Programming BCR 2000 controller with VST
2010-07-05 by mollekula
Hi guys, im a BCR2000 newbie, i bought it last week and gonna need some help. i read a little piece of info in the manual, downloaded BC manager and a few presets from the Behringer website. i used the Native Instruments Pro-53 preset to experiment and sent it to my BCR2000. i loaded the plugin in my Cubase SX3 and it worked, i mean the controls on the VSTi interface corresponded while i was tweaking BCR controls. then newbie as i am, since i dont know yet how to create a preset of my own from scratch for any VST, i used the very same Pro-53 preset to modify it for another VSTi, needless to say that when i sent the preset to BCR and loaded the other plugin, the only control that was working was the "volume", since i guess volume control number is "CC 07" for every VST or the majority (im just guessing). it took me 3 hours to find out the rest of controls, trying every number from 0 to 127 control by control, though i didnt manage to find 4-5 controls to my disappointment, is it possible these control numbers are above 127 which is the last on CC type and thats why i didnt find them? So, my questions are: 1. what is the way to find out what is the exact control number for each knob and any other control on the VSTi interface so that i dont have to try every single CC number for hours and hours 2. what is the procedure to program a VST FX or Cubase mixer faders etc? because these experiments i made were for a VSTi 3. a question for push button encoder, i managed to program the push buttons using Toggle On in the BC Manager menu and Value 1 (0) Value 2 (70 or 127). for those buttons on the interface that have 2 working positions it worked fine, but some buttons use more than 2 positions, some use up to 10, so how do i program this button parameter so that it changes every time i push the same button? 4. NRPN, is the same or similar programming with CC type? what do i do to program this way?
      i still have to do some serious reading, but id appreciate it if you people could enlighten me here with these questions of mine and put me on the right path so i can make the most of BCR2000. thank you in advance
Re: [bc2000] Programming BCR 2000 controller with VST
2010-07-05 by Sunrider
Hi mollekula,
some plugins have a MIDI-learn ability, so you could use your Pro-53
preset for them, too.
A lot of plugins doesn't have such a MIDI-learn, but they could be
wrapped with the MCX by midevice.com
cu
Perry Staltic
Re: Programming BCR 2000 controller with VST
2010-07-05 by Mark
For e.g. CC messages you can set the Mode parameter to Increment and then select the actual increment step.
But of course this only gives you e.g. 0, 10, 20 etc. An irregular step sequence (e.g. 0, 5, 20, 21, 40) cannot be programmed this way.
Hope this helps,
Mark.
2010-07-22 by mollekula
thanx perry, midi learn is awesome, thanx for the tip. i havent had any time to deal with plugins without 'learn' ability, if i have trouble ill ask for some help. thanx again
