Analogue-sequencer
Index last updated: 2026-04-28 23:15 UTC
P3 patterns for chords?
2011-07-25 by John
Can P3 patterns on Cirklon be used to step sequence chords, or are they for monophonic lines only?
John
RE: [analogue-sequencer] P3 patterns for chords?
2011-07-25 by Colin f
You can use the aux rows to add up to 4 extra notes, for 5 note polyphony.
The limitations are that all notes will share the common velocity value and
length for the step.
The aux notes can either be absolute - you specify the exact note as C3, G4,
etc., or relative - you specify each note as an interval from the main note
value.
If you set up a pattern to use aux notes, then go into real-time record, the
notes you play will be recorded into the main note, and as many auxes as you
have set to use notes.
Colin
