyboards out of the prototype unit.  They have the same keys, same arrangement, same colors.  I believe ultimately his was a microswitch unit that went into Honeywell key to tape machines.  I was able to find a Mohawk MDS keyboard, which uses the same switches and keytops and can be arranged exactly the same way.  The only difference is the Honeywell units had a flange on either side one used to secure the unit.  The flanges on mine are detachable and not the same.  Here’s a photo of my first mockup.  The original keytops are white around the base and then blue, red or white on top.  I had to paint some of my keys blue the best I could to match Don’s look.  I think I got pretty close:
http://s1381.photobucket.com/user/unclefalter/media/e37ad304-1694-4961-8dea-6e3e2a8f1421_zpstnmvaanw.jpg.html
My case is also pretty much bang on, except the top part which could be metal or wood but is covered with vinyl on the prototype.  Also need to change my side pieces to oak from fir.
Sent: Friday, March 18, 2016 2:12 PM
  _____
a
On Fri, 18 Mar 2016 13:36:03 -0700, you wrote:
<snip>
>Anyway, I know I could get away with being inexact here.  But the point of the exercise is to get as close to original as possible, which is why I went to the trouble of getting 1973 vintage chips.  I\ufffdd also like to duplicate the process a hobbyist of that day would have used also, for my own education and experience.  The experience is a big part of this.  I want to be able to do what the museum can\ufffdt/won\ufffdt, let people see and use and get the feel for the thing.  The museum will never show the most important part of the TVT, the boards, but I can with mine.  And because I can I will, and I guess for that reason I want them to look right.
Then a suggestion I'd have would be to go do what you want, but be
reasonable about the definition of "as reasonable".  I think that the
comment about the different variations having possibly different color
boards is realistic, although I don't remember any SWTP product that I
saw having paper boards (although there were a lot out there).
NEXT:  I'd design the same thing using modern technology, and build
one of them.  That would give people a unique idea of just how far
technology has come in about 50 years.  (note: feel free to embellish,
but have the basic mode be exactly what the original did).
I seem to remember a 68045 chip that was designed to be a similar
style of display.
Harvey
>Yeah
>of the art.
>Regards.
>  _____
>Snip:
>ST
2016-03-18 by Andrew Volk
I suspect the part you were referring to is the 6845, the CRT chip used in
the first IBM PCs.
Sent: Friday, March 18, 2016 2:58 PM
<snip>
to the trouble of getting 1973 vintage chips. I'd also like to duplicate the
do what the museum can't/won't, let people see and use and get the feel for
style of display.
Harvey
>Yeah
>of the art.
there is some
forgotten projects,
snide remarks.
>Regards.
> _____
>Snip:
>ST
>the first IBM PCs.
Actually, no.  The 6845 did 80 by 40 amongst other thins, the other
chip is either the 68047 (AMI) or the 6847(Y) from Motorola.  It's
essentially the display section of a TV typewriter on a chip, although
IIRC it did need a color modulator since it put out R-Y and B-Y for
color information.
So I got the name wrong, but close.
Harvey
><snip>
>style of display.
>Harvey
>>Yeah
>>of the art.
>there is some
>forgotten projects,
>snide remarks.
>>Regards.
>> _____
>>Snip:
>>ST
I believe that the unit with the brown paper mother board was a "homebrew" board,
now that I re-read the item (photos) I posted.
However the unit looks neat and well-done.
T
Quote:
"But why in 40 years nobody has taken some color photos of the prototype’s boards is beyond me."
I think that the technology was elevating so fast at that time, that the TV Typewriter concept
faded away pretty fast.
More sophisticated applications (and chips) were emerging which offered more "bang-for-the buck" than
Lancasters device and all of its interations.
Soon after that, Altair, SWTP, and many other vendors were offering (nearly) complete computers for
not very much money.
Even the "Byte Shop" out of New York City had a computer kit for sale.
I guess I lean more toward innovation and progress tha nostalgia when it comes to this
kind of stuff.
But don't get upsent by saying that the demise of Kodachrome was a natural and expected
advance in color film technology!
RFH
Sent: Friday, March 18, 2016 2:52:55 PM
"'Brad' unclefalter@yahoo.ca :
a
2016-03-19 by Brad Thompson
Hello--
On 3/18/2016 5:52 PM, 'Brad' unclefalter@... [Homebrew_PCBs] wrote:
> <snip>
 >>I didn\u2019t realize Lancaster was in a home (although I kind of thought
necessary and months apart.  But yeah, I suppose maybe it\u2019s getting
By coincidence, I'm thumbing through a copy of "Place: See America
First", Volume 2 No. 1, October 1972,
Random House. It's a collection of essays, poems, drawings, and short
stories contributed by many
recognizable authors (e.g., Scott Turow, Molly Ivins, etc). And there on
pp. 171-177 is an article entitled
"The Hole Catalog: Access To Holes" by Don and Bee Lancaster. it's
essentially a guide to spelunking--
the art and science of cave exploration-- and written in the typical
Lancaster style of informal and
readable explanation of the topic.
