Homebrew PCBs
Slightly OT: What are these called?
2017-10-15 by Brad
Figured if anyone might know it might be you guys.
I am making some double sided boards that will not be plate through - so I
need these metal IC socket pins you install in a strip and then cut after
soldering on both sides.  I have a roll of about 500 but will need many
more.. I just can't find more because I don't know what their proper name
is.  I've tried 'IC socket strip' but I get the strips with the plastic
tops.
https://drive.google.com/file/d/0B4pq0-BHd2x6czNwVFlLYWRNSUE/view?usp=sharin
g
Many thanks if anyone knows what the proper name is and/or where to get
them.
Brad
Re: [Homebrew_PCBs] Slightly OT: What are these called?
2017-10-15 by Harvey Altstadter
Brad,
Those are stamped and formed contacts. There are a gazillion types on the internet and ebay. With a quick look, I couldn't identify a source for the type you are using.
If I were doing what you describe, I wouldn't use those contacts. It will be difficult to keep the solder out of the top spring contact when you are soldering them in. Instead, I would use cylindrical machined socket pins, like this one: https://www.mill-max.com/products/rec/0297. These types of contacts have the spring socket contained within the body cylinder, allowing the solder to flow around the entire contact without having to protect the spring. They are probably more expensive, but will result in less rework and possible board damage.
The link I gave above is for a Mill-Max part I picked at random. When I do this, I sometimes buy some machined contact IC sockets or socket strips on ebay, and remove the contacts. This is a very inexpensive way to get them. The strips/sockets are made of thermoplastic material, and a little encouragement from the heat gun makes them very easy to remove.
Harvey
On 10/15/2017 12:18 PM, 'Brad' unclefalter@... [Homebrew_PCBs] wrote:
\ufffd
\ufffd
I am making some double sided boards that will not be plate through \ufffd so I need these metal IC socket pins you install in a strip and then cut after soldering on both sides.\ufffd I have a roll of about 500 but will need many more.. I just can\ufffdt find more because I don\ufffdt know what their proper name is.\ufffd I\ufffdve tried \ufffdIC socket strip\ufffd but I get the strips with the plastic tops.
\ufffd
https://drive.google.com/file/d/0B4pq0-BHd2x6czNwVFlLYWRNSUE/view?usp=sharing
\ufffd
Many thanks if anyone knows what the proper name is and/or where to get them.
\ufffd
Brad
\ufffd
\ufffd
\ufffd
Re: Slightly OT: What are these called?
2017-10-15 by pierreraymondrondelle@...
RE: [Homebrew_PCBs] Re: Slightly OT: What are these called?
2017-10-15 by Bertho
Note:  For joining top to bottom layers as is normally done, you do not want perfect little tubular eyelets.  You should use eyelets that are formed from a strip and rolled into the eyelet shape.  It will have a desirable vertical slit in it.
I know it sounds backwards the reasons are valid.
Many decades ago Motorola used eyelets on PCBs instead of through hole plating.  Originally nice round eyelets were used and there were a lot of field failures.  The solder properly solders the bottom section to the runner, it wicks up through the eyelet and solders the component lead but there is no capillary action to draw the solder over the eyelet’s top edge onto the top runner so it only makes mechanical contact.  The eyelets with a vertical slit avoids that problem.
Bertho
From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com]
Sent: Sunday, October 15, 2017 16:19
Subject: [Homebrew_PCBs] Re: Slightly OT: What are these called?
brass eyelets for this purpose are on sale on eBay.
Here are two of my related saved searches:
https://www.ebay.com/sch/i.html?_sacat=12576 <https://www.ebay.com/sch/i.html?_sacat=12576&_nkw=%281_+components_+%2Ceyelet%2Ceyelets%2C+%29+%28copper%2Cbrass%2Cnickel%2Ctin%2Cgold%2Csilver%2C%29+-%28stud%2Cscrew%2Ccurtain%2Ccurtains%2Cdress%2Cpin%2Cpins%2C+%29&_sop=10&replaceid=28272496013> &_nkw=%281_+components_+%2Ceyelet%2Ceyelets%2C+%29+%28copper%2Cbrass%2Cnickel%2Ctin%2Cgold%2Csilver%2C%29+-%28stud%2Cscrew%2Ccurtain%2Ccurtains%2Cdress%2Cpin%2Cpins%2C+%29&_sop=10&replaceid=28272496013
https://www.ebay.com/sch/i.html?_sacat=12576 <https://www.ebay.com/sch/i.html?_sacat=12576&_nkw=%281_+components_+%2Caderendh%C3%BClsen%2Ceyelet%2Ceyelets%2Crivet%2Crivets+%29+-%28nylon%2Cbrake%2Cmachine%2Csqueezers%2Csqueezer%2Cpulling%2Cnose%2Criveter%2Ccutting%2Ccutter%2C+%29+-%28shaver%2Cpneumatic%2Caerospace%2Caircraft%2Cgun%2C+%29+-%28arrow%2Cleather%2C3%2C4%2C6%2C8%2C10%2C12%2Cclip%2Cpop%2Caluminum%2C+aluminium%2Ctool%2Cblind%2C+%29+-%28spray%2Cplier%2Cpliers%2Cdome%2Cstud%2C+%29&_sop=10&replaceid=28272269013> &_nkw=%281_+components_+%2Caderendh%C3%BClsen%2Ceyelet%2Ceyelets%2Crivet%2Crivets+%29+-%28nylon%2Cbrake%2Cmachine%2Csqueezers%2Csqueezer%2Cpulling%2Cnose%2Criveter%2Ccutting%2Ccutter%2C+%29+-%28shaver%2Cpneumatic%2Caerospace%2Caircraft%2Cgun%2C+%29+-%28arrow%2Cleather%2C3%2C4%2C6%2C8%2C10%2C12%2Cclip%2Cpop%2Caluminum%2C+aluminium%2Ctool%2Cblind%2C+%29+-%28spray%2Cplier%2Cpliers%2Cdome%2Cstud%2C+%29&_sop=10&replaceid=28272269013
There's lot of junk because it's not so easy to filter the items. Anyway, you'll find quickly some 0.9 or 1mm eyelets.
