QTR-Quadtone RIP
Watercolor like printing
2010-03-23 by mypaulmay
Dear all,
I want to acchieve a watercolor like look of my print.
What channel /cartridge can I use to add water/solvent to all other channel / cartidges ?
Thanks for your time
PM
Re: Watercolor like printing
2010-03-24 by Jon
--- In QuadtoneRIP@yahoogroups.com, "mypaulmay" <mypaulmay@...> wrote:
> Dear all,
> PM
I haven't tried doing what you are trying to do, but I don't think it would be feasible for a few reasons.
First, the amount of solvent (whether water or flushing solution or something else) required would probably be far more than a printhead would be able to provide. The paper would absorb a fair amount (all of it?) before you would see any runoff from saturation. This is especially an issue as the droplets aren't all laid right on top of each other, but with space in between.
Second, the paper path is flat. This means you'd need even more fluid & it wouldn't run, just spread out the ink. Given what I said first, that would be a lot of picoliters!
Third, if you could lay down lots of solvent, a printer with dye based inks might show some running/oozing of the colors. Pigment based inks would require even more fluid as you'd need to float the particles to get any watercolor type FX.
I do a little painting & think that you might be better off trying applying water (or whatever solvent you might choose) with a brush. You'll have control over the volume applied & can vary the tilt of the surface to control any running/oozing of the colors.
Hope this helps even tho it isn't exactly what you asked for.
Jon B
2010-03-25 by mazawa1
How about using watercolor paper that is dampened before printing?  Have not tried this ...just thinking out loud.
--- In QuadtoneRIP@yahoogroups.com, "Jon" <pixionate@...> wrote:
> --- In QuadtoneRIP@yahoogroups.com, "mypaulmay" <mypaulmay@> wrote:
> > Dear all,
> > PM
> Jon B
2010-03-26 by johnny_kurtz
Why not try to give the photograph a "watercolor" feeling in Photoshop using a Wacom tablet?
> > > Dear all,
> > > PM
> > Jon B
2010-03-26 by mypaulmay
Dear all,
thanks for your replies.
I am already  adding solvent to the paper before printing.
This does lead to quite some watercolor like results, but the I want to add more control.
This is why I thought of adding a "solvent" channel / cartridge to the regular gray channels.
Thanks and Best Regards
PM
> > > > Dear all,
> > > > PM
> > > Jon B
Re: [QuadtoneRIP] Re: Watercolor like printing
2010-03-26 by mrjimbo
I don't know if this is appropriate or not.. I don't know what printer your using as you use the word solvent.. Anyway have you experimenting with a few uncoated papers?
jimbo
  To: QuadtoneRIP@yahoogroups.com
  Sent: Friday, March 26, 2010 10:17 AM
  Subject: [QuadtoneRIP] Re: Watercolor like printing
  Dear all,
  PM
  > > > > Dear all,
  > > > > PM
  > > > Jon B
2010-03-27 by mypaulmay
I am using stardard uncoated watercolor (Arches & Fabriano) papers only for the watercolor like printing approach
> jimbo
>   ----- Original Message -----
>   From: mypaulmay
>   Dear all,
>   PM
>   > > > > Dear all,
>   > > > > PM
>   > > > Jon B
2010-03-28 by Kirk
To get a water color effect, I used to go to Kinkos's and have a color copy of my photo made.  The color copy would be placed face down against a sheet of water color paper.  The nastiest, most toxic methel-ethel-keytone solvent I could get my hands on, would be applied to the back of the color copy.  It would bleed, spread, and transfer the inks to the watercolor paper.
I'd try something like that with Windex, or maybe even water.
> Dear all,
> PM
