Homebrew PCBs
images for photoresist
2016-04-12 by Jeff Heiss
I'm using laser transparencies for photoresist boards and I would like to
test a real photographic film image.  I understand real film has solid black
this is excellent at blocking light.  Can anyone suggest a type of place
that can do photonegatives from a .jpg or .bmp?  Can a CVS or Riteaid do
this?
Jeff
Re: [Homebrew_PCBs] images for photoresist
2016-04-12 by Harvey White
>this?
You want a  professional place, one that does drawings, engineering
prints, and the like.  They're likely to have the ability to make the
image. Photolithographers, for instance.   Riteaid or CVS barely know
how to develop Tri-x Pan.
Harvey
>Jeff
RE: [Homebrew_PCBs] images for photoresist
2016-04-12 by keith printy
That is simple to develop.i haven't done it in a while but it was d76
developer , stop bath and fixer . you have to work in total dark until the
fixer. If the size is 8 by 10 you could put it in a photo processing drum
and let a motor do it for you. You would just need to drain the chemicals at
the proper time.
A friend of mine used to do it with lithograph film . I don't think it was
as touchy and it could be handled under a yellow light if I recall.
From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com]
Sent: Tuesday, April 12, 2016 5:24 PM
Subject: Re: [Homebrew_PCBs] images for photoresist
>this?
Harvey
>Jeff
2016-04-13 by Andrew Volk
I did a bit of this in my college days.  We used orthographic film
(Kodalith, I think) that was not sensitive to reds and had very high
contrast.  It was fairly easy to use for me and give great results.  I made
contact prints from mylars taped with Bishop tapes and pad layouts.  I used
it under a ruby light with a carbon filament.  (Something my Dad had in his
basement photo area, along with an old enlarger and developing trays.)  Ahh!
The good old days.
Andy
Sent: Tuesday, April 12, 2016 4:23 PM
Subject: RE: [Homebrew_PCBs] images for photoresist
the proper time.
From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew! _PCBs@yahoogroups.com]
>this?
how t! o develop Tri-x Pan.
Harvey
>Jeff
2016-04-13 by Harvey White
>contrast.
It was kodalith.  It may no longer be available.  You had a two part
developer that was used to give you that almost step contrast.  If you
developed it in Dektol it would give you a gray scale.
>The good old days.
You forgot the 8x10 view camera....
This gave you a negative, and you had to use that with something like
Kodak KPR... nasty stuff.
Harvey
>Andy
>the proper time.
>>this?
>Harvey
>>Jeff
>the proper time.
Kodak Kodalith, 2 part developer, stop and fixer.  Red light is fine.
gave almost a complete black and complete transparent, wonderful
stuff.  However, there were two types, the line and the dot.  Dot was
used for newspaper photographs, and line is what you wanted.
Harvey
>>this?
>Harvey
>>Jeff
No view camera for my work, just direct contact printing.  When I left
college and went into the electronics business, then there were rubyliths
(red cellophane image on a heavy mylar base) and the view camera was a room.
The rubylith was hung against a wall-sized light board and the camera was
mounted in an opposite wall.  The reduction of size was about 20:1, but the
whole process was essentially the same to get a master image.  That was
stepped down again 10:1 and step and repeated for a whole wafer full of
images used to make integrated circuits.  Mind you that was mid to late
1970's.  The process has changed a lot since then.
Sent: Tuesday, April 12, 2016 6:30 PM
>contrast.
>The good old days.
Harvey
>Andy
at
>the proper time.
black
>>this?
>Harvey
>>Jeff
Re: images for photoresist
2016-04-13 by cs6061@...
Way back in my hand taping days before CAD layout tools, we would lay a board out using Mylar film, ruby tape and Bishop dip and doughnut pads. This was done at 2:1 then sent to an industrial photo house to be reduced 2:1 on lito-film. IIRC it was about $20 to $50 for a set of negatives and more if you wanted a set of contact positives. I saved some cost at home by doing my own contact positives. Making the contact prints was fairly easy -- just a couple pieces of glass to clamp the films together, a darkroom safe light, some slow litho-film, developer and fixer. Took around 20 minutes to do the entire process. The positives were used with boards spin coated with Shipley AZ111 positive resist, exposed then etched. Turn around for the photo house was 24 hours but you could pay for 1 hour service if you were in a rush. Eventually all the photo houses switched over to laser plotters once PCB CAD systems became available. Even the photo plotting houses went by the way side once the PCB fabricators started to accept digital Gerber input files.
You can still buy litho-film, the developer and fixer from places like Freestyle Photographic Supplies. Though the web site seems to be down. The ideal thing would be to build your own photo plotter
Criag
Re: [Homebrew_PCBs] Re: images for photoresist
There were two ways of doing this.  One was to use black donuts and
black crepe paper tape.  This would work well with one sided boards.
The other method was to use the black crepe for the pads, and then red
transparent and blue transparent tape for the other layers.  Red tape
could be shot with Kodalith, because it was sensitive to blue only and
red was no light (hence opaque).  Blue tape was shot with panchromatic
film with a red filter (making the blue drop out).  Panchromatic film
was sensitive to all colors.
And it took a bit to get there.  Good computers and all sorts of
stuff.
Or do toner transfer, or send out to China for the boards, etc....
Main problem is the sensitized board, which can be a bit dear.
Harvey
>Criag
