In most cases the BC can control most synths with sysex
> Has anyone figured out how to control the Triton with a BCR 2000?
Check the back of the manual for System Exclusive (sysex) info, that is usually where it is located.
>Question: Can a single rotory control represent all the instruments in a bank (128) so that I could assign 14 rotory pots on the BCR for 14 banks on the Triton and be able to read what I selected on the BCR display? i.e. A101, C110, K127 etc?
The BC can output up to 125 bytes of any Midi data per control.
The values it can use are 0 to 16,383 in 2 byte Midi form.
So yes it will output 0 to 128 as a single data byte.
I use one of the encoders to go though all the banks (User 1 & 2 Internal A to I) and presets on my FantomX
I don't have a Triton so I may have misunderstood what you mean by 'banks'.
As far as the display is concerned, no.
The display will only show the values of the Button/Encoder when it is changed.
All the best
Royce