73--
Brad  AA1IP
...Writing from the U.S.' east coast and offering a shoutout to the
other Brad, wherever he may be....
P.S. the 1970s featured "The Whole Earth Catalog" which was followed by
slew of "The Whole..."
catalogs of many things. So I guess that it's obvious that someone like
Don Lancaster
would borrow the concept to discuss caves and caving.
2016-03-19 by rolohar@...
Brad:
Don Lancaster passed away on October 24, 2013.
He was 81 years old.
I don't know who was (is) handling his correspondence (@Tanija).
I think some of his publications are still in print.
>>I didn’t realize Lancaster was in a home.
2016-03-19 by Brad
Are you sure about that?  I got an email from ‘Don’ in August of 2015 that said the following:
“At the time I bought a whole pile of surplus keyboards, mostly broken, to
get enough blue keys.
I don't remember, but I probably bought the memory chips as new
distributor stock. We did buy some surplus ones after the TVT went
into print. As I recall, these were factory rejects, and only about half
of them were resellable.”
Pretty sure that’s Don.
Brad
Sent: Friday, March 18, 2016 6:42 PM
Brad:
  _____
> <snip>
2016-03-19 by Brad
True, but the device is still historically significant.  At least, it was significant enough for a museum to want and display it.  Seems odd they wouldn’t want to show the truly relevant bits of it to the public.  Or that other vintage computer admirers over the years wouldn’t have caught a shot somewhere.
Sent: Friday, March 18, 2016 4:15 PM
kind of stuff.
RFH
  _____
  _____
a
2016-03-19 by Harvey Altstadter
Roland,
Hmmm... the What's new section of his website was updated as recently as
March 5 of this year.  He has some comments on the new Sainsmart
O'scope. Says he has one on order.
On 3/18/2016 6:41 PM, rolohar@... [Homebrew_PCBs] wrote:
> Brad:
> Regards,
> > <snip>
> >>I didn\u2019t realize Lancaster was in a home.
> they wouldn\u2019t want to show the truly relevant bits of it to the
> wouldn\u2019t have caught a shot somewhere.
Hello--
Based on some years as an E.E. and technical editor for trade magazines,
I'm a little suspicious. Here's a case in point:
After a layoff in the mid-1980s, I attended a party at which I bumped
into another E.E. who had also been laid off
from another company which designed and built Little Black Boxes (LBBs)
for a military program. He related the
following which may be true:
"We were running really late on delivery date for ten LBBs-- nine had
passed our final test, but we couldn't get the tenth
ready for delivery. The program manager decided to ship an empty
housing, which wouldn't pass acceptance tests
and hence would be get returned for repairs. The turnaround time would
let us get the tenth LBB ready to go.
Unfortunately, the incoming-test tech noticed that the nonworking LBB
was considerably lighter than the others
and opened its case. The company lost the contract, and I lost my job...."
So there may be no innards inside the museum's TV Typewriter's case.
73--
Brad  AA1IP
Harvey Altstadter:
Don Lancasters obituary is available on several websites, and I think it is on Wikipedia
Here is one URL, if you are interested in reading it.
http://www.legacy.com/obituaries/gjsentinel/obituary.aspx?pid=159729485
Here is another:
http://www.legacy.com/obituaries/commercialappeal/obituary-preview.aspx?n=don-lancaster&pid=167703074&referrer=1474
This information is not too difficult to find on the Net.
Sometimes for a person (like Lancaster), another person will respond to correspondence long after the individual
has deceased. Sometimes it is a member of the family, or in this case, most likely a former associate.
In this age of copyright mania, someone may own all the rights to Lancaster's publications and writings,
and probably may be profiting from them.
Hmmm... the What's new section of his website was updated as recently as March 5 of this year. He has some comments on the new Sainsmart O'scope. Says he has one on order.
Brad:
> <snip>
NOTE:
Both Lancaster obits may be wrong!
I'll go back and double check.
If people have been receiving information from "Don Lancaster" lately, then my inforation it
completely wrong.
The obits I referred to have different information for the deceased person.
Sorry!
Even a "P.D" is wrong once in a while.
From: "rolohar@... [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com>
Sent: Friday, March 18, 2016 8:54:03 PM
Harvey Altstadter:
Here is another:
Brad:
> <snip>
YES!
