QTR-Quadtone RIP
Maximum TIF file size with QTRGui?
2017-12-01 by dtrout@...
I'm running the latest Windows version of QTR and have run into an interesting problem relating to the size of the TIF file I'm trying to print. The file is from a 4x5 negative (scanned at 4000 spi on my Howtek) and is 539MB in size (no compression). When I open this file in QTRGui, a blank white square appears in the QTRGui File Open window where I would normally see a small thumbnail of the image. There is no error message or other indication that QTR has encountered a problem with the image (other than the blank thumbnail).
I went back into Photoshop and saved the same image to a different TIF file, this time compressed using LZW. Strangely, the resulting file size is now 710MB. I've seen increases in file size with compression before, but not this much! But the really strange part is that QTRGui successfully opens the larger TIF file (with LZW compression).
Both TIF files were saved as flat images without layers.
So my questions:
  • Is there a known maximum size allowed for TIF files in QTRGui? (Is it different in QTR on the Mac?)
  • Why would QTR open the larger TIF (with LZW compression) but not the smaller non-compressed TIF file?
For completeness of information, my workstation is running with 36GB of RAM and 4 CPU cores, so I think there should be no problem there.
Any ideas welcome.
Dave
Re: Maximum TIF file size with QTRGui?
2017-12-02 by dtrout@...
More information after some further testing:
Print-Tool on the Mac can open both files with no problems. So this is clearly only a problem on Windows using QTRGui. My feeling at this point is that QTRGui is running into some kind of internal memory management issue when opening large TIF files. But I'd still like to know if there is any kind of "documented" (but maybe not largely known) limit on the maximum TIF file size in either QTRGui or Print-Tool.
Roy, any comments?
Dave
Re: [QuadtoneRIP] Re: Maximum TIF file size with QTRGui?
2017-12-02 by Roy Harrington
Hi Dave
I don't think there's much I can add as far as QTRgui. Any specific limitations are due to the
language and libraries it was written with. Seems strange that the larger compressed file works better
but I can't look into it all all. I've not had anyone talk about limit problems with it before though.
There are a couple things you can do that may help. Use grayscale rather than RGB, convert to
8-bit for printing, rotate image ahead of time rather than have QTR driver do it.
On the Mac side I have more control and info. Again its mostly dependent on system limits - hardware and software.
There have been a couple cases where people went over the 2G limit of 32 bits and this caused
some internal problems. But that is huge.
Roy
On Sat, Dec 2, 2017 at 9:10 AM, dtrout@... [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com> wrote:
Roy, any comments?
Dave
