can't install huskervu
2009-11-17 by guanchetetranchete
Everytime I try, the installer asks me wether i want to install the net framework thing, although it's already installed!! If i say yes, it downloads it and installs it again and then nothing else occurs, and if i say no, the intaller window just disppears!!!
Nobody here seems to have this problem, or at least i haven't found anything...
Thsnks in advance for your help!!!!1
Re: can't install huskervu
2009-11-20 by guanchetetranchete
anybody??
The thing is that the installer behaves as if i wouldn't have net framework installed, altough it IS there!!
I would really appreciate some help!!!
--- In bc2000@yahoogroups.com, "guanchetetranchete" <guanchetetranchete@...> wrote:
RE: [bc2000] Re: can't install huskervu
2009-11-20 by Marco Sa
dot.net framework works side by side you should not have any problems but...
please try the following:
1. Remove all versions of dot.net framework, I do mean all (Use CCleaner);
2. Install the version 1.1 from the XP CD, I believe huskervu requires only this version;
3. Install huskervu;
4. Update the dot.net framework acording to your needs.
Good luck.
To: bc2000@yahoogroups.com
Date: Fri, 20 Nov 2009 15:17:25 +0000
Subject: [bc2000] Re: can't install huskervu
anybody??
Windows Live: Friends get your Flickr, Yelp, and Digg updates when they e-mail you.
