Homebrew PCBs
Question about developing a board
2004-10-01 by Bob Weiss
I made a couple PCB's awhile ago using the decal method and never
want to go through that again!. Well anyway, I have access at work
to a film printer (work at a newspaper) and I can print negatives
upto a size 11x17". I was wondering what do I need to take a blank
double sided copper board and make it into a circuit board? Do I
need a developer, light, etchant and resist solution and I am good
to go? Could anyone also recommend a good company for these products?
Thanks!
RE: [Homebrew_PCBs] Question about developing a board
2004-10-01 by Leon Heller
>From: "Bob Weiss" <BWeiss@...>
>Reply-To: Homebrew_PCBs@yahoogroups.com
>Subject: [Homebrew_PCBs] Question about developing a board
>Date: Fri, 01 Oct 2004 15:21:56 -0000
I use NaOH solution for developing (very cheap) and a UV exposure unit I
built myself, with pre-coated boards (positive-working resist).
Negative-working resist boards are difficult to find, you'd be better off
making positives. The PCB manufacturers use negative-working resist as it
gives better definition, but it's not really suitable for home use.
If you want to buy everyting you need off-the-shelf, try Mega Electronics
(UK).
Leon
Leon
Re: [Homebrew_PCBs] Question about developing a board
2004-10-01 by Les Newell
If you are buying board from Mega then I would recommend their Microtrak
board rather than the Fotoboard. It is the same price but it seems to be
more tolerant to over/under exposure and it seems to give better
definition. The only down side is that it takes over twice as long to
expose. You also need stronger developer.
Les
> (UK).
> Leon
> Leon
2004-10-01 by Jan Kok
> upto a size 11x17".
Those negatives should work great.
If you are in a reasonable sized city, you can get presensitized PCB
material, developer and etchant from an electronics parts store.
Whatever you use to expose the aluminum sheets used for newspaper
printing will probably work very well for exposing the presensitized
PCBs.  Follow the instructions (maybe inside the package) for the PCB
material and do a few test runs to get the exposure/develop/etch times
right.
Have fun!
- Jan
Re: Question about developing a board
2004-10-01 by Dave Mucha
products?
> Thanks!
I think the Decal method is really slow if you are taling about the
self stick traces and pads.
Toner transfer is the best cheap way to make boards.
The photoresist is more costly for the stock boards, but if you can
develop, then great.
I remember a guy on here who was makeing pre-sensitized boards for a
decent price.
Maybe you'll get a direct e-mail from him ?
I've never done the photoresist so can't comment on the ease.
Dave
