QTR-Quadtone RIP
A light has dawned....
2008-07-03 by brouwerkent
I apparently was making a mound out of a molehill...I have a reasonable understanding of
QTR profiling now.  Pretty simple now that I have created my first profiles.    I was
confused by reading the scattered documentations, which to my mind makes this more
complicated than it really is.
I hope someone will answer a few more questions.  I did not get any answers to previous
questions...apparently they were just too stupid!!!  Sorry if my questions were/are foolish.
I am using OSX.  Here are my questions.
1.  There is a droplet, DropQuadProfile.  Current version does not seem to function on
Leopard.  Do I need to use this?  What I have been doing is simply editing the text file,
putting in the appropriate profile folder, and running the terminal script to reinstall the
profile.  Appears to work fine. Am I missing something?
2.  My assumption on linearization is that if I make some changes, ie add a toner curve,
that I need to print the modified curve/step wedge  without any linearization values in the
installed text file.  Is this correct?  I assume I would not get a correct linearization if the
modified curve has any linearization text.  Please confirm that I am correct.  Once I have
read the 21 step, I simply paste in the linearization values, right?...and reinstall to have a
linearized curve.
3. I am still wondering what .quad files are?  They are in the Cone Ink areas.   Just curious.
I would like to look at the text values, but have not found a way to view these curves.
Thanks for your patience with me.
Phil
Re: [QuadtoneRIP] A light has dawned....
2008-07-10 by Roy Harrington
The install script is fine -- it's what I always use.
> linearized curve.
That's correct -- print without linearize values, measure, and the put
the values into curve.
The .quad files are the actual curves.  They are just a big table of
numbers.  Use TextEdit if
you really want to see what's there.  Better is the new program called
QTR-CurveView.
Drop a bunch of .quad files onto it and it shows nice graphs of the inks.
Roy
> Phil
Re: A light has dawned....
2008-07-10 by Susan Chapin
"pretty simple" huh? I have, with the help of folks in the Digital BW the
Print group, figured out how to make grayscale .icc profiles for use with
the Epson 3800 driver (Windows Vista), but I haven't figured out how to
"print without linearize values, measure, and put the values into a curve."
And that's why I'm not using QTR..
Anyone have a "for dummies" step by step explanation, pretty please with
sugar on top?
Much thanks in advance,
  - susan
toner curve,
reinstall to have a
> linearized curve.
2008-07-10 by Michael T. Murphy
That assumes that you have followed the first couple of steps in
setting up a new curve.  Basically you should have already done the
following:
1) Print out the the step chart for all of the inks, with no ink
limit set, using the QTR "Calibration Mode." Then,
2) Determine the black ink limit from that chart.  Set the limit in
QTR. Print out the step charts a second time with that limit set.
3) Go to "Curve Creation" in QTR. Use the 1st and 2nd chart to
determine the "Density" and "Limit" for each of the other black/grey
inks.  Save the curve set that you are working on.  (Paul Roark has
some pretty good instructions for all of this on his web site.)
Once you are at that point, go into QTR and open up the 21 Step
chart.
4) Select the curve set that you are working on.  Set the dpi, etc.
that you want to use later for your prints.  Print out the 21 Step
chart with that curve.
5) Open the Gretag ProfileMaker software. Use the "Measure" function.
Use a spectrophotometer to read the "L" values of each patch on the
21 step chart that you just printed.
6) Export the "L" values to a text file.  Open the text file, cut and
paste the values to Excel.  Copy just the "L" values from Exzcel.
7) Paste the L values on the "Linerization" tab of teh curve that you
are making in QTR.  Save the file.  Generate the curves.
A few points. If you have gotten to the stage of making your own ICC
profile using the QTR "Create ICC" tool, you should already be
through step #6?  You should have created a text file from the 21
step chart that you dragged to the "Create ICC" tool?  Then it is
just a matter of entering those values in the curve that you are
creating in QTR.
One question though: what papers are you using? Which inks? Aren't
there existng profiles in QTR for the 3800 and a paper close to teh
one tht you are using? The curves don't vary a lot from paper to
paper.
Hope that helps.  No time to re-read - hope it all makes sense
too. ;>) Post questions. Good luck!
Best,
Michael
2008-07-11 by slcphoto73
Thanks for this clear - as far as it goes - explanation. And despite
what follows, I am really truly grateful for your answer to my question.
Why do I say "as far as it goes"? I think what I am missing is a good
overview and under-the-hood-view of the subject, something I would get
in a published book (I don't know of any) or an advanced course on
digital black and white printing (not offered in my community
college). I'm sure with this under-the-hood knowledge all would come
clear.