regards
RE: [Homebrew_PCBs] Slightly OT: What are these called?
2017-10-15 by Brad
Thanks Harvey,
Yeah I've heard a lot of not so good things about these sorts of contacts.
The reason I went with them is because I have a vintage Mark-8 project I'm
doing and they are typically what was used and have the right vintage look.
In fact, I have a number of vintage home-brew machines with two sided boards
and they all used these.  The ones I bought were from ebay and they were
called 'molex ic strip' - but I don't think that's the right name and if I
search under that now it comes up with the plastic topped ones, which I
don't want.
I'm sure they must have a proper name somewhere.. there must still be
millions of them out there - they were used a lot back in the day.
Brad
Sent: Sunday, October 15, 2017 1:18 PM
Subject: Re: [Homebrew_PCBs] Slightly OT: What are these called?
Brad,
type you are using.
Harvey
tops.
g
them.
Brad
<http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_cam
paign=sig-email&utm_content=emailclient>
Virus-free.
paign=sig-email&utm_content=emailclient> www.avg.com
2017-10-16 by William Kimber
I recall the item you are looking\ufffd for (with strip of metal along top that was removed after soldering) but also like you cannot recall the name.\ufffd As far as I am aware they have not been made for many years.\ufffd Presumably most people went to proper sockets as they became much cheaper.
A thousands of those pins were way cheaper than proper sockets.\ufffd Sockets in those days were much higher with more plastic.
Would they have been made by Vero -now defunct?
Will
On 16/10/17 11:51, 'Brad' unclefalter@... [Homebrew_PCBs] wrote:
\ufffd
Thanks Harvey,
\ufffd
Yeah I\ufffdve heard a lot of not so good things about these sorts of contacts.\ufffd The reason I went with them is because I have a vintage Mark-8 project I\ufffdm doing and they are typically what was used and have the right vintage look.\ufffd \ufffdIn fact, I have a number of vintage home-brew machines with two sided boards and they all used these.\ufffd The ones I bought were from ebay and they were called \ufffdmolex ic strip\ufffd \ufffd but I don\ufffdt think that\ufffds the right name and if I search under that now it comes up with the plastic topped ones, which I don\ufffdt want.
\ufffd
I\ufffdm sure they must have a proper name somewhere.. there must still be millions of them out there \ufffd they were used a lot back in the day.\ufffd
Brad
2017-10-16 by mbushroe@...
I considered using these in the past but never actually bought some. I believe they are normally called pcb rivets or hollow grommets, or eyelets. Of all things, Walmart sells a bulk pack of 200 for $6.
Finding the right grommet setting tool could be a bit harder. A hand operated press with top and bottom dies will probably run over $100. If you have access to a small lathe it may be possible to make your own. Harbor Freight sells a watch case press that possibly be modified to either take you home made dies or machine the parts that come with it. If you still have to tools then getting more rivets/grommets/eyelets should be easy.
Mike
Re: [Homebrew_PCBs] Re: Slightly OT: What are these called?
2017-10-16 by Harvey White
Hmmm, kinda been there, did that, then did other things instead.
I think the previous poster's comment about slotted rivets is quite
correct.  I had a story from someone about the regular rivets not
working in the long run.  Solder has to go to the outside of the
rivet, and that has to be soldered to the land on both sides.  Then I
think it'll work.  You do have to check both sides of the rivet.
I actually have one.  Fortunately, it matched the rivets I bought.
From the size involved, you'd want almost a watchmaker's lathe,
smaller will be better here.  The seat for the rivet is a simple
stepped cylinder, with enough of a center to keep the rivet centered.
The hammer part is a bit more tricky.  It needs to be dished but only
in a ring.  A standard conical punch shape would cause the rivet to
split, but not fold over against the PC material.  Look at the much
larger rivet seating tools to see.
