> It looks exactly like printing without a curve selected.
> If you can look at the .quad graphs and they are similar then the
> most likely explanation is that you missed selecting the curve on the
> first print. The curve was selected on the second print.
> Roy
> On Fri, Jan 15, 2016 at 8:08 AM, Paul Roark roark.paul@... [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com> wrote:
> So, probably something went wrong in the re-linearization process.
> (I'm on Windows, so I can't help with the Print Tool issues.)
> Paul
> www.PaulRoark.com
> On Fri, Jan 15, 2016 at 8:02 AM, Jacques Caron jacques.caron@... [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com> wrote:
> Hi
> I used one of yours : Eb6-EpsHpn-T (this one was OK) and for the first print a profile that I linearized from yours : Eb6-EpsHpn-T-lin.
> If I look at both quad profiles (using QTRView), they look almost the same so the input to Print Tool must be very close.
> Jacques
> Jacques Caron
> Photographe
> jacques.caron@...
> Le 2016-01-15 à 10:47, Paul Roark roark.paul@... [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com> a écrit :
>> Which profiles were used?
>> Paul
>> www.PaulRoark.com
>> On Fri, Jan 15, 2016 at 6:15 AM, jacques.caron@... [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com> wrote:
>> Hi
>> Is it possible that a profile goes bad?
>> Explanation: I printed a 13x19 on an Epson 1430 fitted with the standard Eb-6 inks; I used Print Tool to select a profile and sent the task to the printer. Unfortunately, the print was almost black (but the whites were OK). I immediately reprinted the same picture, using Print Tool and this time, selected a profile very close to the one I used. Perfect print!!!
>> I'll have to refill the printer since the first print almost drained the black cartridge.
>> What could be the cause of this behaviour?
>> Many thanks
>> To see the prints :
>> https://dl.dropboxusercontent.com/u/41606691/Print_01.jpg
>> https://dl.dropboxusercontent.com/u/41606691/Print_02.jpg
> Roy Harrington
> roy@...
> www.harrington.com