It must be the original Don Lancaster.
I apologize and deeply regret the error.
This is the first time in about 30 years that I have actually been wrong in anything that I said or wrote.
Best Regards,
Sent: Friday, March 18, 2016 7:21:26 PM
“ At the time I bought a whole pile of surplus keyboards, mostly broken, to
Brad
Brad:
> <snip>
2016-03-19 by Stefan Trethan
The PD admitting he is wrong. Who needs a TVT replica, this is a historic moment in itself!
ST
I have an appointment with my shrink first-thing Monday morning.
RFH
From: "Stefan Trethan stefan_trethan@gmx.at [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com>
Sent: Friday, March 18, 2016 9:28:11 PM
ST
2016-03-19 by Tom Crawford
This TV Typewriter thread has triggered some interesting thoughts, that might be of interest. I recall building one of these, so took a look through my project files (I keep stuff way too long...)
Found a picture of what I built, dated May, 1980. The photo note says it was a CT-1024, actually, not an original TVT. Photo includes a large aluminum box I hand-built from flat stock to hold all the electronics, power supplies and connectors, and a separate Keyboard, with a cable connection to the box. I made all the PCBs myself from the plans, and soldered a wire into every via of the set of 2-sided boards.
Behind is a modified BW TV to use as a CRT (prob. hot chassis, as I remember! I hope I had a polarized plug wired correctly to it!). Sitting next to it on the table is a home-made “Pennywhistle” 300 baud acoustic coupled modem. The phone handset cradles were made from cut-down soup cans, lined with weather-stripping foam.
After looking at the photo, I realized I had seen that big aluminum box recently, so after some poking around my workshop, I found the entire CT-1024, and it’s keyboard! (The modified TV and Pennywhistle I knew were gone, replaced quickly with a safer and clearer surplus CCTV monitor, and a faster 1200 baud direct connected modem...) I’m tempted to plug it in, and see what happens, but I don’t really need another project. Maybe someone else wants to try...? I also took some new pictures, including the insides and the circuit boards, I will see what’s involved in posting them, if anyone is interested. Sorry, don’t know what type of PCB material I would have used at the time [g].
This device replaced a modified IBM Selectric (From a “Computyper” device, as I recall), which never did work very well. Used for some online BB access locally, and with my first microcomputer, a “Tek-1802” (RCA 1802 cpu, ram, hex keypad, 7 segment displays...)
I moved on fairly quickly to a hand-built “Big Board” (Z80, 64K RAM, 80x24 display generator, 2x 8inch floppy drives (cost a fortune, even surplus!), running CP/M. Used this for “serious” software development in C. Was followed by a hand-built clone Apple II with floppies, then my first purchased IBM PC....
fyi,
Tom Crawford
Sent: Friday, March 18, 2016 5:01 PM
To: Homebrew PCBs mailto:Homebrew_PCBs@yahoogroups.com
Yeah
of the art.
Regards.
From: "Stefan Trethan stefan_trethan@gmx.at [Homebrew_PCBs]" mailto:Homebrew_PCBs@yahoogroups.com
Snip:
ST
Posted by: "Brad" mailto:unclefalter@yahoo.ca
Cecil - k5nwa
2016-03-21 by rolohar@...
Hi Tom Crawford:
Wow!
I kind of knew that if I put out some "bait", some reader would dig out his old TV-Typewriter and tell us
an interesting story.
Thanks
I’m tempted to plug it in, and see what happens, but I don’t really need another project. Maybe someone else wants to try...?.
Tom Crawford
2016-03-21 by Harvey Altstadter
Tom,
Your description of the modified TV for use as a monitor triggered my
memory.  Although I didn't build the TVT, I used the  handbook to modify
a small screen TV for use as a monitor.  Yes, it had a hot chassis.  I
used it with a computer board that I read about in Radio Electronics.
The CPU was the Signetics 2650. I bought the board from Central Data and
stuffed it myself. It came with the ROM listings in a poorly printed
book.  I manually programmed a 4K X 8 PROM. Much to my amazement, got
through it with no errors and the computer worked.  I remember one quirk
of the monitor.  Alternating lines of text angled to the left and
right.  I wanted to troubleshoot the system, expecting that there were
some sync issues, but with the monitor having a hot chassis, and the
scope having a grounded chassis, I didn't try.  The board came with a
version of BASIC on an audio cassette. That was loaded from a modified
audio tape player. Soon enough, the system was replaced by a Commodore
64, and the 2650 board relegated to long term storage bin in the sky.
(Another) Harvey
On 3/19/2016 10:12 AM, 'Tom Crawford' ah983@... [Homebrew_PCBs]
> boards.
