The limits of working with QTR
2017-09-01 by skapuskar@...
QTR is a great software, especially in conjunction with Print Tool. Steep learning curve, but it is worth it.
I have been using it for many years now, it took me some time to get used to it's potential and I'm sure that there are still things to discover, but it has definitely become essential in my digital workflow.
The past weeks I have been working on 3 different projects, improving my digital negatives for carbon transfer printing, creating digital negatives for silver baryta printing, and making profiles for digital inkjet prints.
The latter was the simplest, and the obtained profile was spot on.
More time involving was the negative creation for silver prints and carbon transfer. Whereas the profile creation for inkjet works in a strict mathematical fashion, it is not so the case with alternative chemical processes. The inkjet profile creation is a straight forward linear process, you start with a base curve, apply a grey curve correction to mathematically evenly space the tonal values, then you linearize the output to obtain a smooth gamma corrected curve that results in an evenly spaced appearance to the human eye.
In the case of making digital negatives for alternative processes, unfortunately, the same procedure does not give the same predictable results. The fact that chemical processes do not follow a linear behaviour, sets the limits of QTR, in other words, this is not a QTR issue, it is the non-linear behaviour of the processes that limit QTR from giving you that perfect profile, so a lot of trial and error is required to obtain a fair profile that works for your specific process.
Mainly, my biggest difficulties in most cases were to get smooth transitions in the highlights. In my trials, the limiting factor with negatives for silver printing was the typical paper inertia, that is, it takes a certain amount of exposure to the paper before initial development would show. In the case of carbon transfer (which is a fairly linear process), the self masking properties of the sensitizer concentration would cause non-linear behaviour in the highlights.
Those are only a few elements that are specific to many processes and that QTR can not take into account, no blame.
Just sharing some thoughts...
Sidney
Sidney
