Homebrew PCBs
Etching with vinegar, peroxide and salt
2016-06-19 by Brad
Stumbled across this method while reading up on etching.  I'm still waiting
on my ferric chloride, which you cannot buy around here.
Anyway, the procedure is 'simply' mix cleaning vinegar (higher acid
concentration than regular vinegar) and peroxide at 1:1 and let her rip,
adding table salt to speed up up or maintain the reaction.
Here's a few pics of the process:
http://s1381.photobucket.com/user/unclefalter/media/Mobile%20Uploads/2016061
8_145928_zpsyjqawclk.jpg.html
Further along:
8_165549_zpsrgxs32nq.jpg.html
And almost done:
8_170642_zpso2duc8vd.jpg.html
In terms of how it worked.. not bad. kind of slow.  On my first PCB, I made
a batch of 'etchant' from peroxide and regular vinegar and dumped it in.  I
thought it had to keep bubbling to work, so I kept adding salt.. but I think
I killed the reaction.  I then went out and bought the more powerful
cleaning vinegar, took the board out (it had been sitting in that first bath
for about 1.5hrs) drained the old solution, then put in a new batch, again
1:1 with the more powerful vinegar.  The board upon removal had little bits
of green PCB showing but there was still tons of copper, in a finish that is
sort of like what rusty pennies get when you put them in cola.  I put the
board back in.. wow. that remaining copper really began to disappear fast.
I also put the whole thing in my laundry tub and put a few inches of hot
water under while gently rocking it back and forth.  That's how it got to
the state shown in the third picture.
I'm not sure why, but there were some stubborn parts where the original
shiny copper was still holding out.  I poured a bit of salt onto those spots
and it seemed to help get things moving.
Anyway, off to try to finish it.. if anyone out there has more tips on this
method I'm all ears.  I like that it's a lot less nasty than ferric, etc.
Re: [Homebrew_PCBs] Etching with vinegar, peroxide and salt
2016-06-19 by James
Quinn Dunki etches like that, she gets pretty good results, slow, but I guess you know what they say about winning the race.
On Sun, Jun 19, 2016 at 12:29 PM, 'Brad' unclefalter@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
Stumbled across this method while reading up on etching. I’m still waiting on my ferric chloride, which you cannot buy around here.
Anyway, the procedure is ‘simply’ mix cleaning vinegar (higher acid concentration than regular vinegar) and peroxide at 1:1 and let her rip, adding table salt to speed up up or maintain the reaction.
Here’s a few pics of the process:
http://s1381.photobucket.com/user/unclefalter/media/Mobile%20Uploads/20160618_145928_zpsyjqawclk.jpg.html
Further along:
http://s1381.photobucket.com/user/unclefalter/media/Mobile%20Uploads/20160618_165549_zpsrgxs32nq.jpg.html
And almost done:
http://s1381.photobucket.com/user/unclefalter/media/Mobile%20Uploads/20160618_170642_zpso2duc8vd.jpg.html
In terms of how it worked.. not bad… kind of slow. On my first PCB, I made a batch of ‘etchant’ from peroxide and regular vinegar and dumped it in. I thought it had to keep bubbling to work, so I kept adding salt.. but I think I killed the reaction. I then went out and bought the more powerful cleaning vinegar, took the board out (it had been sitting in that first bath for about 1.5hrs) drained the old solution, then put in a new batch, again 1:1 with the more powerful vinegar. The board upon removal had little bits of green PCB showing but there was still tons of copper, in a finish that is sort of like what rusty pennies get when you put them in cola. I put the board back in.. wow… that remaining copper really began to disappear fast. I also put the whole thing in my laundry tub and put a few inches of hot water under while gently rocking it back and forth. That’s how it got to the state shown in the third picture.
I’m not sure why, but there were some stubborn parts where the original shiny copper was still holding out. I poured a bit of salt onto those spots and it seemed to help get things moving.
