BCR2000 with TR-626 as step sequencer
2010-12-02 by Alan
Do any of you boffins out there know if it would be possible to rope the BCR2k into sequencing duties without hooking it up to a computer? I know such software as 'BCR Steps' can do the job but I just had this crazy idea: Now and again I use a Roland TR-626 as a kind of low tech step sequencer. It sends out a separate midi note number for each drum sound and it's patterns can be tweaked, on the fly, in a live context. The only trouble is that the assignment of midi note numbers to drum sounds is a mind-numbingly tedious programming task that cannot be performed live. I wondered what the chances are of getting the BCR to change the note assignment, and therefore alter pitch, whilst a sequence is running. Also could it be given the task of controlling other sequencer related midi events such as gate time, accent/velocity, etc.? Of course I'm just looking at this question with regard to the drum machine I happen to have. Maybe there is a more generic model that can harness the pattern programming and midi clock aspects of any drum machine. When you consider the cost of your average hardware step sequencer this, if it's possible, could be an amazing low cost alternative. Any takers?
