Well - see below.
--- In bc2000@yahoogroups.com, "sexontony" <sexontony@...> wrote:
> Is it possible with BC Manager 1.4.0 to change BCR2000 presets 1..12
> via midi notes e.g. 84..95 on the midi channel 15? (If yes, how?)
> My controller context here is music production.
> Solving this "problem" would allow us not to work just with a single
> preset in a "musical session" but could freely combine multiple
> presets with each other and easily switch between them using simple
> single midi note events in a predefined space (e.g. here midi channel
> 15).
> Then you could e.g. build a setup for 8 tracks (per each BCR 2000)
> and control various aspects of these 8 tracks by switching among
> predefined presets. Some ideas what those presets could do:
> 1. volume adjustments (midi ch 1)
> 2. eq adjustments (midi ch 2)
> 3. compressor adjustments (midi ch 3)
> 4. efx adjustments (midi ch 4)
> 5. balance adjustments (midi ch 5)
I suppose it depends on what software you are trying to control,
however, if you want to have banks of 8 tracks, you can use mackie preset.
It is all in one preset, have you looked at that?
http://shoshin.110mb.com/genmce/bcr2000
I did a video tutorial, using Ableton Live, for controlling pans,
sends and plugins.
Mackie mode is very powerful - in fact, I have wasted the last year
life thinking about it.
Here is a link to my experiences with mackie mode.
http://shoshin.110mb.com/genmce/about/about.htm
You get control on tracks 1-8, for pan, send, faders, mutes, arms,
solos etc...and other stuff.
You get a bank knob, to bank down to the next set of tracks 9-16,
17-24, 25-36... etc (however many tracks you have). This does not use
changing preset on the bcr. It is all in 1 preset on the bcr.
You get a master fader, and a jog wheel, markers, as well as transports.
> By giving each aspect its own preset you can eliminate unnecessary
> "crazy cross thinking" what is defined where and how we should switch
> there most efficiently.
Your right of course - that crazy cross thinking can get really confusing.
Remembering what note to push to control faders or pans, might be hard
to remember too. Remembering which preset would control what might be
tough too... What if you have more than 8 tracks?
So - what software are you trying to control?
Try the mackie preset I made or someone elses.
Kip
> Any ideas, comments and hints?
