Mellotronists group photo
Mellotronists
Index last updated: 2026-04-28 23:09 UTC
Re: another crappy Mellotron
2010-03-25 by lsf5275@aol.com
I have been steadily trying to get a bunch of Mellotrons done and out of
the shop. Rather than post everything that is going on, I think that it is
only  worthwhile (and perhaps marginally entertaining) if I put up photos and
comments  about the more challenging ones. This Mellotron is the 2nd one
I've done since  the "Blue Mellotron." I'm not particularly fast these days
because I've been  working harder than ever at trying to keep my regular
business afloat and at the  same time, getting my house ready to sell. Soon I will
be moving to a new place  out in the countryside with a stand alone shop in
its own building.
So here is #885/674. Yes, two Mellotrons butchered to make one. When  it
came into the shop the floor was rotted out and the right side of the cabinet
was split front to back about 6 inches up from the bottom. The whole
cabinet was  coming apart at the seems. This one also had the worst keyboard I
have ever  seen. There were son many keys with compound warps that I wasn't
sure how to get  they straight and make them stay that way. Eventually I ended
up using a  technique that it very risky but it worked and I was able to get
the keys  straight.
Here are a few before and after photos for those that can view them.   I'll
put a whole series up on the home page later tonight or tomorrow. If you
right click and save these they are in much better resolution
This one hides many  dark secrets. It is hard to see the warps in the keys
but they were  so bad that keys were stuck  together.
Notice the missing  fuse? It's duct taped inside the power supply.  Sweet!
Pretty much like most  I get. Complete with 30 year old dirt and stuff
spilled all through  it.
It not only needed  cleaning, but a thorough disinfecting before I could do
 much.
This was the solution  to keeping the floor together. Then it got dropped
and slit the  side.
Testing the rebuilt  machine
I  later ended up repainting the wood for the control panel.
Fitting out the  cabinet. The owner did not want the outside  painted.
The  basement.
This one had to be  rewired from the control box to the power supply. Lots
of burned  wiring and the WME 289 & 290 were burned  up.
Ready for  delivery.
Ready to go home with  its owner. Look how excited he is.
This is my  shop
It is like a big  "L"
4  work tables
This one is where I  spend the most time. Solovox in the  background
The wood "rack" speeds  things up and is a great place to lace tapes into a
 frame.
