re Using the bcr with arturia synths
2010-04-20 by nick
At present I own 2 arturia synths moog modular and analog factory. Is there a set for these with this controller and does it work well with these vsti.
Re: re Using the bcr with arturia synths
2010-04-21 by Royce
If you use the BC factory CC preset and then Ctrl left mouse click on a control in the VST, a dialog will pop up.
Simply press 'Learn' button on the dialog and then twist the encoder on the BC that you want to link.
The VST will remember this connection.
Repeat for all the other controls you want to connect.
Hope this helps
Royce
2010-04-21 by -
Is there a way to prevent the initial value jumps on the synths, which happens the first time you move them? I think it also happens everytime you change presets.
I looked but could not find where they (moog modular) output any midi to use as feedback.
> Hope this helps
> Royce
Re: [bc2000] Re: re Using the bcr with arturia synths
2010-04-21 by simon.pocock@bulldoghome.com
There isn't any way because none of the Arturia synths output any midi at all.
It's a feature I've personally requested to be added many times being a long time user of all their synths but all
I ever get from them is "we'll look into it" and nothing happens. It's the one thing that really puts me off using
them outside a studio environment.
For live work I use Native Instruments' Pro 53 which has midi feedback and can be set to do a CC dump when you
change presets.
Quoting - <k5kip_1999@...>:
> change presets.
> as feedback.
> > Hope this helps
> > Royce
> vsti.
Visit Pipex Business: The homepage for UK Small Businesses
Go to http://www.pipex.co.uk/business-services
