> Look at the Tutorial.pdf last page -- its about Bonjour printing which
> is an ethernet connection.
> It says for Leopard 10.5 but 10.6 is the same. If you do this exact
> sequence you'll get the profiles.
> Make sure you do 1), 2), 3) on the screen and last line afterward.
> I'd actually recommend working on the USB connection try other USB
> devices to see if the
> port is broken.
> Roy
> On Tue, Feb 15, 2011 at 6:58 PM, john <deanwork2003@...> wrote:
> > Thanks for the input Roy.
> > This 3800 is at a friends how so I can't test it again right now. I tried two days to set this up, going through PS CS4/latest Snow Leopard.
> > But you are correct, it was not recognizing QTRs printer software through the usb connection. It is a new quad mac and I tried several ports and two cords, one a short one.
> > The odd thing is this person is printing fine via ethernet to the 3800 and QTR will load that way. But in that network configuration, the curves won't load to make QTR operational. That was very strange.
> > I'll pass on this info to the client.
> > I appreciate it.
> > John
> > Yahoo! Groups Links
