How do you use momentary (updown mode) in a .tx statement?
2010-05-05 by ajawdokimov
Hi All
i cant seem to seperate the .tx values to correspond to on/off states
of the button, it just chucks out both the on and off state on the on and off (wow that must sound confusing :)
heres an example ;)
$button 41
  .showvalue on
  .mode updown
  .minmax 64 127
  .tx $B0 $0F $7F  (i want this to be the on state)
  .tx $B0 $0F $40  (Want this to be the off state)
hope that clarifies my ramplings ;
at the moment it chucks out both states on button and off
cheers
Anton
Re: [bc2000] How do you use momentary (updown mode) in a .tx statement?
2010-05-05 by djo3yk@yahoo.ca
Hi Anton,
I think what you're looking for is the "ifp" and "ifn" commands in the
.tx statement.  Check out the "Just a jump to the left" section in
SecretBC.pdf doc in the files section for more details on this.  Hope
this helps.
Joey.
On 5/5/2010 11:16 AM, ajawdokimov wrote:
> Hi All
> heres an example ;)
> $button 41
>    .showvalue on
>    .mode updown
>    .minmax 64 127
> cheers
> Anton
Re: How do you use momentary (updown mode) in a .tx statement?
Thanks so much Joey, that sorted it out nicely ;)
cheers :)
--- In bc2000@yahoogroups.com, djo3yk@... wrote:
> Hi Anton,
> this helps.
> Cheers,
> Joey.
> > Hi All
> > heres an example ;)
> > $button 41
> >    .showvalue on
> >    .mode updown
> >    .minmax 64 127
> > cheers
> > Anton
2010-05-05 by markwinvdb
> heres an example ;)
> $button 41
>   .showvalue on
>   .mode updown
>   .minmax 64 127
You can also use "val":
$button 41
  .showvalue on
  .mode updown
  .minmax 64 127
  .tx $B0 $0F val
This also produces exactly the same output as the ".easypar" version you mentioned earlier, i.e. 127 when you press the button and 64 when you release it.
Hope this helps,
Mark.
