Interface
2016-11-18 by Michael Buchner
Check this on the web: The ED103-MIDI2SDS is an 8-channel MIDI note to Trigger unit suitable for use with a variety of synthesizer modules and drum machines including the SDS range from Simmons for which it was originally designed. The unit has 8, velocity sensitive, trigger outputs each of which can be assigned to aspecific MIDI Note using the `LEARN’ mode. Features 8 Trigger outputs each being able to swing between 0V (LO) and +10V (HI) in 127 steps as defined by the MIDI Velocity received. When in TRIGGER mode the duration of the trigger pulse is adjustable from around 1mS to 130mS as set by an onboard trimmer. When in GATE mode the trigger is controlled by Note-On and Note-Off commands. An INVERT mode allows the trigger outputs to swing from HI to LO. Specifications Power +12V @ 50mA -12V @ 10mA TRIGGER Output Range Velocity controlled from 0V to +10V in 127 steps. Onboard trimmers allow the LO and HI voltages to be adjusted to provide finer resolution:- LO can be adjusted from 0V to ~2V HI can be adjusted from ~6V to 10V TRIGGER Output Duration Adjustable from 1mS to 130mS User Selectable Options TRIGGER/GATE Mode INVERT Mode Determines if output is pulsed or MIDI controlled Determines if outputs swing LO to HI or HI to LO