Once you make the tool, you'll want to harden it.  Tool steel is
recommended.
A very light tap would work well.  You'll find that the rivet takes a
lot of room on the board, needing a substantially sized hole.  It'll
limit the size of the parts you can use.  I ended up using copper
rivets (available locally).
You'd almost do as well with stake in terminals.  It would be a much
larger board with somewhat difficult ways of doing vias.  One
technique is to treat the whole board as single sided as far as parts
leads is considered, then stitch the top and bottom together with
thing gauge wire (say #26).  You then solder on both sides, clip the
unwanted parts, and you have vias.
Doesn't allow you to do through holes well on things like parts leads,
but does work.
Lots depends on the size of the parts, the number of vias and whether
or not you can do a via without a plated hole, and if your design can
tolerate all through leads to be effectively single sided.
Harvey
>Mike
2017-10-16 by dale.chatham@...
These look to me like the metal socket part that goes into the plastic ic socket you are more familiar with. I've managed to get the metal out of one of those and they look identical, without the metal strip across the top.
I suspect these are the bulk form and are put into the plastic part of the socket via machine. Is there a catch on them that would catch on part of the socket and make it difficult to remove?
2017-10-16 by Harvey Altstadter
The pins that I use come from female header strips, and sell for about
0.90 USD for 3 pieces of 40 pin strips, including shipping. Example:
http://www.ebay.com/itm/3-PCS-Strip-Tin-PCB-Female-IC-Breakable-40pin-Single-Row-Round-Header-Socket-New-/361872902978?hash=item54414e4b42:g:2wwAAOSw7hRWQCzj.
I use my heat gun to soften the plastic, ad push the pins out from the
tail side.
Using these pins eliminates all the need for special tooling, and they
are cheap. In my early days in the Aerospace industry, we used eyelets
to repair pulled out holes in plated through boards. There are some
considerations to using them, and they were eventually banned from
military systems, except under very special circumstances. It was found
that over time, the solder joints between the pad and the eyelet would
crack. This situation could be improved by using funnel head eyelets and
flaring the backside. This allowed the solder to make a fillet with the
underside of both top and bottom of the eyelet. Flaring the eyelet
without breaking it was somewhat problematical. The tooling had to be
just right, and the force sufficient to make sure that the eyelet was
firmly swaged to the board, with no play.
The pins that I propose can be used in either of two ways. The solder
tail can be stuck right into the hole, and the tail soldered first, with
the top pad then soldered to the shank of the pin. The other way would
be to make larger holes, if the pads permit it, and push the shank
through the hole and solder it to the bottom pad, and the collar of the
pin then soldered to the top pad. This does require that the top pads be
a bit larger. The advantage to the second method is that the socket pins
will sit flat on the board, and will always be in line without
adjustment. This assumes that one can drill the socket holes in a
straight line. Once in place. the solder tails can be broken off to get
them out of the way.
Harvey
> Mike
2017-10-16 by bduris@...
They were originally referred to as Molex Pins or Molex IC Sockets. As far as I know they aren't made any more. A while ago All Electronics had something like a last-time buy on them and I picked up a couple hundred. There does look to still be a single replacement source on eBay that I found, but you have to want 500 of them and they aren't real cheap:
- Bob
2017-10-16 by keith printy
I've had reliability issues with those. Maybe if you can find something gold
plated , but the tin ones I have had to reseat chips periodically because
they would quit making a connection
Sent: Sunday, October 15, 2017 3:19 PM
Subject: [Homebrew_PCBs] Slightly OT: What are these called?
tops.
g
them.
Brad
2017-10-16 by Rob
I use nixie tube sockets for all sorts of connections.... and never owned a nixie tube.
100pcs Nixie/VFD Tube Socket Pins(1mm) Gold Plated IN-12 IN-18 IN-2 IN-8 ZM1040
http://www.ebay.com/itm/272708957417
I use wire wrap pins as the male end and the nixie tube socket as female connectors:
http://www.learnmorsecode.com/716/pin2.jpg
Perhaps nixie tube sockets are too large for ICs.... I don't know.
On 10/16/2017 06:33 PM, 'keith printy' keethpr@... [Homebrew_PCBs] wrote:
\ufffd
I\ufffdve had reliability issues with those. Maybe if you can find something gold plated , but the tin ones I have had to reseat chips periodically because they would quit making a connection
\ufffd
\ufffd
\ufffd
& nbsp;
\ufffd
\ufffd
\ufffd
\ufffd
Brad
\ufffd
\ufffd
\ufffd
2017-10-16 by Roland Harriston
Made by Molex.
RFH
On 10/16/2017 3:33 PM, 'keith printy' keethpr@... [Homebrew_PCBs] wrote:
\ufffd
\ufffd
\ufffd
\ufffd
\ufffd
\ufffd
\ufffd
\ufffd
\ufffd
Brad
\ufffd
\ufffd
\ufffd
