Re: Today's Indulgence
2009-07-06 by jason/solvent/suctionrecords
hi, > > At the moment, nothing is final except that there will be some > native CV > output. > The CPU itself has a built-in 12 bit DAC, so it would be daft not > to at > least have 2 channels of CV/gate. i would like to request, pretty please (!), that you have at least 2 channels of: - CV (selectable V/Oct or Hz/Volt) - Gate (selectable Gate, Gate +15v, S-Trig, S-Trig+15v) - Aux so that's 6 outputs total i mean, basically i am hoping you would make it identical to the options available on the Kenton... every other analog-style sequencer that i've tried (Doepfer, Frostwave, Analogue Solutions) has fallen short in this regard -- i could never use any of them with all of my synths, and i'm not talking about obscure synths, but fairly common 1s like Korg MS-20, Roland Sys100 > > A couple of years ago, I did some analysis on MIDI latency in > relation to > triggering percussion sounds. > Cirklon will have 16 tracks, and the means to create dedicated > percussion > patterns, x0x-style. > The outcome of that testing was that I decided I need at least 16 > to 24 > channels of accent/trigger outputs to drive percussion sounds where > every > channel can be updated in less than 2ms and preferrably less than 1ms. > Internal generation of those triggers seems like a much better idea > than > trying to arrange some way of sending data to a MIDI to CV > convertor in > advance, to be clocked out at the right instant. > This sort of thing will most likely be available as an optional > card. Not > everyone wants to stump up for the necessary extra circuitry. so this extra card... the idea is that it would have 16-24 analog triggers? well, i like the idea, and would buy it... but it does seem very niche. what i think would make it a lot more versatile and useful, is if these outputs could all be configurable, like the Aux channels on a Kenton.... so if you wanted to use them all to trigger drums, you can, but you also have the option to use them for additional CVs i sold my P3 because of the lack of native CV/gate... i only have 1 Kenton Pro-2000, and i would find myself always having to choose whether to use it for a CV/Gate from the computer/DAW, or from the P3... plus, the rewiring of Midi cables always seemed like a chore and as a result the P3 didn't get used as much as it should've...... of course, i could've got another Pro2000, or maybe some kind of Midi-Merge box (yuck), but these just didn't seem like good options.... so i am really hoping that the Cirklon nails it on the native CV/Gate side of things..... i think that it would be a smart move considering the growing modular market thx jason [Non-text portions of this message have been removed]
