[bc2000] Assigning these values to a button
2011-02-18 by Alex
Hi all,
Sorry if the answer is too obvious but I want to assign a button of my BCR2000 to send values based on this table using BC Manager.
Filter
Velocity
Sensitivity --- CC# 110 Values
-8 ------------------ 0
-7
------------------ 12
-6
------------------ 19
-5
------------------ 26
-4
------------------ 33
-3
------------------ 40
-2
------------------ 47
-1
------------------ 54
0 ------------------ 61
+1
------------------ 68
+2
------------------ 75
+3
------------------ 82
+4
------------------ 89
+5
------------------ 96
+6
------------------ 103
+7
------------------ 110
+8
------------------ 117
As you can see every value can be obtained adding 7 to the previous one, except the first jump (0 - 12). If I define a button to increment mode (+7) from 12 to 117, I can get all values but 0. How can I achieve that?
Thank you so much in advance.
Alex
Re: Assigning these values to a button
2011-02-19 by Mark v.d. Berg
> Filter
> Velocity
> -7 ------------------  12
> -6 ------------------  19
> -5 ------------------  26
> -4 ------------------  33
> -3 ------------------  40
> -2 ------------------  47
> -1 ------------------  54
> +1 ------------------  68
> +2 ------------------  75
> +3 ------------------  82
> +4 ------------------  89
> +5 ------------------  96
> +6 ------------------ 103
> +7 ------------------ 110
> +8 ------------------ 117
I don't think this is possible on the BCR itself (unless Royce can come up with something clever...).
But have you checked how the receiving device (a (soft-)synth I presume) responds to OTHER values than the ones in your table?
Can't you create a "modulo 7" sequence that DOES work consistently?
E.g. doesn't a value of 5 trigger "-8" as well?
Hope this helps (a bit),
Mark.
[bc2000] Re: Assigning these values to a button
2011-02-19 by Alex
Thanks Mark! No, I didn't test how other values responds yet. But you are on the right, maybe a value of 5 trigger "-8" so it would be no problem. I will try it.
Thanks!
2011/2/19 Mark v.d. Berg <markwinvdb@...>
> Filter
> Velocity
Mark.
Alex