> Sitting next to it on the table is a home-made \u201cPennywhistle\u201d 300 baud
> entire CT-1024, and it\u2019s keyboard!  (The modified TV and Pennywhistle
> CCTV monitor, and a faster 1200 baud direct connected modem...)  I\u2019m
> tempted to plug it in, and see what happens, but I don\u2019t really need
> will see what\u2019s involved in posting them, if anyone is interested.
> Sorry, don\u2019t know what type of PCB material I would have used at the
> time [g].
> This device replaced a modified IBM Selectric (From a \u201cComputyper\u201d
> \u201cTek-1802\u201d (RCA 1802 cpu, ram, hex keypad, 7 segment displays...)
> I moved on fairly quickly to a hand-built \u201cBig Board\u201d (Z80, 64K RAM,
> surplus!), running CP/M.  Used this for \u201cserious\u201d software development
> fyi,
> Tom Crawford
> *From:* mailto:Homebrew_PCBs@yahoogroups.com
> *Sent:* Friday, March 18, 2016 5:01 PM
> <mailto:Homebrew_PCBs@yahoogroups.com>
> *Subject:* Re: [Homebrew_PCBs] TV Typewriter: Custom G10 copper clad
>> *Sent:* Friday, March 18, 2016 10:35 AM
>> *To:* Homebrew PCBs mailto:Homebrew_PCBs@yahoogroups.com
>> Yeah
>> of the art.
>> with snide remarks.
>> Regards.
>> *From: *"Stefan Trethan stefan_trethan@... [Homebrew_PCBs]"
>> Snip:
>> ST
>> Posted by: "Brad" mailto:unclefalter@...
> Cecil - k5nwa
2016-03-21 by Harvey White
On Sun, 20 Mar 2016 18:29:38 -0700, you wrote:
>Tom,
I did that with my first color TV.  Needless to say, it had a hot
chassis so I borrowed an isolation transformer.
I wanted (and this dates me a lot) a Tektronix programmable
calculator.  I decided to design one, buying surplus ICs from Digikey
(back when they were doing that).  I wired up a data sequencer,
figured out addressing modes, debugged it with my homemade scope
switch ( 74151, homemade D/A and a Tektronix 513D scope).  All
hardwired, all wirewrapped, and it was starting to work.  Built a
display to run with it, sync generator, I think it might have done
color (external NTSC color encoder, but I could be confusing this with
the next incarnation).  190 or so TTL IC's.
Then the 6502 came out for 30 dollars.
I looked at my 190 IC's, and cried a bit,
Next project used the 6502, 8K of EPROM, 2K of RAM, color display,
ASCII keyboard, home programmed monitor with lots of features.
All wire wrap, I might add, far easier for me to do than PC boards.
Now,with microcontrollers with 256K of flash memory, 16K of internal
RAM, running at 32 Mhz or better, with all the peripherals inside....
You younger guys (first time I ever said that) don't know what you
missed.
Harvey
>(Another) Harvey
>> boards.
>> Sitting next to it on the table is a home-made \ufffdPennywhistle\ufffd 300 baud
>> entire CT-1024, and it\ufffds keyboard!  (The modified TV and Pennywhistle
>> CCTV monitor, and a faster 1200 baud direct connected modem...)  I\ufffdm
>> tempted to plug it in, and see what happens, but I don\ufffdt really need
>> will see what\ufffds involved in posting them, if anyone is interested.
>> Sorry, don\ufffdt know what type of PCB material I would have used at the
>> time [g].
>> This device replaced a modified IBM Selectric (From a \ufffdComputyper\ufffd
>> \ufffdTek-1802\ufffd (RCA 1802 cpu, ram, hex keypad, 7 segment displays...)
>> I moved on fairly quickly to a hand-built \ufffdBig Board\ufffd (Z80, 64K RAM,
>> surplus!), running CP/M.  Used this for \ufffdserious\ufffd software development
>> fyi,
>> Tom Crawford
>>> Also on the original front \ufffd I don\ufffdt think anyone harboring an
>>> that\ufffds why I\ufffdm not holding my breath there.
>>> Yeah
>>> of the art.
>>> with snide remarks.
>>> Regards.
