Homebrew PCBs
Reversing art work without Orange Dry Peel Negative Film
2016-11-10 by g8kps@...
Hi all,
I'm normally just lurking but I thought I would share this tip. I had run out Orange Dry Peel Negative Film, the solution I found was to use Photosensitive Dry Film on some laser drafting film the only problem I had was to find the correct temperature on my laminator which terned out to be a lot lower than I use for copper clad board. there's is no need to stock "Orange Dry Peel Negativ film" and its cheep.
This all came about as a friend asked me to eatch some some brass name plate for his 2" traction engine as he new I make my own PCB,s. Not a problem I thought, well I used Photosensitive Dry Film on the brass sheet, as the brass was rather thick I had to tern up the temperature on my laminator to get good adhesion.
SHARPIE PERMANENT MARKER ETCH TEST
2016-11-12 by Rob
I had been getting very mixed results with ARTLINE 70 HIGH PERFORMANCE
permanent markers
and SHARPIEs were drying out too fast for me so I tried other SHARPIE
products called EXTREME FADE RESISTANT and  INDUSTRIAL SUPER PERMANENT
INK..........and a generic marker called CASEMATE.
http://www.learnmorsecode.com/laminator/etch/index.html
Difinitely concluded there was differences enough to avoid BLUE and
GREEN and CASEMATE
Re: SHARPIE PERMANENT MARKER ETCH TEST
2016-11-12 by tasmod@...
Excellent test. I did something similar and was amazed at some results.
I now use a black 'Laundry marker' available here in the UK from W H Smiths a newsagents chain store.
It works quite well but as with all of the markers you cannot over etch. It is reminiscent of the Dalo PCB pen in that the light tracks look multicoloured under certain light conditions. (Oh how I miss the Dalo pen ! )
For the US folks maybe something similar is available.
Rob G4NQX
Re: SHARPIE PERMANENT MARKER ETCH TEST finer lines
2016-11-12 by Rob
I was hoping to find a marker that could leave a finer line.
I am getting a real fat line with a sharpie.
So I was hoping a new sharpie might leave enough inck for a thinner line.
This is too fat for DIP pins:
http://www.learnmorsecode.com/laminator/pic/PIC16F628PROTO8d.jpg
It works but is tight.
http://www.learnmorsecode.com/laminator/hotcakes.html
On 11/12/2016 06:54 AM, AncelB mosaicmerc@... [Homebrew_PCBs] wrote:
> You need to use Silver Sharpies and make sure the ink is dry.
2016-11-12 by alan00463@...
I got a package of five "Sharpie Precision" precision markers from Staples. Also marked "Ultra Fine". The package contained two black markers. The other ones were green, blue, and red.
The black marker draws a line 1/60 in. wide,, or 17 mil.
Heating season has begun, so today I started boiling water to add moisture to the air.
HTH,
Alan
Re: [Homebrew_PCBs] Re: SHARPIE PERMANENT MARKER ETCH TEST finer lines DOES IT ETCH
2016-11-12 by Rob
DOES IT ETCH
does it leave enough ink on the PCB to leave copper traces after etching?
Could you draw an 8 pin SMT landing pad with it?
> HTH,
> Alan
2016-11-13 by Brad Thompson
Hello--
At the risk of revealing the era in which I learned technical drawing
(*), how about using an erasing shield?
http://drawsketch.about.com/od/materials/ss/erasershield.htm
The online auction site lists a bunch of sources for $.99 on up...
252478256009
(Usual disclaimers apply.) Also, I haven't tried this due to displacement of
my drafting kit<g>.
In theory, the marker ink shouldn't spread under the shield and smear,
but if
so, applying some tape on the under side to raise the shield off the
copperclad
might work.
73--
Brad  AA1IP
(*) I worked on the crew that invented Fire....<g>
On 11/12/2016 10:38 PM, roylowenthal@... [Homebrew_PCBs] wrote:
> What's wrong with erasing shields? I still occasionally use one & just
> showed SWMBO the benefits of an Opaline bag for a pencil sketching class
> she's taking on line.
Hello, Roy and the group--
Nothing, really-- In response to Bob Roomberg's experiments with marker pens
as dispensers of resist for PC-board paths, an erasing shield might
serve as a
"mask" or template for creation of uniform traces on handmade boards.
Press the shield to the copperclad, drag a marking pen over the
appropriate opening in the shield, and you *might* have straighter and
better-looking traces.
As for the Opaline bag, I think there's one in my supplies cabinet,
along with a motor-driven eraser that can chew its way through a sheet
of paper in no time at all if
carelessly used<g>.
73--
Brad  AA1IP
SHARPIE PERMANENT MARKER ETCH TEST finer lines SEARCH FOR THE RIGHT MARKER
2016-11-13 by Rob
I had 6 years of drafting.
4 in high school and 2 after high school.
I have drawn houses, office buildings, hospitals, solar houses....
footings to shingles
and then
one day in 1981  I saw a house get drawn on an IBM PC .. a 286......
every stick of lumber....
in about two minutes. I knew right then that computers would take the
jobs away from a pencil pushing
draftsmen like me ....
so thats when I joined the dark side... and pursued a computer
programming career.
