Mellotronists group photo
Mellotronists
Index last updated: 2026-04-28 23:09 UTC
Frozen Motor Question
2007-05-15 by Berington Van Campen
Hey everyone! Glad to be the newest member of this "elite"
community! Have owned M-400 #1485 since 1977, & it's figured
prominently in my music (at the time esp., very Yes- & Genesis-
influenced, as well as Beatles, Crimson and others...). Suffice it to
say, since '77 it's been a huge boon to my music career. I should
add, I made the SMS3 conversion, etc, and being a VERY clean machine,
it's operated beautifully with only routine maintenance. Learned to
clean motor brushes, etc.
   Sadly, in my mainstay scoring work, the advent of MIDI equipment,
sequencing & mixing direct to digital recorders, bypassing tape
altogether, made using the Mellotron a rarity. Periodically I'd fire
it up just to make sure it stayed lubricated, etc, and it always
delivered the thrill of playing what's a truly wondrous instrument
even to this day.
   More recently, getting back into live performance as a guitarist,
I've wanted to get that M-puppy back into circulation, and found the
motor VERY sluggish. Soon stalled altogether, and while trying to
encourage the capstan to turn, I began smelling an electrical
burning, and of course, killed the power immediately. Examining the
motor, I found a couple of resistors (I believe… they're pretty
fried!) attached to it that had burned. I have the original owner's
manual w schematics, the old CMC-10 board & other docs, but can't
seem to locate `em at the moment. Do any of you have such experience
with your instruments, and/or have any ideas how to proceed to un-
stick the motor, replace the burnt parts, and restore my once-happy
baby to its previous state? Or is there anyone in the L.A. area I
might talk with? I'd appreciate any suggestions! Thanks muchly in
advance!  ~B.
   P.S. – A photo of #1485 appears on my MySpace site under "View my
pics" at www.myspace.com/berington.
Re: Frozen Motor Question
2007-05-16 by Doug Berg
--- In Mellotronists@yahoogroups.com, "Berington Van Campen"
to
machine,
to
equipment,
fire
> even to this day.
guitarist,
owner's
experience
happy
> advance!  ~B.
my
  Hello B:  Guess to start with obvious, loosen belt from motor and
see if motor turns freely. If not check for any obstructions, does
tach wheel clear head? Are motor bearings dry? Next, look at
armature and commutator for any burned windings, really dark brown,
The next step would be to remove armature and with ohm meter check
for shorts in windings and on commutator.  If resistors at motor are
burned, they can easily be replaced but were not the cause of
malfunction but the result.  Could be capacitor gone bad, when you
find your schematics you will be able to determine value.  Last to
check is SMS3 card, hopefully you have checked edge connectors on
card for snug fit and proper insertion.  These are basics, so if and
when you find problems, you can look for specific areas.  Remember
if voltage to motor decreases, current increases, and things will
quickly fry.  Let us know what you find, and BE CAREFUL.  Doug
Re: [Mellotronists] Frozen Motor Question
2007-05-16 by Mike Dickson
Berington Van Campen wrote:
> Hey everyone! Glad to be the newest member of this "elite" community!
Greetings. We're *not* that elite; we even let Canadians in.
Mike Dickson, Edinburgh
2007-05-16 by James Bailey
--- In Mellotronists@yahoogroups.com, Mike Dickson <mike.dickson@...>
community!
Yeah, and even 'tronless ones like me!
Jim Bailey
2007-05-16 by Rick Blechta
But the Canadians may not let you back in after on the havoc you "reeked" on your last trip here.
Rick
2007-05-16 by Berington Van Campen
WOW! You guys are tremendous!! I appreciate such a response, and so quickly!
To Martin, thank you for your referral to your local Streetly rep here in Sunland, Paul Cox. (pjc56@...) Sounds like the way to go if I can\ufffdt sort it out myself, following several suggestions. Sunland\ufffds only about 20 minutes from where I live, so that\ufffds exactly the kind of info I was hoping for. By the way, the \ufffdlegendary\ufffd M-4000 sounds fascinating\ufffd first I\ufffdve heard of it here, but it sure has been the topic of much (hopefully ALL good-natured!) ribbing! I look forward to hearing about it, too, but all in good time, yes? Remember the Kurzweil \ufffdphantomware\ufffd piano? It was advertised IN MAGAZINES for like, 2 YEARS, before anyone ever played one! Now that fine instrument\ufffds almost \ufffdold hat!\ufffd I\ufffdm sure when the 4000 is ready for unveiling, you\ufffdll be the first one WANTING it to get out there! In the meantime, some of the comments have been cracking me up! Not uppin me crack, mind you\ufffd I\ufffdm leavin\ufffd that one alone! HA! Ahh yes, a little twisted humor is a lovely thing\ufffd
Doug Berg, thank YOU for your sensible suggestions to get at least a diagnosis! They make all the sense in the world, and I look forward to getting\ufffd TO \ufffdem! That\ufffds exactly the kind of stuff I was hoping for! I KNOW I\ufffdve seen that damn manual not too long ago, too! I can visualize it\ufffd I\ufffdm sure it\ufffds in my studio somewhere. Makes me crazy. I\ufffdll find it sometime when I\ufffdm not looking for it. But yes, I\ufffdm sure it has resistor and cap values in the hand-drawn schematics. I\ufffdm sure you\ufffdre QUITE right, too, that the resistors are a result, NOT the cause.
To Frank, your offer to fix it if I send it to you is most appreciated, as well. And a damn good price, too! (By the way, the rest of you should check his site if you haven\ufffdt already, at www.myspace.com/trondoc. BEAUTIFUL restoration work!) Your suggestion to change the capstan bearings is undoubtedly a wise one, especially for such relative ease of doing. And it seems, as you say, something that should be done just on general principles after such a lengthy time. As far as the motor rebuild, yes it does sound do-able. As far as the chokes, possible resistors, caps and all go, might I be able to buy any parts through you? You\ufffdd surely know the correct values, and that\ufffdd be the LEAST I could do for your generous assistance and guidance. Of course, your suggestion to just go with the new motor through Streetly is undoubtedly the best, particularly since they\ufffdre such better motors. And considering Martin\ufffds info earlier, a pretty easy one, too. Still, the rebuild is certainly less expensive for the time being, and would be an interesting project, too, if I chose to do it myself.
And lastly, to Mike Dickson, up in Edinburgh! HA! Thanks for your greetings! As to Canadians, well, MY only beef with \ufffdem is they insist on playing everything in the key of \ufffdeh?\ufffd (HAD to say it\ufffd it was right there\ufffd right there\ufffd )
Thanks everyone! I look forward to any more feedback; I\ufffdll let y\ufffdall know what I do, and of course the results. It\ufffds great to get acquainted with you all! #1485 thinks so, too.
All the best,
Berington
Van Campen Productions / VCMusiCorp
VCMusiCorp1@...
(626) 458-4474 Home/Office
(323) 821-0411 Cell
Re: [Mellotronists] Re: Frozen Motor Question
2007-05-17 by Mike Dickson
> community!
And even gormless ones like Blechta.
