BCManager to Setup Soft Synths
2010-01-02 by zerolatencyproductions
Hello Everyone,
I just setup my BCF and BCR for the first time.  They are running in U-3 mode with some hard-synths hooked into the midi ports and are working in Sonar 8.  Now that the BCF is controlling Sonar in Mackie Emu mode, I'd like to start programming the BCR to control other things like my hardware and software synthesizers.  I have already downloaded BCManager and watched Kip's video.  What I am wondering now is if there is somekind of list that comes with a synthesizer or other midi controlled device that has all of the info I need to program the BCX through BCManager.
Brandon
Re: BCManager to Setup Soft Synths
2010-01-02 by rpcfender
Welcome Brandon
Did you download Mark's definitive BCL document 'BC Midi Implementation.pdf' from his website?
That should help you out with the BC script language.
The BC manager has a help file with it.
Most synths have the sysex spec at the back of the user manual -
You should be able to find a pdf of most manuals on the web.
Some are in a separate files (eg Emu P2k series or Yamaha VL=70m)
Any problems feel free to post your questions here, but make them detailed about exactly what you want to do. The response then is usually more helpful.
All the best
Royce
