Tweaking Yamaha FB-01 with BCR2000
2010-07-07 by virteo
Hello everybody
I’m trying to program my BCR2000 to tweak Yamaha FB-01 sound generator.
FB-01 recognizes a sysex messages only.
To do my job I found a PC patch editor for FB-01 – I plugged FB-01 to my computer: it works well, no problem here.
To find what kind of sysex messages a PC patch editor sends to Yamaha, I observed a sent data of PC patch editor with the SysEx window of BC Editor.
I noticed that most of the time, the same Parameter N° is shared by two, three, or four orders: in my example, the parameter #57 is shared by “Sustain level” and “Release rate” orders.
The sent data looks like that:
In PC patch editor, I turn the “Sustain level” knob:
$F0 $43 $75 $0A $57(parameter #) $00 $00 $F7
--- --- --- --- $57 $00 $01 ---
--- --- --- --- $57 $00 $02 ---
--- --- --- --- $57 $00 $03 ---
I stop and I turn “Release rate” knob now:
--- --- --- --- $57 $01 $03 ---
--- --- --- --- $57 $02 $03 ---
--- --- --- --- $57 $03 $03 ---
I stop and I turn “Sustain level” knob again:
--- --- --- --- $57 $03 $04 ---
--- --- --- --- $57 $03 $05 ---
--- --- --- --- $57 $03 $06 ---
I stop and I turn “Release rate” knob again:
--- --- --- --- $57 $04 $06 ---
--- --- --- --- $57 $05 $06 ---
--- --- --- --- $57 $06 $06 ---
--- --- --- --- $57 $07 $06 ---
and so on…
Do you think that it is possible to reproduce the same orders with BCR2000?
Thank you for your help
Re: Tweaking Yamaha FB-01 with BCR2000
2010-07-07 by Royce
Hi
I'm not sure this is true. I had a quick look at the Midi spec (yuou can download it at Yamaha) and looks lik eyou can use controllers to also change stuff
> To do my job I found a PC patch editor for FB-01 â€" I plugged FB-01 to my computer: it works well, no problem here.
This is true of many early synths when memory was very costly.
Two or more parameters were packed into a single byte
0xxx xyyy  where xxxx was one parameter and yyy was another.
Unfortunately with the BC you can't access the value of another parameter (say Sustain Level) to add it to the new value of Release Rate, and then output the resulting byte
Royce
Re: [bc2000] Re: Tweaking Yamaha FB-01 with BCR2000
2010-07-07 by Léonid Brédikhine
it's clear... :(
thanx for your answer
Le 7 juil. 2010 à 16:08, "Royce" <rpcfender@...> a écrit :
> Hi
> generator.
> also change stuff
> s.
> Royce
2010-07-08 by Royce
Hi
> it's clear... :(
There is a solution if you can program a PC or Mac.
Set up the BCR with CC controls.
Plug it into a PC
Write a program (you might be able to use Bome's Midi Translator) that takes the CC values from the BC and after just changing just the correct bits in the combined parameter puts out the sysex message.
I have done this before and it isn't that hard.
If you get into trouble feel free to email me.
All the best
Royce
> > Hi
> > generator.
> > also change stuff
> > s.
> > Royce
re: [bc2000] Re: Tweaking Yamaha FB-01 with BCR2000
2010-07-08 by virteo
Hi Royce
Your idea is not bad! I am going to reflect about it.
I wished to avoid using my computer – I prefer the “hardware touch”, but if I have no choice…
I do not know how to handle Bone’s Midi Translator, and if I understood well I need a Pro version of this software.
I would like to thank you one more time for your help.
Leonid
> Message du 08/07/10 09:50
> De : "Royce"
> A : bc2000@yahoogroups.com
> Copie à :
> Objet : [bc2000] Re: Tweaking Yamaha FB-01 with BCR2000
> Hi
> > it's clear... :(
> Plug it into a PC
> All the best
> Royce
> > Le 7 juil. 2010 à 16:08, "Royce" a écrit :
> > > Hi
> > > generator.
> > > also change stuff
> > > s.
> > > Royce
RE: [bc2000] Tweaking Yamaha FB-01 with BCR2000
2010-07-09 by badmuts@acadiane.org
Just curious: what PC patch editor for FB-01 did you find? I also have
an FB-01 and would like to fiddle around with it a bit, most i could
find was old atari stuff or broken windows 95 software...
  _____
Van: bc2000@yahoogroups.com [mailto:bc2000@yahoogroups.com] Namens
virteo
Verzonden: woensdag 7 juli 2010 10:40
Aan: bc2000@yahoogroups.com
Onderwerp: [bc2000] Tweaking Yamaha FB-01 with BCR2000
Hello everybody
I'm trying to program my BCR2000 to tweak Yamaha FB-01 sound generator.
To do my job I found a PC patch editor for FB-01 - I plugged FB-01 to my
Re: [bc2000] Tweaking Yamaha FB-01 with BCR2000
2010-07-10 by Léonid Brédikhine
it's "4op delux" for atari.
it works perfectly on my xp pro with atari simulator. and it's free!
also, there is "fb-01 sound editor" for pc of a french programmer.
it's free, but i prefere "4op delux".
and at last, you can purchase the "midi quest" software. it coasts
~250€. more designed graphic interface, but as for me, i got my
yamaha for 30€ in the second hand shop, so my choice is done.
> have an FB-01 and would like to fiddle around with it a bit, most i
> could find was old atari stuff or broken windows 95 software...
> virteo
> Hello everybody
> or.
