Homebrew PCBs
Milling PCBs: Leaving behind "threads" of copper
2017-02-09 by me@...
I am milling PCBs. I am using Flatcam to produce the gcode and autoleveller to "level" the code. Over all it does a great job. But I am noticing what looks like "threads" of copper in between the traces. Typically the "threads" hug the traces. I can remove them easy enough with a scribe but the process can be tedious.
I am using a 30deg etching bit .1mm. I set flatcam so it overlaps 22% and I am cutting 3 bit widths.
Any one else milling and have seen this problem?
Re: Milling PCBs: Leaving behind "threads" of copper
Well tried on the remaining bits of the board I was cleaning up and a brush didn't seem to help at all. Of course they were the most stubborn of the threads. I will try the brush right away next time.
Is this a common occurrence?
2017-02-10 by hickspj467@...
Copper is notorious for its difficult machining characteristics. It has a tendency to be 'gummy' and 'catch the cutting tool. Careful selection of tool feed and speed go a long way to reduce those tendencies. A very sharp tool helps as well. As mentioned a brass brush to break off the tendrils wirks.
PJH
N7PXY
Re: [Homebrew_PCBs] Re: Milling PCBs: Leaving behind "threads" of copper
2017-02-10 by Cristian
At 08:33 PM 09-02-17, you wrote:
>Two words.
>Brass Brush.
Wrong, use another two words: abrasive rubber (eraser with glass
powder inserts).
Specially produced to clean the PCBs.
See Farnell UK #141330 and #4208596, under the name of
  ERASER/CLEANER BLOCK.
Cristian