I am not opposed to the idea of using an eraser shield
BUT
it is not the goal to use fat markers as much as it is the goal to find
a VERY thin marker that
does have the right chemistry to draw an SMT pad and hairline copper traces.
AND
since there are more than one permanent marker companies like SHARPIE
and ARTLINE
I just figured I would share results of my experiments and if any of you
guys do find a fine line marker with
resistance to acid etching solutions then shout it out here.
On 11/12/2016 11:31 PM, Brad Thompson brad.thompson@...
> marker pens
> serve as a
> carelessly used<g>.
> 73--
> Brad AA1IP
RE: [Homebrew_PCBs] Re: SHARPIE PERMANENT MARKER ETCH TEST finer lines
2016-11-13 by Dave Wade
I believe that some of the Staedtler waterproof markers were reasonably etch resistant, may not be this exact one..
https://www.staedtler.co.uk/en/products/markers-refill-ink/universal-pens/lumocolor-permanent-pen-313-permanent-universal-pen-s/
some folks sell these as etch resist on E-Bay..
http://www.ebay.co.uk/itm/121477899315
but they are available with fine tips.
Dave
These are what folks used to recommend
> From: Homebrew_PCBs@yahoogroups.com
> [mailto:Homebrew_PCBs@yahoogroups.com]
> Sent: 13 November 2016 00:49
> To: Homebrew_PCBs@yahoogroups.com
> Subject: Re: [Homebrew_PCBs] Re: SHARPIE PERMANENT MARKER ETCH
> TEST finer lines
> Hello--
> At the risk of revealing the era in which I learned technical drawing (*), how
> 252478256009
> (Usual disclaimers apply.) Also, I haven't tried this due to displacement of my
> drafting kit<g>.
> In theory, the marker ink shouldn't spread under the shield and smear, but if
> copperclad might work.
> 73--
> Brad  AA1IP
> Posted by: Brad Thompson <brad.thompson@...>
> http://groups.yahoo.com/group/Homebrew_PCBs
> Yahoo Groups Links
2016-11-13 by Rob
THANK YOU for the suggestion.
I'll have them here in a few days.
http://www.ebay.com/itm/262038010827
On 11/13/2016 03:48 AM, 'Dave Wade' dave.g4ugm@... [Homebrew_PCBs]
> Dave
> > TEST finer lines
> thinner line.
> > Hello--
> drawing (*), how
> > 252478256009
> displacement of my
> > drafting kit<g>.
> smear, but if
> > 73--
> > Brad AA1IP
> Photos:
> > Yahoo Groups Links
2016-11-14 by Craig Martin
The staedtler lumocolor permanent pen 313 permanent (RED)  0.4 line works for me
The black didn't work in ferric chloride
Craig VK2ZCM
  Sent: Sunday, November 13, 2016 8:27 PM
  Subject: Re: [Homebrew_PCBs] Re: SHARPIE PERMANENT MARKER ETCH TEST finer lines
    Dave
    > TEST finer lines
    > Hello--
    > 252478256009
    > drafting kit<g>.
    > 73--
    > Brad AA1IP
    > Yahoo Groups Links
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
2016-11-14 by Rob
I'm using 50 ml muriatic acid mixed with 100 ml hydrogen peroxide......
both are 30% and 70% water. Standard hardware store $4 pool acid and
drug store $3 peroxide.
  Nothing exotic about this stuff.
On 11/13/2016 10:00 PM, 'Craig Martin' jennyandcraig01@...
> \ufeff
> works for me
> Regards
> Craig VK2ZCM
>     ----- Original Message -----
>     *From:* Rob roomberg@... [Homebrew_PCBs]
>     <mailto:roomberg@...%20[Homebrew_PCBs]>
>     *To:* Homebrew_PCBs@yahoogroups.com
>     <mailto:Homebrew_PCBs@yahoogroups.com>
>     *Sent:* Sunday, November 13, 2016 8:27 PM
>     *Subject:* Re: [Homebrew_PCBs] Re: SHARPIE PERMANENT MARKER ETCH
>     TEST finer lines
>>     Dave
>>     > TEST finer lines
>>     thinner line.
>>     > Hello--
>>     drawing (*), how
>>     > 252478256009
>>     displacement of my
>>     > drafting kit<g>.
>>     smear, but if
>>     off the
>>     > 73--
>>     > Brad AA1IP
>>     and Photos:
>>     > Yahoo Groups Links
>     Avast logo <https://www.avast.com/antivirus>
>     www.avast.com <https://www.avast.com/antivirus>
2016-11-15 by roylowenthal@...
Has anybody tried using a technical pen & one of the water resistant inks meant for drafting on film?
