Data Request on BCR2000
2011-02-02 by ajawdokimov
Hi and greetings to all forum members
on page 18 of the bcr/bcf manual is written this
"DATA REQUEST
  Current value settings of the MDI device connected to your B-Control can be transmitted to your B-CONTROL using the data request function (provided that the midi device supports this funtion, and a request command was defined using the editor software) In this case, the midi device doesnt send data: the B-CONTROL requests them instead
         Press the LEARN key while the EDIT key is kept pressed.
         The request takes place, and the B-CONTROL indicates the controller values of the recieving MIDI device on the LED ring or through fader positions"
thats great, but how do I define this, I use BC manager, but cant seem to see where I should do this?
also, I want to put this  as the data request:
Program Edit Buffer Data Dump
Status Description
1111 0000 System Exclusive (SysEx)
0000 0001 DSI ID
0010 0110 Tetra ID
0000 0011 Edit Buffer Data
0vvv vvvv 384 bytes expanded to 446 MIDI bytes in "packed MS bit" format
(see page 66.)
1111 0111 End of Exclusive (EOX)
which, in my limited knowledge confuse me,
how does that go into a .tx command???
ANY clarification here is greatly appreciated !
Kind Regards
Anton
Re: Data Request on BCR2000
2011-02-02 by Mark
> "DATA REQUEST
See:
- BC Manager Manual, section 24 (FAQ) -> "Editing", question 12
- "BC MIDI Implementation.pdf", sections 13.3, 13.7 and 23 (in particular 23.2)
> Status Description
> 0000 0001 DSI ID
> 0010 0110 Tetra ID
> (see page 66.)
A preset's ".tx" statement(s) can define at most something like 125 bytes in total, so what you're suggesting above (451 bytes if I understand you correctly) isn't possible.
Hope this helps,
Mark.
2011-02-03 by ajawdokimov
Hi Mark thanks for you reply,
good to know the limit of bytes on a tx command,:)
--- In bc2000@yahoogroups.com, "Mark" <markwinvdb@...> wrote:
> > "DATA REQUEST
> See:
> > Status Description
> > 0000 0001 DSI ID
> > 0010 0110 Tetra ID
> > (see page 66.)
> Hope this helps,
> Mark.
