L values comparison
2015-11-05 by peter@...
Hi All,
Getting back into QTR after months on another photographic project.
I am using Print Tool with a 3800 and 9900, also just updated to El Capitan with no problems so far.
After some help from Roy - thank you.
I did my first curve today with the following: i1 Pro (old device UVcut) running i1 Profiler licensed version.
I used: Richard Boutwell's i1-QTR-Step-21x4-random TARGET and his i1-profiler-QTR-21x4-random.txt script.
I printed out the target with Print Tool - No colour Mgmt. left to dry. I loaded the target into i1 Profiler and measured using spot, it went without a problem. Saved the file then proceeded with the Linearisation using Diallo QTR Workflow Level 2.
Again all went OK and the new curve UKpk- 9900- Canson Platine Fibre Rag- Neutral is sitting in the QTR Applications folder and duly shows up when printing from my Quad9900 set up in Print Tool.
I looked at the two graphical displays, one without linearisation and one with. The latter is no where near a straight line, in fact apart from 2/3 tiny shifts in the "L" its the same as the former.
I printed a target - I like the Northlight Images test image that Keith Cooper provides - with my new profile and one with the UKpk-raw-neutral. I cannot see a difference.
Did the same routine and double checked everything, same result.
Any ideas or help would be appreciated - thank you.
Peter
