QTR-Quadtone RIP
Epson Artisan 730
Epson Artisan 730
2012-07-27 by scho_2000
Is there an equivalent QTR supported printer that I could use with the Artisan 730?  I tried with the R260, 280, 380 series but did not work.  Printer is set up for wireless network printing.
Re: Epson Artisan 730
2012-07-27 by serdar_b
Any of the printers using claria inks supposed to be suitable. I can use P50 with R260, 280, 380 and with 1400. Have you tried epson 1400 profile, it is a much recent printer.
but I suspect it is a wireless thing.
Good luck
2012-07-28 by scho_2000
Thanks.  You may be right about the wireless connection.  How did you install a P50?  Install script or manually via Print/Fax?
> Good luck
Re: [QuadtoneRIP] Re: Epson Artisan 730
2012-07-28 by Phil Morse
> > Good luck
I re-installed QTR and now I can access the Quadtone printer list and was able to install the Epson Artisan 730 as a QuadR280.
> > Good luck
> > Good luck
> > Good luck
Problem now is that it doesn't print.  Sending a print job results in the printer spitting out endless sheets of  paper from the feeder.  I'll try another printer emulation, but it looks like this is not going to work.
> > > Good luck
2012-07-28 by serdar_b
I am using windows PC, I installed QTR select the printer and then the printing model.
If you are using a mac, I don't know how to do it.
> > Good luck
> > > Good luck
> > > Good luck
No luck setting up a Quad printer with any of the Claria printer surrogates.  However, I was able to get excellent metamerism free BO prints on high gloss metallic papers using the Epson 730 driver, plain paper setting, annd B&W mode.  If you use any of the photo paper settings then the printer will revert to full color mode, even with the B&W mode checked and the resulting prints will exhibit metamerism.  I also tried some BO printing on fiber base glossy and matte papers, but the prints were too blue/black cool for my taste.  The metallic high gloss and luster papers print very close to pure neutral using just the Claria black ink.
