Ink Pattern Page, printing using curves, QTR2.6.1, and mini-tutorial
2008-04-09 by crispycoffin
Got a question regarding printing the Ink Pattern Page ala the mini-tutorial offered in the files section. Quick hardware rundown: Mac OSX 10.4.11, MacBook Pro, Epson 2200, Spyder3 Studio, Epson UC ink. I'm building some curves for Hahnemuhle photo rag and noticed, when referring to the mini tutorial that one should first print the ink pattern page using a curve in which you have set calibration to "yes", the default limit to 100, and deleted the linearize data line. When I'm in the print dialog for QTR 2.6.1 I can select a curve, then select Calibration for the mode. The curve appears to remain selected although grayed out. I print this, and, following the tutorial guidelines, define the limits (in this case K=53%, LK=75%) and add those values to the curve file. I reinstall the curve, following the same printing procedure (select the curve, then select the "Calibration" mode and print. The two prints are identical. Now, does using the calibration mode mean NOT using any curves (since the selection appears grayed out)? If that is the case than does that mean the mini tutorial is wrong or out of date? The process would seem to make sense. You would want find the ink limit. Print a new page with the limits curve and then find the density for partitioning. This would not work if the curve is not applied went printing the calibration page. Am I wrong? Oh, and I'm not color managing the file. Everything else seems to be as it should. Thanks! coffinphoto.com
