BCR button settings
BCR button settings
2010-11-06 by deathspanielb
Is there any way to set BCR buttons to be lit by default and blink off while pressed?
Re: BCR button settings
2010-11-07 by Royce
Strangely there is only one way I know that you can have the default as ON. That is, with the LED on
You need to have the switch in Toggle mode (toggleon) and use easypar with the default = any value in the lower half of the min max range
eg minmax 0 100  then default has to be 49 or less
Unfortunately you need to have the switch in Momentary mode (toggleoff). So, as far as I know, having the LED on is not possible.
Perhaps Mark can show me that I am wrong here.
Royce
2010-11-07 by Mark
Nope, I can't, I think you're spot on!
The first table in section 15.9 of "BC MIDI Implementation.pdf" is completely in line with your analysis, once we realize that the LED on the button basically acts in sync with the "on" and "oFF" messages flashing in the display (as described in the table). And this goes for both "standard" (.easypar) and "custom" (.tx) definitions.
So no, I can't see a way either.
Mark.
