2019-02-25 by dagor52@...
If you are making profiles in QTR the assignments you select for ink usage is up to you. You can as one person suggested swap chips on the cart that is installed for the bad channel and then tell QTR that the new position. It's not necessary for you reset the chip. I'm curious, are you using all of you 10 inks in your QTR profile?
