Homebrew PCBs
HOBBY CRAFT ENAMEL WORKS GREAT AS ACID RESIST
2016-12-01 by Rob
I had some really crumby results with using nail polish as acid resist
so I had no great expectations from enamel hobby paint
BUT THIS WORKS GREAT!!!!!!
My search for a readily available acid resist for PCB touchup or hand
crafted etching is over.
I painted on the copper with the thinnest paint brush I could find but I
am certain this
paint would flow freely from a fine point technical pen or dip ink pen
to make SOIC traces.
pictures:
   http://www.learnmorsecode.com/laminator/etch/enamel.html
HOBBY CRAFT ENAMEL WORKS silver sharpies did not work for me
2016-12-01 by Rob
I did use the Silver Sharpie and had terrible results.
It burned off the PCB and floated just like India ink did.
It left streaks of etched hairlines inside 1/8th inch traces.
More than once.
So...nope... no Silver Sharpie for me.
I thought maybe it was an age issue becuase I do use silver sharpies to
write on
black plastic cases..... so I tried a second time using a brand new
fresh silver sharpie...
and got floaters.
My test method is VERY consistent.
The copper PCBs all come from the same source.
I scrub until shiny and scratches with very fine sand paper then
wash clean with acetone.
THEN
apply thin ink line for testing.
I make one pass with a marker and usually leave just enough pigment to
be translucent
and then I apply a second coat..... usually then being the dark color
its supposed to be.
BUT
the enamel craft paint went on translucent where thin... dark black
where thick (paint brush)  and I noticed that even those very thin
layers blocked etching.... much better than my silver sharpies ever did.
MY etch mixture is 100ml of 3% hydrogen peroxide and 50ml of 30%
muriatic acid.
My etch time is usually about 6 minutes.
It has been extremely consistant results again and again so I am very
pleased with this process.
My quest for a good etch resist is driven by the fact that the readily
available sharpie products failed me....
drying out before I was finished touching up a board.... and then the
silver floaters and streaking.
The sharpies drying out might be just be because I take much much longer
to trace over toner traces than normally done by the rest of you all
with good vision.
So if I have to resort to a wetter etch resist...like craft paint in a
bottle... then I'm OK with that idea.
On 12/01/2016 09:05 AM, AncelB mosaicmerc@... [Homebrew_PCBs] wrote:
> Use a Silver sharpie for touch ups or simple circuits. Over the counter
> goodness, needing no extras or special skills.
> Posted by: AncelB <mosaicmerc@...>
> <https://groups.yahoo.com/neo/groups/Homebrew_PCBs/conversations/messages/35278;_ylc=X3oDMTJxbG5uMDU0BF9TAzk3MzU5NzE0BGdycElkAzQ1MDUzNjEEZ3Jwc3BJZAMxNzA1MDgzMjkxBG1zZ0lkAzM1Mjc4BHNlYwNmdHIEc2xrA3JwbHkEc3RpbWUDMTQ4MDYwMTE0MA--?act=reply&messageNum=35278>
