Homebrew PCBs
Min trace width using Press and Peel
2004-05-01 by cpexed
Hello,
What is the min trace width while using a transfer product liek press
and peel blue? I want to use SSOP parts and these have pads that are
0.38 mm wide is this feasabile?
Josiah
Re: [Homebrew_PCBs] Min trace width using Press and Peel
2004-05-01 by Stefan Trethan
On Sat, 01 May 2004 17:22:28 -0000, cpexed <cpexed@...> wrote:
> Hello,
> Josiah
i have some 7 mil with toner transfer on inkjet paper (much lower $ than
pnp)
<http://stud4.tuwien.ac.at/~e0225977/pcb.jpg>
good luck
ST
Re: Min trace width using Press and Peel
2004-05-02 by ballendo
Stefan,
Which printer/toner did you use? Which etchant?
Thank you in advance,
Ballendo
--- In Homebrew_PCBs@yahoogroups.com, Stefan Trethan
than
> pnp)
> good luck
> ST
2004-05-02 by Steve
--- In Homebrew_PCBs@yahoogroups.com, "cpexed" <cpexed@y...> wrote:
> Hello,
Look in Files:
http://groups.yahoo.com/group/Homebrew_PCBs/files/Toner_Transfer/
A couple photos of someone's 8 mil traces with 8 mil spacing, and that
was not PnP blue. I think he said he used an inkjet paper.
Hmm... and .38mm is about 15 mils
Steve
Re: [Homebrew_PCBs] Re: Min trace width using Press and Peel
2004-05-02 by Stefan Trethan
HP LJIIID and ALL the error comes from it (rough edge).
The added error of the transfer is much lower than the bad quality of the
printout.
It seems to be the opposite, things get smoothed out a bit and the
"sprinkled toner"
(small particles strewn around) are not transferred.
I have HUGE problems with thick traces, pinholes everywhere.
Need another printer.
ST
On Sun, 02 May 2004 01:03:34 -0000, ballendo <ballendo@...> wrote:
> Stefan,
> Ballendo
> than
>> pnp)
>> good luck
>> ST
> Be sure to visit the group home and check for new Bookmarks and files:
2004-05-02 by Dave Mucha
of the
> printout.
> "sprinkled toner"
> ST
I found in the few TT  boards I have ever made, was that the dusting
all over the board were undercut by the acid so fast that they never
posed a problem.
Also, that in melting the toner, it covered better in some areas.
I too had a problem with getting really dark black areas in large
sections.  I am not sure if it has to do with the laser model being
old, or if it has more to do with the electrostatic exhanges in an
area of the toner.
for large areas, I always went back with a marker and filled in the
holes.
Dave
> On Sun, 02 May 2004 01:03:34 -0000, ballendo <ballendo@y...> wrote:
> > Stefan,
> > Ballendo
lower $
> > than
> >> pnp)
> >> good luck
> >> ST
files:
> > Yahoo! Groups Links
> posed a problem.
Seems so..
> area of the toner.
> holes.
> Dave
this is always a problem with laser printers/copiers.
But i think the older the printer and the thicker the paper the worse it
gets.
I can't make any traces 20mil, i get long areas where it actually results
in two parallel lines, with the middle beeing a single long "pinhole".
It is sometimes better, sometimes worse.
This printer always had problems with toner coverage, this is also the
reason why
i have given up on photo process, i can't get a useable transparency.
ST