I know in color printing what I am accomplishing when I create a .icc
profile: I'm recording the response of my
printer/ink/paper/resolution/etc. combination to a request to print a
certain RGB value and making that information available to Photoshop
so it can compensate when it sends a file to the printer.
Now, what am I accomplishing when I create an Epson ABW profile?
Presumably the same thing, except I am measuring shades of gray
instead of colors.
That's overview. Under the hood, I know the spectrophotometer measures
the RGB values actually printed. For color, the Eye-one software
somehow magically turns those numbers into a .icc profile. For
grayscale, the MeasureTool software somehow magically creates a
mysterious text file full of mysterious numbers, which QTR CreateICC
magically turns into a .icc profile. Photoshop reads the .icc profile
and adjusts the numbers sent to the printer so the printer prints the
colors or shades of gray Photoshop expects the original numbers to
represent.
Now we come to QTR curves/profiles, non-Epson ink sets, mysterious
terms like "linearization," "ink limit," "density," "L values," etc.
And unclear actions such as entering values into a curve in QTR. All
the information I can find on the Web and in news groups and in QTR
documentation appears to take for granted that the reader has an
overview and under-the-hood-view of what QTR is doing. I don't; that's
why I asked for a "For dummies" explanation.
I know I'm asking too much for any individual to give me a semester's
tutorial for free -- but can anyone point me to a book or on-line
class or, I suppose, tutorial video, or even an in-person workshop
that explains this material, with particular reference to QTR and the
terms used?
 - confused susan trying to figure it all out
--- In QuadtoneRIP@yahoogroups.com, "Michael T. Murphy"
> following:
> chart.
> creating in QTR.
> paper.
> Best,
> Michael
2008-07-14 by Michael T. Murphy
Not a lot of time, but here is a quick response.
What you are setting in QTR is at a more "detailed" level than an ICC
profile. You atre really setting up a generic "driver" the program
taht puts the ink on the paper.
Imagine you work for Epson. They ask you to write a driver to make
prints on their next printer. Grey inks only - no color - to make it
a little easier for your first driver. ;>)
Your first question: How many inks?
That corresponds to the number of inks that you set in QTR as "Grey
ink." You might tell it, for example, that the Black (K), Light Black
(LK), and Cyan (C) positions have an ink cartridge in them.  The M,
LC, LM, and Y positions have no ink (or a color ink) so you leave
those unused.
The next question: "Which ink is darkest?"  "By how much?"
The "L" value ranges from 0 to 100. 0 is the darkest, 100 is the
lightest.
You use the "Density" value to enter the "L" value that you read from
a patch of ink to tell QTR how dark an ink is. First you set the
value of the darkest ink, K.
The values you enter for the other inks are relative, in terms of the
darkest ink - usually K.  They tell QTR how much "lighter" those inks
are than K.
So you enter the denisty of "LK" as a 40, that tells QTR that the
darkest that LK gets in the printout is the same as K at the 40
level, a litte less than halfway to black on K's "white" to "black"
scale.
And then you enter a 13 for C. That says that C is lighter than K or
LK, that the blackest it gets in the test printout is equal to K at
the 13 level.
So C is more useful for highlights than shadows. LK will be useful
for midtones. And when you need a dark black, K will be used for the
shadows.
Next question: "How do I know when to stop adding more ink?"
The answer: at the point of diminishing returns for any given
dilution.  That is, as you put more ink on the paper, the patch
usually becomes darker - which is good. But there comes a point where
you keep adding ink, anbd the patch becomes just barely darker, or
actually becomes a little lighter. That is the "Limit", the point at
which you stop adding ink (and probably switch to your next darker
ink.)  If you didn't have a limit, you could keep addinmg ink -
trying to get a draker black - until you had puddles on the paper
taht smeared and created a holy mess.
OK, you enter all of that. QTR makes a print, but there are jumps and
gaps in the values it outputs, especially when it switches from one
ink to the next. So you "linerize" it - make the output appear
smooth, or continous, to the eye, so that there aren't weird things
going on when it switches from the C to LK ink - like suddenly
getting darker by 15 units, instead of 1 or 2 "L" values.
I hope that helps.   More questions?
Best,
michael
2008-07-14 by dlruckus
Hello Susan. One of the things you might want to try is to simply type
the specific terms you don't understand into the search box above the
group messages. Do this one at a time and then follow and read all the
postings related to it from the archives of the group. You're likely
to spend some time doing this but you will probably get a lot more
information than you expected. It's a veritable treasure trove but,
like all treasures, you have to dig for it ;)
Regards.
Duane
> terms used?
2008-07-14 by Susan Chapin
That is helpful! Thank you. I'll be studying your message, and following up
on the resources suggested by a couple of other people. If I still can't
figure it out on my own I might try to get to a Piezography workshop at Cone
in Vermont, which was one suggestion.
 - grateful susan
