QTR-Quadtone RIP
Help printing gradient from Photoshop
2018-09-07 by Dwight Lindsey
Hello all:
I’m new to the list and I’ve got a simple goal that I’m having trouble with.
I’ve made some gradients in photoshop. I’ve got linear gradients and radial gradients. They look beautiful in Photoshop.
I’m having trouble printing them as smooth gradients.
I’m using an Epson SureColor P800 printer with the OEM Epson Inks.
When I print directly to the printer from photoshop, I don’t get smooth gradients.
I had hoped that QuantoneRIP could help, but when I make a TIFF, which looks good, and print it with Quadtone RIP, I get pretty much the same not-smooth-gradient.
I’ll be grateful for any help getting me pointed in the right direction to solve this.
Thanks!
Dwight
Re: [QuadtoneRIP] Help printing gradient from Photoshop
2018-09-07 by Mark Savoia
Is file 8 bit or 16 bit? Printing at 1440 or 2880?
Mark
stillrivereditions.com
> On Sep 7, 2018, at 1:57 PM, Dwight Lindsey lindseydwight@...m [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com> wrote:
> Hello all:
> Thanks!
> Dwight
2018-09-07 by Kerik Kouklis
JPGs are 8 bit. Printing at 2880.
On Fri, Sep 7, 2018 at 11:40 AM Mark Savoia mark@stillrivereditions.com [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com> wrote:
Mark
On Sep 7, 2018, at 1:57 PM, Dwight Lindsey lindseydwight@... [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com> wrote:
Hello all:
Thanks!
Dwight
Oops. Sorry. I was replying to a different email.
Kerik
On Fri, Sep 7, 2018 at 11:40 AM Mark Savoia mark@... [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com> wrote:
Mark
Hello all:
Thanks!
Dwight
That is probably the issue, needs to be 16 bit at creation time and print out as 16 bit. Don’t covert to 16 bit, it will not help. Stay away from JPEGs too, bad file format, destructive. The printing DPI looks good. Also make sure you have no printer issues, check the nozzles and alignment.
Mark
> On Sep 7, 2018, at 2:46 PM, Kerik Kouklis kerik@... [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com> wrote:
RE: [QuadtoneRIP] Help printing gradient from Photoshop
Image is grayscale, 8 bit.
I can easily make it 16 bit, but the not-linear-grad issue is not subtle at all . . . I wouldn’t imagine that the 8 bit 16 bit issue would result in the problem I’m having . . .
But I’m hear to learn and glad for any suggestions.
Dwight
From: QuadtoneRIP@yahoogroups.com <QuadtoneRIP@yahoogroups.com>
Sent: Friday, September 7, 2018 11:36 AM
To: QuadtoneRIP@yahoogroups.com
Subject: Re: [QuadtoneRIP] Help printing gradient from Photoshop
Mark
On Sep 7, 2018, at 1:57 PM, Dwight Lindsey lindseydwight@hotmail.com [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com> wrote:
Hello all:
Thanks!
Dwight
2018-09-08 by Dwight Lindsey
I created a 8 ½ x 11 gradient, 16 bit, Greyscale.
Saved it as a TIFF with no compression.
Now I get an error message “Unable to create TIFF Bitmap buffer”.
What to do?
Thanks!
Dwight
Sent: Friday, September 7, 2018 11:54 AM
To: Kerik Kouklis kerik@kerik.com [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com>
On Sep 7, 2018, at 2:46 PM, Kerik Kouklis kerik@kerik.com [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com> wrote:
Re: Help printing gradient from Photoshop
2018-09-08 by David Whistance
Are you using a standard QTR “profile”? If so have you run the linearisation script so that it works with your printer?
David Whistance
2018-09-10 by brian_downunda@...
The fact that you had this error message suggests that you're on Windows. If you scroll down the posts in this group to around 24-25 Aug you'll see that I had the same error message. I didn't ever solve it directly. It came and went several times and seems to have gone away. It seemed to be related to the number of pixels in the image file rather than the Mb size of the file
In relation to your initial problem of unsmooth gradients, I'd be more inclined to suspect your colour management settings than the file format and bit depth, although creating and printing a 16 bit uncompressed TIFF can't hurt. If you manage to get past this error perhaps you could share your workflow in more detail and esp your CM workflow & QTR settings. QTR should be able to print a pretty good gradient.
What to do?
Thanks!
Dwight
RE: [QuadtoneRIP] Re: Help printing gradient from Photoshop
2018-09-11 by Dwight Lindsey
Hi Brian:
Yes, Windows 10.
Since that post . . . in between other real work . . . I’ve been going through the curve generation and linearization routines. So far without good success. I don’t like the way the 21step prints look.
I don’t have a densitometer. I’m printing on transparent film and my scanner doesn’t really do that . . . so I’m struggling.
I’ll keep plugging at it. I don’t fully understand what I’m doing yet, but I’m further along in the process. From long experience with other technical puzzles, I’ll get this, after a few days more struggle.
If there’s anyone in the Los Angeles area (I’m in Lancaster, NorthEast of LA) who’d like a consulting gig helping me figure this out . . . I’d like to talk.
Dwight
Sent: Sunday, September 9, 2018 5:19 PM
Subject: [QuadtoneRIP] Re: Help printing gradient from Photoshop
What to do?
Thanks!
Dwight
2018-09-11 by brian_downunda@...
I'd missed the fact that you're printing on transparency. I only print on paper. There are number of dig neg practitioners here who may be able to help.
Dwight