< https://en.wikipedia.org/wiki/Technical_pen >
Roy
2016-11-15 by Dave Sage
Yes. I used them for a couple of years and even installed them in my Roland
plotter to plot circuit boards. They did an excellent job (if you were
lucky) and if the correct ink is used it is VERY resistant to etch. This was
my only method of making boards during that time. But then I got a laser
printer and abandoned the plotter and ink method in favor of toner transfer.
I would never go back and quite frankly I'm not sure why anyone is
considering going back to markers and technical pens when toner transfer
works so well.
   The technical pens and plotter were simply a pain in the butt. I was
using the smallest ones available (0.3mm I believe) and they had to be taken
apart and cleaned after every use. There was an extremely fine wire inside
used as an ink release valve and it was sure to get bent when dis-assembled.
The pens required special cleaner to dissolve the ink. The pens frequently
skipped when used on copper (rather than paper as intended).
 For what it's worth Eagle can still generate plot files for the Roland
plotters but the plotters require a parallel port (rare these days) and
drivers for same AFAIK do not exist for the plotters any more.
 Forget the markers etc. and use toner transfer, it's cheap and easy.
SHARPIE PERMANENT MARKER ETCH TEST FOR TOUCHUP NOT PLOTTING
2016-11-15 by Rob
My goal here with SHARPIES is for touchup...adding anything that didn't TONER transfer properly..... not plotting.
I've gotten pretty consistent results with toner transfer.... but an oddball missing pad or trace once in a while.
So I thought it would be good to figure out once and for all what permanent marker works.
I used drafting pens for years.... for drafting.
I would clean them weekly.... take them apart\ufffd and use an ultrasonic ring cleaner.....
which will unclog dried ink.
On 11/15/2016 07:06 AM, 'Dave Sage' davesage12@... [Homebrew_PCBs] wrote:
\ufffd
Yes. I used them for a couple of years and even installed them in my Roland plotter to plot circuit boards. They did an excellent job (if you were lucky) and if the correct ink is used it is VERY resistant to etch. This was my only method of making boards during that time. But then I got a laser printer and abandoned the plotter and ink method in favor of toner transfer. I would never go back and quite frankly I'm not sure why anyone is considering going back to markers and technical pens when toner transfer works so well.
\ufffd\ufffd The technical pens and plotter were simply a pain in the butt. I was using the smallest ones available (0.3mm I believe) and they had to be taken apart and cleaned after every use. There was an extremely fine wire inside used as an ink release valve and it was sure to get bent when dis-assembled. The pens required special cleaner to dissolve the ink. The pens frequently skipped when used on copper (rather than paper as intended).
\ufffdFor what it's worth Eagle can still generate plot files for the Roland plotters but the plotters require a parallel port (rare these days) and drivers for same AFAIK do not exist for the plotters any more.
\ufffd
\ufffdForget the markers etc. and use toner transfer, it's cheap and easy.
\ufffd
\ufffd
\ufffd
Re: SHARPIE PERMANENT MARKER ETCH TEST FOR TOUCHUP NOT PLOTTING
2016-11-16 by Dave Sage
For touch ups I would suggest, with the right ink, the technical pen would
be far superior to a sharpie because you can just set the pen tip down and
ink will flow. No need to rub it around. I always found sharpies difficult
to get a good / durable layer built up. The tech pen ink used to be much
more resistant to etch as well. I see the bottle I have is Staedtler #485
23SAR-9. The R may be a P. There's a bit of ink dried on the container. A
google search on anything to do with technical pens draws a blank as far as
I can see. Staedtler does still have a selection of "sharpie" type markers
that may be better than an actual Sharpie.
 I believe they also had a technical pen ink that was used somehow in the
ceramics industry. Maybe to autograph mugs or something?
That may be another place to look for a good ink.
Sage
ETCH TEST STAEDTLER LUMOCOLOR 313 GREEN and BLACK worked well enough for SMT
2016-11-16 by Rob
I think RED would have worked with more coverage.
Not sure about BLUE though.
Definitely worked well with GREEN and BLACK :
On 11/16/2016 11:20 AM, 'Dave Sage' davesage12@... [Homebrew_PCBs] wrote:
\ufffd
For touch ups I would suggest, with the right ink, the technical pen would be far superior to a sharpie because you can just set the pen tip down and ink will flow. No need to rub it around. I always found sharpies difficult to get a good / durable layer built up. The tech pen ink used to be much more resistant to etch as well. I see the bottle I have is Staedtler #485 23SAR-9. The R may be a P. There's a bit of ink dried on the container. A google search on anything to do with technical pens draws a blank as far as I can see. Staedtler does still have a selection of "sharpie" type markers that may be better than an actual Sharpie.
\ufffdI believe they also had a technical pen ink that was used somehow in the ceramics industry. Maybe to autograph mugs or something?
\ufffd
Sage
\ufffd
2016-11-17 by Rob
Don't know if this will work in a technical pen... will try it...:
http://www.ebay.com/itm/111446456118
But it IS the ink to refill the STAEDTLER LUMOCOLOR permanent 313 markers.
Which to my surprise are labeled as refillable.
Has anyone ever seen a refillable SHARPIE ?
> Roy
