Vintage Simmons Drums (UK) Users Group
Index last updated: 2026-04-28 23:14 UTC
Latest repair - SDS2000
2013-09-01 by <philmurr@...>
I bought the SDS2000 that was recently on ebay UK.&nbsp; Cost me around £58 and classed as not working (but may be just a loose wire :-)) - good price I thought. It arrived, very nice physical condition.&nbsp; Checked the fuse - blown so replaced it.&nbsp; Hopefully that was all and it will work I thought, so took the lid off and powered it up.&nbsp; Nothing at all for about 10 seconds then a sharp crack and smoke :-( - quickly turned the power off again. The smoke came from a tantalum cap across one of the op-amp +/- supply, put there for decoupling, so I guess it was just its time to die, and nothing too serious. Looking at the schematics, the SDS2000 uses 5V regulated for the logic, then +/- regulated for the analogue sections, display, etc. and unregulated +/- for headphones etc. Disconnected the regulated outputs from the 3 regulators, powered the unit up again and measured the output voltages.&nbsp; 5V was spot on, but the +/- regulated outputs were giving 1.7V and -2V.&nbsp; Not right. Stuck in replacement LM317 &amp; 337 regulators, plus replaced a few electrolytics that had seen better days.&nbsp; Also replaced the blown tantalum cap. Powered back up and sprung into life :-) I now have a near-immaculate SDS2000 (with reverb).&nbsp; Everything tested out fine and it sounds lovely.&nbsp; I know it&#39;s a later bit of Simmons kit and there&#39;s probably not much love for it, but it is actually a very good unit.&nbsp; And it was good fun and cost less than £2 to repair.
Re: [Simmons Drums] Latest repair - SDS2000
2013-09-01 by Michael Buchner
My hero!
Von meinem iPhone gesendet
Am 01.09.2013 um 19:27 schrieb <philmurr@...>:
> I bought the SDS2000 that was recently on ebay UK.  Cost me around £58 and classed as not working (but may be just a loose wire :-)) - good price I thought. It arrived, very nice physical condition.  Checked the fuse - blown so replaced it.  Hopefully that was all and it will work I thought, so took the lid off and powered it up.  Nothing at all for about 10 seconds then a sharp crack and smoke :-( - quickly turned the power off again. The smoke came from a tantalum cap across one of the op-amp +/- supply, put there for decoupling, so I guess it was just its time to die, and nothing too serious. Looking at the schematics, the SDS2000 uses 5V regulated for the logic, then +/- regulated for the analogue sections, display, etc. and unregulated +/- for headphones etc. Disconnected the regulated outputs from the 3 regulators, powered the unit up again and measured the output voltages.  5V was spot on, but the +/- regulated outputs were giving 1.7V and -2V.  Not right. Stuck in replacement LM317 & 337 regulators, plus replaced a few electrolytics that had seen better days.  Also replaced the blown tantalum cap. Powered back up and sprung into life :-) I now have a near-immaculate SDS2000 (with reverb).  Everything tested out fine and it sounds lovely.  I know it's a later bit of Simmons kit and there's probably not much love for it, but it is actually a very good unit.  And it was good fun and cost less than £2 to repair.
RE: Latest repair - SDS2000
2013-09-02 by <warlandr63@...>
Always good to here stories with a happy end. Tip to budding electronics guys...check ex gov auctions for test equipment!! Gov. generally buy top shelf gear for it&#39;s various depts (military, research etc) and quite often when it stops working they put it in a back room and forget about it, then sell it off many years later during cleanups. I have countless bits of gear that were $15,000+ when new. Most of the time it&#39;s simple fixes like the one described that get it back working again.....great stuff.
--- In simmons_drums@yahoogroups.com, &lt;buchnerelectronics@...&gt; wrote:
 My hero!
Am 01.09.2013 um 19:27 schrieb &lt; philmurr@... &gt;:
 &gt; I bought the SDS2000 that was recently on ebay UK.  Cost me around £58 and classed as not working (but may be just a loose wire :-)) - good price I thought. It arrived, very nice physical condition.  Checked the fuse - blown so replaced it.  Hopefully that was all and it will work I thought, so took the lid off and powered it up.  Nothing at all for about 10 seconds then a sharp crack and smoke :-( - quickly turned the power off again. The smoke came from a tantalum cap across one of the op-amp +/- supply, put there for decoupling, so I guess it was just its time to die, and nothing too serious. Looking at the schematics, the SDS2000 uses 5V regulated for the logic, then +/- regulated for the analogue sections, display, etc. and unregulated +/- for headphones etc. Disconnected the regulated outputs from the 3 regulators, powered the unit up again and measured the output voltages.  5V was spot on, but the +/- regulated outputs were giving 1.7V and -2V.  Not right. Stuck in replacement LM317 &amp; 337 regulators, plus replaced a few electrolytics that had seen better days.  Also replaced the blown tantalum cap. Powered back up and sprung into life :-) I now have a near-immaculate SDS2000 (with reverb).  Everything tested out fine and it sounds lovely.  I know it&#39;s a later bit of Simmons kit and there&#39;s probably not much love for it, but it is actually a very good unit.  And it was good fun and cost less than £2 to repair.
&gt;
&gt;
