Need 24" printer recommendation for QTR and refillables
2019-10-10 by david@...
I am looking for suggestions about which 24" printer might best suit my needs for QTR with refillable cartridges.
° Can use readily available refillable cartridges
° Is less likely to clog
° Isn't plagued by Epson trying to lock me out of my own printer (if such a thing exists)
One sort of related question, too, please... What is the transport system in the 4900 series printer? Is it like the larger printers or the 17" and smaller printers?
Thanks.
2019-10-11 by Russell Welch
The 78xx series is good depending on your needs many around in various states, currently on ebay one with bad magenta channel for $50 if willing to pick it up in western NE. I use a 7880 with only the black matte channel for DTP photogravure, the rest of crts filled with distilled water.
From: QuadtoneRIP@yahoogroups.com <QuadtoneRIP@yahoogroups.com>
Sent: Thursday, October 10, 2019 6:22 PM
To: QuadtoneRIP@yahoogroups.com
Subject: [QuadtoneRIP] Need 24" printer recommendation for QTR and refillables
Thanks.
2019-10-11 by David Kachel
Thanks Russel. Based solely on the numbers published by Epson for the 78XX and my 3880, I conclude that print quality and resolution should be the same. Has that been your experience? (assuming you have made that comparison) dk On 10/10/19 5:43 PM, Russell Welch rcwelch121@... [QuadtoneRIP] wrote: > > The 78xx series is good �depending on your needs many around in > various states, currently on ebay one with bad magenta channel for $50 > if willing to pick it up in western NE.� I use a 7880 with only the > black matte channel for DTP photogravure, the rest of crts filled with > distilled water. > > *From:* QuadtoneRIP@yahoogroups.com <QuadtoneRIP@yahoogroups.com> > *Sent:* Thursday, October 10, 2019 6:22 PM > *To:* QuadtoneRIP@yahoogroups.com > *Subject:* [QuadtoneRIP] Need 24" printer recommendation for QTR and > refillables > > I am looking for suggestions about which 24" printer might best suit > my needs for QTR with refillable cartridges. > > > � Can use readily available refillable cartridges > > � Is less likely to clog > > � Isn't plagued by Epson trying to lock me out of my own printer (if > such a thing exists) > > > One sort of related question, too, please... What is the transport > system in the 4900 series printer? Is it like the larger printers or > the 17" and smaller printers? > > > Thanks. > > -- David Kachel _________________________ Artist-Photographer Fine B&W Photographs & Photogravures Inventor of Selective Latent Image Manipulation Techniques Author \u2014 21st Century Dry Film Polymer (Direct-to-Plate) Photogravure
2019-10-11 by Greg Brophy
7880 or 7900 is the best in my opinion
> On Oct 10, 2019, at 7:22 PM, david@... [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com> wrote: > > I am looking for suggestions about which 24" printer might best suit my needs for QTR with refillable cartridges. > > > ° Can use readily available refillable cartridges > > ° Is less likely to clog > > ° Isn't plagued by Epson trying to lock me out of my own printer (if such a thing exists) > > > One sort of related question, too, please... What is the transport system in the 4900 series printer? Is it like the larger printers or the 17" and smaller printers? > > > Thanks. > >
I have not used a 3880, my experience with the 7880 is using the Epson driver 1440 matte black , unidirectional for DTP photogravure, I am experimenting with the P800 and QTR for DTP with satisfactory results(using your recommendations), I do not plan to put any money to resuscitate my older 7880. When dead I will purchase a new 24 inch Sure Color Printer. For B&W prints I do not believe third party inks provide any advantage over Epson, and are no longer less expensive.
Sent: Thursday, October 10, 2019 7:53 PM
Subject: Re: [QuadtoneRIP] Need 24" printer recommendation for QTR and refillables
dk
On 10/10/19 5:43 PM, Russell Welch rcwelch121@outlook.com [QuadtoneRIP] wrote:
Thanks.
David Kachel
Artist-Photographer
Author — 21st Century Dry Film Polymer (Direct-to-Plate) Photogravure
Your preference between the two? On 10/10/19 6:06 PM, Greg Brophy greg@... [QuadtoneRIP] wrote: > 7880 or 7900 is the best in my opinion -- David Kachel _________________________ Artist-Photographer Fine B&W Photographs & Photogravures Inventor of Selective Latent Image Manipulation Techniques Author \u2014 21st Century Dry Film Polymer (Direct-to-Plate) Photogravure
Greg, What about the 7890? On 10/10/19 6:06 PM, Greg Brophy greg@... [QuadtoneRIP] wrote: > 7880 or 7900 is the best in my opinion > > . > > __,_. -- David Kachel _________________________ Artist-Photographer Fine B&W Photographs & Photogravures Inventor of Selective Latent Image Manipulation Techniques Author \u2014 21st Century Dry Film Polymer (Direct-to-Plate) Photogravure
Never tried it I have a 7880 and like it. The 7900 seems to clog a lot but that is just what I have seen.
> On Oct 11, 2019, at 6:23 PM, David Kachel david@... [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com> wrote: > > Greg, What about the 7890? > >> On 10/10/19 6:06 PM, Greg Brophy greg@... [QuadtoneRIP] wrote: >> >> 7880 or 7900 is the best in my opinion >> >> . >> >> >> __,_. > -- > David Kachel > > _________________________ > > Artist-Photographer > > Fine B&W Photographs & Photogravures > Inventor of Selective Latent Image Manipulation Techniques > Author — 21st Century Dry Film Polymer (Direct-to-Plate) Photogravure >
2019-10-12 by Philip Lindsay
My 9900 Printer sure liked to clog so I bet the 7900 is the same! My Canon doesn't clog but I have changed a pair of print heads. At least head replacement is a user maintenance item.
On Friday, October 11, 2019, 4:11:49 PM PDT, Greg Brophy greg@... [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com> wrote:
__,_.
David Kachel
Artist-Photographer
Author — 21st Century Dry Film Polymer (Direct-to-Plate) Photogravure2019-10-12 by mick.sang@...
Do you run your 7900 on a regular basis, daily, weekly monthly? Frequent nozzle checks? Frequent head cleanings? 5 trouble-free years is a great record so you certainly know what you are doing!!
Phil Lindsay
On Friday, October 11, 2019, 7:51:08 PM PDT, mick.sang@... [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com> wrote:
We've had our 7900 for 5 years. No serious clogs to report at all. - knock on wood! Same for 4900, P5000 and 7800.2019-10-12 by mick.sang@...
