Mellotronists group photo
Mellotronists
Index last updated: 2026-04-28 23:09 UTC
Re: [Mellotronists] Re: Tron on Ebay... report on 1221 - 2nd attempt
2007-03-13 by tronbros@aol.com
In a message dated 13/03/2007 04:26:33 GMT Standard Time,
franzs@... writes:
John was able to inspect the machine.  How  do you buy these things from a
long distance?
Jeff
Dear All,
You have to assume that the 'tron on offer is NOT in full working  condition
and just needs light adjustment.  This is  NEVER the case.  When you buy any
mellotron/novatron you  must expect to invest in it further to get it to peak
performance and this  almost certainly involves pinchrollers, pads, headblock
service, tapes, service  to tape frame, service to audio, probably some type of
servo upgrade and almost  certainly a new motor.  Whether you buy from us,
Markus or anyone else is  not the issue.  It is naive to think an
electromechanical device that has  hardly been serviced since it was created 35 years ago is
going to be anything  more than a total disappointment in the first instance.
To sum up, buy any 'tron you can in the prior knowledge that acquiring one
is only the first step.  There are many more hurdles before it can be truly
called a working mellotron.
Best,
Martin
STREETLY ELECTRONICS - All Things Mellotronic
_www.mellotronics.co.uk_ (http://www.mellotronics.co.uk/)
_www.mellotronics.com_ (http://www.mellotronics.com/)
US  East Coast Agent - Jimmy Moore _jmoore6397@..._
(http://jmoore6397@.../)
US West  Coast Agent - Paul Cox _pjc56@..._
(http://pjc56@.../)
2007-03-14 by gino wong
I have found in the last year what Martin said is true, you can't use
them for work unless you get a qualified techover or you may end up
borrowing one.  What I have also found is that Mellotrons certainly
require less maintenance than a guitar or a tube amplifier and if you
count the electrolytic caps and the absence of tantalum caps. over ten
- fifteen years require less service than almost any other electric
keyboard.  Compared to any other pro tape devices ownership is a real
bargain, especially these days.
gw
> franzs@... writes:
> long distance?
> Jeff
> Dear All,
> of servo upgrade and almost certainly a new motor.  Whether you buy from us,
> 35 years ago is going to be anything more than a total disappointment in the
> first instance.
> Best,
> Martin
> US East Coast Agent - Jimmy Moore jmoore6397@...
> US West Coast Agent - Paul Cox pjc56@...