Anyway, off to try to finish it.. if anyone out there has more tips on this method I’m all ears. I like that it’s a lot less nasty than ferric, etc.
RE: [Homebrew_PCBs] Etching with vinegar, peroxide and salt
2016-06-19 by Brad
It definitely works.  I’m just not sure how.  The various sites say the salt just ‘speeds up’ the process.  But if you just leave the boards in peroxide and vinegar, nothing really happens.  The salt seems to be the key.  I just pour a bit over un-etched areas and it goes nuts.  However on my first board, I’m thinking either the table vinegar I was using was too weak, or too much salt.. eventually the process just stopped working.
From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com]
Sent: Saturday, June 18, 2016 5:36 PM
To: Homebrew PCBs <Homebrew_PCBs@yahoogroups.com>
Subject: Re: [Homebrew_PCBs] Etching with vinegar, peroxide and salt
http://quinndunki.com/blondihacks/?p=835
On Sun, Jun 19, 2016 at 12:29 PM, 'Brad' unclefalter@... <mailto:unclefalter@yahoo.ca>  [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com <mailto:Homebrew_PCBs@yahoogroups.com> > wrote:
Further along:
And almost done:
2016-06-19 by duwaynes@...
One explanation I was given is that the vinegar reacts with the chloride in salt and produces a very weak hydrochloric acid. I tried it but it took forever to see any effect on the copper. Much easier to go and get a gallon of muriatic acid for $10. I only use about an ounce at a time along with 3 oz of peroxide and get boards etched in about 5 minutes.
2016-06-19 by Brad
Yeah.  I just have a hesitancy about muriatic, remembering some accidental burns years ago. :)  I accidentaly splashed a bit of this vinegar stuff on my hand in a moment where I forgot to put on gloves and nothing happened.  That kind of thing with muriatic would be very bad.  It etches beautifully – just really slow.
Sent: Sunday, June 19, 2016 9:02 AM
Subject: RE: [Homebrew_PCBs] Etching with vinegar, peroxide and salt
2016-06-19 by Stefan Trethan
It's all a matter of concentration. You don't need all that high a concentration to etch, and you got hydrochloric acid in your stomach after all...
ST
On Sun, Jun 19, 2016 at 6:57 PM, 'Brad' unclefalter@yahoo.ca [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
Yeah. I just have a hesitancy about muriatic, remembering some accidental burns years ago. J I accidentaly splashed a bit of this vinegar stuff on my hand in a moment where I forgot to put on gloves and nothing happened. That kind of thing with muriatic would be very bad. It etches beautifully – just really slow.
2016-06-19 by keith printy
Have you thought about using acetic acid ? isn’t that what vinegar actually is ?
I have glacial acetic here ,it is used for darkroom work. Stop bath is basically the same thing except it has indicator in it so you know when it goes bad I used to stick my fingers in it all the time when printing photo’s . it freezes at about 62 degrees I think ,so watch where you store it. The glacial you can water down to whatever strength you need ,stop bath you also water down. It comes in a small plastic bottle and you add a certain amount to like a half gallon of water . think the mix is only a couple ounces to half a gallon!
Sent: Sunday, June 19, 2016 12:58 PM
2016-06-19 by <n0tt1@...>
I'd like to do that as well with the Muratic...question is what
does one DO with the spent etch?  Might not be so good
in a septic tank IF that is permitted to pour the stuff down
the drain.  Just asking...
Charlie
On 19 Jun 2016 09:01:49 -0700 "duwaynes@... [Homebrew_PCBs]"
<Homebrew_PCBs@yahoogroups.com> writes:
2016-06-19 by Brad
What I’ve got seems to work fairly well – I think the only area I’m suffering is not understanding the process, and the relationship between the vinegar and salt and the peroxide.  Today I put in a full 500ml bottle of peroxide and then dumped what was left of my cleaning vinegar in – I think it was close but not quite 1:1.. and that mixture went crazy on the board and did a perfect job.  However, the board I put in was half the size of the previous.. so maybe the amount of copper present has an impact also.  I put a bit of salt in and it just fizzed and fizzed away.
