All channels affect all channels?
2008-09-21 by Andy
I'm trying to set up a preset on my BCF2000 to use the faders to
control the volumes of the MIDI channels 1-8 on any multitimbral synth.
Sliders 1-8 are set to control CC7 (volume) for each of MIDI channels
1-8. So far so good. But when I tried it, moving any of the sliders
changed the volume of ALL the channels simultaneously.
Any ideas where I might be going wrong?
Cheers
Andy
Re: All channels affect all channels?
2008-09-22 by rpcfender
Hi Andy
Have you checked the output from the BCF with a MidiOx (or whatever
the Mac Midi monitor is)?
Get MidiOx to display in Hex (right click on the input monitor)
You should see a stream of values when you move the fader.
For fader 1
B0 07 00  for channel 1
B0 07 01  for channel 1
B0 07 02  for channel 1
B0 07 ??  this last value of the three bytes could really be anything
depending on where you move the fader
for the other faders
B1 07 ??  for channel 2
B2 07 ??  for channel 3
B3 07 ??  for channel 4
B4 07 ??  for channel 5
etc
How did you create the preset? With Mark's editor?
Try using the front panel - Hold 'EDIT' and move fader1
Top 1 (left) encoder set to 'CC' in the display
Top 2 set to 'Ch 9'
Top 3 to '7' for the vol
Top 4 set '0' as the min
Top 5 set '127' as the max value
Top 6 set 'Abs'
Leave 7
Top 8 set to 'on'
Press 'EXIT'
Fader 1 should be set to Channel 9 - check with MidiOx
B8 07 00
B8 07 01
B8 07 02
B8 07 03 etc
Make sure that there are no synths or PC programs running that might
echo back the CC7 messages on all channels (Sonar, for example, could
easily do this)
Let me know how you get on.
Royce
2008-09-22 by Andy
Hi Royce,
I set up the preset on the BCF itself. Didn't use any editors. I'll
see if I can find out where it went wrong.
Will let you know.
Cheers
Andy
--- In bc2000@yahoogroups.com, "rpcfender" <rpcfender@...> wrote:
> Hi Andy
synth.
> For fader 1
> etc
> Top 2 set to 'Ch 9'
> Top 6 set 'Abs'
> Leave 7
> Top 8 set to 'on'
> Press 'EXIT'
> B8 07 00
> B8 07 01
> B8 07 02
> B8 07 03 etc
> easily do this)
> Royce