>>> Snip:
>>> ST
>> Cecil - k5nwa
2016-03-21 by Jean-Paul Louis
This reminds me of my first modem (circa 1985). It was not fast but it worked at the time to connect to the university network.
https://www.dropbox.com/s/oep8dni17dgg2fa/acoustic-modem-early-80-40343864.jpg?dl=0
Jean-Paul
N1JPL
> On Mar 20, 2016, at 9:29 PM, Harvey Altstadter hrconsult@cox.net [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
> Tom,
> Your description of the modified TV for use as a monitor triggered my memory.  Although I didn't build the TVT, I used the  handbook to modify a small screen TV for use as a monitor.  Yes, it had a hot chassis.  I used it with a computer board that I read about in Radio Electronics. The CPU was the Signetics 2650. I bought the board from Central Data and stuffed it myself. It came with the ROM listings in a poorly printed book.  I manually programmed a 4K X 8 PROM. Much to my amazement, got through it with no errors and the computer worked.  I remember one quirk of the monitor.  Alternating lines of text angled to the left and right.  I wanted to troubleshoot the system, expecting that there were some sync issues, but with the monitor having a hot chassis, and the scope having a grounded chassis, I didn't try.  The board came with a version of BASIC on an audio cassette. That was loaded from a modified audio tape player.  Soon enough, the system was replaced by a Commodore 64, and the 2650 board relegated to long term storage bin in the sky.
> (Another) Harvey
>> fyi,
>> Tom Crawford
>> From: mailto:Homebrew_PCBs@yahoogroups.com
>>> Yeah
>>> of the art.
>>> Regards.
>>> From: "Stefan Trethan stefan_trethan@... [Homebrew_PCBs]" mailto:Homebrew_PCBs@yahoogroups.com
>>> Snip:
>>> ST
>> Cecil - k5nwa
2016-03-21 by Brad
That is really neat.  My CT1024 looks more like the ones you see in google images.  The keyboard has black keys.
That note from Don Lancaster is fantastic!
Sent: Sunday, March 20, 2016 8:49 PM
To: 'Jeff Heiss' jeff.heiss@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com>
Jean-Paul
N1JPL
> On Mar 20, 2016, at 9:29 PM, Harvey Altstadter hrconsult@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
> Tom,
> (Another) Harvey
>> fyi,
>> Tom Crawford
>>> Yeah
>>> of the art.
>>> Regards.
>>> Snip:
>>> ST
>> Cecil - k5nwa
2016-03-21 by casy_ch@tbwil.ch
Oh yes! Mine had to be fixed with a velcro tape to the telephone
earphone, 75 and 300 Baud.
Jean-Claude, HB3YDH
Am 21.03.2016 um 04:48 schrieb Jean-Paul Louis louijp@...
[Homebrew_PCBs]:
> Jean-Paul
> N1JPL
Aargh! You reminded me of my first encounter with the time sharing
service that our company contracted with in the 70's. Dial up, 300 baud,
acoustic coupler. I/O was a KRS 33 Teletype.  No operating system, just
a Monitor.  I am convinced that that situation caused many of our
employees to be wary of the PCs when we finally got them.  That time
sharing system was so gruesome that it scared people away from wanting
to use computers.
(Another) Harvey
On 3/21/2016 12:30 AM, 'casy_ch@...' casy_ch@...
> Jean-Claude, HB3YDH
> [Homebrew_PCBs]:
>> Jean-Paul
>> N1JPL
2016-03-21 by Brad Thompson
On 3/21/2016 1:45 PM, Harvey Altstadter hrconsult@...
> baud, acoustic coupler. I/O was a KRS 33 Teletype.  No operating
> system, just a Monitor.  I am convinced that that situation caused
> many of our employees to be wary of the PCs when we finally got them.
> That time sharing system was so gruesome that it scared people away
> from wanting to use computers.
Hello--
Gruesome, indeed. One advisory message on our primitive 1970s-era
time-sharing system read, "Changes not saved. OK?"
73--
Brad  AA1IP
2016-03-21 by keith printy
I remember that back in high school. I believe it was through compuserve , which is now owned by AOL
Sent: Monday, March 21, 2016 2:17 PM
Hello--
73--
Brad AA1IP
2016-03-22 by Harvey Altstadter
Our system was pre CompuServe. It was a mainframe located at another
aerospace contractor located several miles away.  I remember that the
system monitor used a question mark for the prompt.  It was very
frustrating.  You would type in a line of code, and instead of getting a
result, you got back a question mark.  There were no error messages, and
only a few system messages.  Once, one of the guys go so frustrated that
he typed in HELP.  He didn't realize that that was a reserved word.  The
teletype sprung to life in a manner not often seen.  The message that
came back was- System operator notified... Help is on the way.  The
cavalry did not, however, come up over the hillside.
On 3/21/2016 4:14 PM, 'keith printy' keethpr@...
> *Sent:* Monday, March 21, 2016 2:17 PM
> <mailto:hrconsult@...>
> Hello--
> 73--
> Brad AA1IP