Without a doubt it works.. the goal here was a) to be safer and b) avoid relying on things that are difficult or impossible to by in my silly small town.
Another thing I found helps per Quinn’s site is the foam brush on the board while it’s in the bath.
Side note: I’m glad I didn’t go with those $400 custom made PCBs I was thinking about.. I dissolved a piece of their sample in my etchant and the green of the fiber was nowhere near what it looked like in pictures.  In fact, these cheapo Chinese boards were far closer.
Brad
Sent: Sunday, June 19, 2016 12:31 PM
From: Homebrew_PCBs@yahoogroups.com <mailto:Homebrew_PCBs@yahoogroups.com>  [mailto:Homebrew_PCBs@yahoogroups.com]
To: Homebrew_PCBs@yahoogroups.com <mailto:Homebrew_PCBs@yahoogroups.com>
2016-06-19 by Harvey White
On Sun, 19 Jun 2016 14:54:56 -0700, you wrote:
>What I\ufffdve got seems to work fairly well \ufffd I think the only area I\ufffdm suffering is not understanding the process, and the relationship between the vinegar and salt and the peroxide.  Today I put in a full 500ml bottle of peroxide and then dumped what was left of my cleaning vinegar in \ufffd I think it was close but not quite 1:1.. and that mixture went crazy on the board and did a perfect job.  However, the board I put in was half the size of the previous.. so maybe the amount of copper present has an impact also.  I put a bit of salt in and it just fizzed and fizzed away.
The standard mix is hydrochloric acid (hydrogen ions and chlorine
ions), and then a lot of oxygen (H2O2, hydrogen peroxide) decomposes
into water and oxygen.
Acetic acid (no idea of the formula), decomposes into hydrogen ions
and acetate ions (probably wrong name).
Salt (NaCl) decomposes in water (or at least makes available) Sodium
ions (Na+) and chlorine ions (CL-).
Turns out that the sodium ions are probably ignored, the acetate ions
are ignored, (and if they're not, IIRC most acetates are soluble), and
what you're left with is Hydrogen ions, Chlorine Ions, and Oxygen.
These form the CuCl reaction which is exactly the same that you'd get
from HCL (muriatic acid) and Hydrogen Peroxide.
The difference (in this case) is that the household vinegar (or even
stronger stuff) gives you the strength of hydrogen ions that you'd get
from dilute HCl (muriatic acid).  So if you can't find HCl, then
acetic acid (vinegar/glacial acetic acid, etc...) and salt (Cl- ions)
will substitute.
You're just making the effect of HCl with other household chemicals.
The problem with Muriatic Acid (HCl) is that it's concentrated, and
like all concentrated acids, has to be handled carefully.
Vinegar is of such a low concentration that you can resist it.  (no
pun intended considering PCB work).  It works rather slowly.
Increase the concentration and it works faster.
Faster makes the time  you have between perfect and overetched a bit
more critical.
I've used both Ferric Chloride (which has HCl in it, BTW), and CuCl
(and the precursor, HCl and Peroxide), and I prefer the CuCl/peroxide
mix.
Cheaper.
Does not stain.
Available locally.
Lasts forever.
BTW: Ferric Chloride eventually becomes CuCl, from what I understand.
Harvey
>Another thing I found helps per Quinn\ufffds site is the foam brush on the board while it\ufffds in the bath.
>Side note: I\ufffdm glad I didn\ufffdt go with those $400 custom made PCBs I was thinking about.. I dissolved a piece of their sample in my etchant and the green of the fiber was nowhere near what it looked like in pictures.  In fact, these cheapo Chinese boards were far closer.
>Brad
>Have you thought about using acetic acid ? isn\ufffdt that what vinegar actually is ?
