Factory Settings
Factory Settings
2010-08-12 by sam.korn
Anyone help with restoring the bcf2000 to factory settings, I've mucked around with it and want to restore?  Thanks in advance
Re: Factory Settings
2010-08-15 by Mark
1. Global settings:
The simplest way is probably to reset these manually on the BCF via "Edit Global Setup".
You can find out what the actual factory settings are from "BC MIDI Implementation.pdf" (section 12.8), available from my website at http://home.kpn.nl/f2hmjvandenberg281/ .
Alternatively, if you have a PC (i.e. Windows), you could do this via BC Manager (available from the same website).
2. Factory presets:
Download http://www.behringerdownload.de/B-Control_download/Factory_Presets_BCF.zip, extract bcf_FACTORY_PRESETS.syx and upload it to the BCF. (Again you can use BC Manager for this, or any other BC editor, or even a generic SysEx uploading program.)
(Actually bcf_FACTORY_PRESETS.syx only contains presets 1-8, so if you upload it to the BCF, any data in presets 9-32 remains unaffected.)
Hope this helps,
Mark.
