Homebrew PCBs
Amount of etchant needed
2016-05-27 by Brad
Hi guys,
So, I think I may have found some much cheaper single side G10 boards in the
color I want.  I ordered a bunch from here based on photos and the seller's
(slightly language inhibited) response on colour.  They described it as
between green and brown, which seems like 'natural' to me.
http://www.ebay.ca/itm/150846166149?_trksid=p2057872.m2749.l2648
<http://www.ebay.ca/itm/150846166149?_trksid=p2057872.m2749.l2648&ssPageName
=STRK%3AMEBIDX%3AIT> &ssPageName=STRK%3AMEBIDX%3AIT
On arrival, I was initially concerned it was just another shade of brown.
But looking around the very edges of the boards where there is no copper, it
does indeed look green.  I'm assuming the copper on one side is sort of
providing the illusion of a different color.
Anyway, my question here - I have to order etchant now (can't find any sold
around here) - if I have 5 boards of around 8"x9" to do.. how much etchant
do I need?  Is the etching solution via 'bath' method pretty much one board
per go?  Or can the same solution be used multiple times?
Brad
Re: Amount of etchant needed
2016-05-27 by me@...
There is no need to order echant. Go to the hardware store and buy a bottle of muriatic acid, peroxide at the grocery. 2 parts hydrogen peroxide and 1 part muriatic acid. Always add the acid to the peroxide to prevent splashing. Wear gloves and eye protection. Use is a well ventilated area.
The mixture is clear so it is easy to see when the etching is done. Mix enough to cover the board. Toss it when your are done as it is very cheap. Don't poor down the drain. Makes a great cleaner for sidewalk stains. Cut with some water.
RE: [Homebrew_PCBs] Re: Amount of etchant needed
2016-05-28 by Brad
Yeah I remember muriatic acid – used to use it to clean our pool.  That was seriously nasty stuff – I’m a bit uneasy about bringing it back into my life.  That’s why I was thinking etchant.  I can’t remember – you *can* pour it into a standard plastic tub right?
From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com]
Sent: Friday, May 27, 2016 4:33 PM
Subject: [Homebrew_PCBs] Re: Amount of etchant needed
Re: [Homebrew_PCBs] Re: Amount of etchant needed
2016-05-28 by Harvey White
On Fri, 27 May 2016 18:32:09 -0700, you wrote:
>Yeah I remember muriatic acid \ufffd used to use it to clean our pool.  That was seriously nasty stuff \ufffd I\ufffdm a bit uneasy about bringing it back into my life.  That\ufffds why I was thinking etchant.  I can\ufffdt remember \ufffd you *can* pour it into a standard plastic tub right?
Yes, and it's generally mixed one part HCL with 4 parts of drugstore
peroxide.  Pour the acid into the peroxide.  Works wonders, watch
because it can be quick.  Then you need to heat it and bubble air into
it once the peroxide goes.
FeCL3 is nastier, it's almost the same stuff and stains
enthusiastically.
Harvey
2016-05-28 by Dave Wade
Why do they insist on giving it multiple names, its Hydrochloric Acid , in Spain it’s called Agua Fuerte and its noxious stuff. I think I slightly prefer Ferric Chloride but only slightly… You really need a fume cupboard or to use outside.
Dave
Sent: 28 May 2016 02:32
Subject: RE: [Homebrew_PCBs] Re: Amount of etchant needed
From: Homebrew_PCBs@yahoogroups.com <mailto:Homebrew_PCBs@yahoogroups.com>  [mailto:Homebrew_PCBs@yahoogroups.com]
To: Homebrew_PCBs@yahoogroups.com <mailto:Homebrew_PCBs@yahoogroups.com>
2016-05-28 by Bill Maxwell
and oddly enough, muriatic acid (and peroxide) is an etchant.
enthusiastically.
Harvey
Posted by: Harvey White
Be sure to visit the group home and check for new Links, Files, and Photos:
http://groups.yahoo.com/group/Homebrew_PCBs
Yahoo Groups Links
<*> To visit your group on the web, go to:
    http://groups.yahoo.com/group/Homebrew_PCBs/
<*> Your email settings:
    Individual Email | Traditional
<*> To change settings online go to:
    http://groups.yahoo.com/group/Homebrew_PCBs/join
    (Yahoo! ID required)
<*> To change settings via email:
    Homebrew_PCBs-digest@yahoogroups.com
    Homebrew_PCBs-fullfeatured@yahoogroups.com
<*> To unsubscribe from this group, send an email to:
    Homebrew_PCBs-unsubscribe@yahoogroups.com
<*> Your use of Yahoo Groups is subject to:
    https://info.yahoo.com/legal/us/yahoo/utos/terms/
On Sat, 28 May 2016 09:13:40 +0100, you wrote:
>Why do they insist on giving it multiple names, its Hydrochloric Acid , in Spain it\ufffds called Agua Fuerte and its noxious stuff. I think I slightly prefer Ferric Chloride but only slightly\ufffd You really need a fume cupboard or to use outside.
The older name is likely derived from popular sources, perhaps the use
of the acid in alchemy.  The name aqua regia (Nitric and hydrochloric
acids) was named such because it dissolved the "royal" metals such as
gold and platinum).
and I do all the etching outside, anyway.  HCL mixtures or ferric
chloride.
Harvey
>Dave
2016-06-10 by lists
In article <02fb01d1b8b8$d85b9970$8912cc50$@...>,
   'Dave Wade' dave.g4ugm@... [Homebrew_PCBs]
<Homebrew_PCBs@yahoogroups.com> wrote:
> Hydrochloric Acid
That is it's proper chemical name, recognised by Chemists all over the
world. Others are historic or local names.
Stuart Winsor
Tools With A Mission
sending tools across the world
http://www.twam.co.uk/
2016-06-10 by Donald H Locker
Muriatic acid is hydrochloric acid at a particular concentration (20-30%. IIRC); purity is not particularly important for many applications, and may not be guaranteed in hardware store supplies.
Donald.
> From: "lists Stuartlists@... [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com>
> To: "Homebrew PCBs" <Homebrew_PCBs@yahoogroups.com>
> Sent: Friday, June 10, 2016 5:05:46 AM
> Subject: Re: [Homebrew_PCBs] Re: Amount of etchant needed
> > Hydrochloric Acid
> Stuart Winsor