>I have glacial acetic here ,it is used for darkroom work. Stop bath is basically the same thing except it has indicator in it so you know when it goes bad I used to stick my fingers in it all the time when printing photo\ufffds . it freezes at about 62 degrees I think ,so watch where you store it. The glacial you can water down to whatever strength you need ,stop bath you also water down. It comes in a small plastic bottle and you add a certain amount to like a half gallon of water . think the mix is only a couple ounces to half a gallon!
>Yeah.  I just have a hesitancy about muriatic, remembering some accidental burns years ago. :)  I accidentaly splashed a bit of this vinegar stuff on my hand in a moment where I forgot to put on gloves and nothing happened.  That kind of thing with muriatic would be very bad.  It etches beautifully \ufffd just really slow.
2016-06-20 by keith printy
I've seen ferric chloride solidify of try to during etching towards the end
when it gets pretty well saturated with the copper. Ferric chloride to my
understanding is used for sewage treatment to coagulate the solids.
Sent: Sunday, June 19, 2016 6:41 PM
>What I've got seems to work fairly well - I think the only area I'm
peroxide and then dumped what was left of my cleaning vinegar in - I think
will substitute.
more critical.
mix.
Cheaper.
Does not stain.
Available locally.
Lasts forever.
Harvey
town.
>Another thing I found helps per Quinn's site is the foam brush on the board
while it's in the bath.
>Side note: I'm glad I didn't go with those $400 custom made PCBs I was
>Brad
>Have you thought about using acetic acid ? isn't that what vinegar actually
is ?
goes bad I used to stick my fingers in it all the time when printing photo's
half a gallon!
kind of thing with muriatic would be very bad. It etches beautifully - just
really slow.
2016-06-20 by Brad
Thanks guys.  I've now etched 5 boards and am pretty happy with the results:
http://s1381.photobucket.com/user/unclefalter/media/20160619_190537_zpsk5uo6
tan.jpg.html
For me it's just living in a small town, there are certain things you cannot
get.  I can get hydrochloric, but yeah, I'm wary.
Sent: Sunday, June 19, 2016 5:14 PM
will substitute.
more critical.
mix.
Cheaper.
Does not stain.
Available locally.
Lasts forever.
Harvey
town.
>Brad
is ?
half a gallon!
really slow.
2016-06-20 by Harvey White
The CuCl etchant never really gets spent, you just occasionally add
more HCl and bubble air through it to etch.
However, you could neutralize the acid (carefully) with baking soda,
then all you have left are copper salts.
Harvey
>Charlie
I would be more concerned with the copper salts. They put copper in marine paint to prevent organisms from attaching to boats!
Sent: Sunday, June 19, 2016 3:47 PM
Charlie
On 19 Jun 2016 09:01:49 -0700 "duwaynes@... [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com> writes:
2016-06-20 by Les Newell
Don't get it anywhere near a septic tank. Copper is really good at
killing bacteria. Mixing it with cement or dry-mix concrete will
neutralize the acid and tie the copper up in a solid block which can be
disposed of in the bin. If you keep cement in a well sealed container it
will last a long time so one bag will last you for ages.
Les
On 19/06/2016 20:46, n0tt1@... [Homebrew_PCBs] wrote:
> \ufeff
> Charlie
2016-06-20 by <n0tt1@...>
Good advice, Les...thanks!
Charlie
On Mon, 20 Jun 2016 14:19:03 +0100 "Les Newell les.newell@...
Les
Charlie
2016-06-20 by Russell Shaw
On 20/06/16 23:19, Les Newell les.newell@... [Homebrew_PCBs] wrote:
> Don't get it anywhere near a septic tank. Copper is really good at killing
> bacteria. Mixing it with cement or dry-mix concrete will neutralize the acid and
> tie the copper up in a solid block which can be disposed of in the bin. If you
> keep cement in a well sealed container it will last a long time so one bag will
> last you for ages.
It makes excellent weed killer.
