--- In bc2000@yahoogroups.com, "Mark v.d. Berg" <markwinvdb@...> wrote:
> --- In bc2000@yahoogroups.com, "diddywahdiddy1" <550@> wrote:
> > reboot with BCR switched on and connected
> > BCM detects 2 devices (!)
> > device 1 is online and using correct firmware
> > device 2 is offline
> Actually BC Manager hasn't really "detected" 2 BCRs:
> It has only tried to restore the BCR "contexts" (cf. the lines in the B-Controls window) that existed when BC Manager closed the last time.
Maybe change the message? It was rather confusing to me. I thought it was actually polling for devices and getting a response.
> "Offline" can result from 2 conditions:
> 1. The previously defined MIDI I/O ports are currently unavailable: their names are between parentheses "(...)" in the B-Controls window.
> 2. The MIDI I/O ports ARE available (hence: not between parentheses), but the previously defined BCR behind these ports could not be found.
> There can be various reasons for this, but in your case it may well be because of a mismatch between the Device ID number on the actual BCR and the Device ID defined in BC Manager.
> So the term "device" (as you were using it) isn't exact enough: we need to distinguish between the BCR and its (USB-based) MIDI I/O ports.
Strangely, the USB devices are both called USB device (USB apparaat) in the B-controls list. But in the midi devices list they are called as below.
> In the situation you describe, BC Manager has detected 2 pairs of MIDI input port + MIDI output port, but not the BCR behind one pair of MIDI I/O ports.
> > 3 both BCR's
> > BCM detects 1 device
> > midi devices shows
> > input: usb device, usb device (2), usb device [2]
> > output: usb device, usb device (2), usb device [2], usb device [3]
> > I check usb device and device (2)
> Ouch! Are "usb device" etc. the actual names?
Like I said : usb apparaat
> Then an important question is: which USB driver are you using?
> And which operating system?
I have a standard XP sp3 OS
> I'm not familiar with all the existing USB drivers, but I suspect you're using a standard Microsoft USB driver.
Yup, I installed Behringer drivers but was advised to deïnstall somewhere on the net.
> One problem with standard Microsoft USB drivers is that they assign numbers DYNAMICALLY to any BCRs you switch on:
> When you switch on one BCR (while Windows is already running), this BCR's USB I/O devices get named "usb device".
> If you then switch on a second BCR, this second BCR's I/O devices get called "usb device (2)". But I think that if you then switch both BCRs off, and then switch on the SECOND BCR, THAT one now gets named "usb device".
Correct
> Another complication with Microsoft drivers is the names they give to the additional USB devices of the BCR's operating modes U-2, U-3 and U-4: these devices get additional numbers between square brackets.
Yesterday I found that, somehow, BC manager or whatever other software changed the U-1 into U-3.... Haven't checked that this morning.
> So if I'm not mistaken, your above lists of I/O devices are to be interpreted as follows:
> The 1st BCR ("BCR1") was in U-3, the 2nd ("BCR2") in U-1.
> Inputs:
> usb device = BCR1 itself
> usb device (2) = BCR2 itself
> usb device [2] = BCR1 MIDI IN socket
> Outputs:
> usb device [2] = BCR1 MIDI OUT A socket
> usb device [3] = BCR1 MIDI OUT B/THRU socket
> This is all extremely confusing.
> (I suppose that if you put BCR2 in U-3, you get names like "usb device (2) [2]" or something?)
I have seen that happening :)
> All in all it is recommendable to install one of the Behringer USB drivers, which produce more informative I/O port names.
> (To varying degrees; some Behringer drivers even use the BCR's Device ID in the port names.)
> What your actual options are, depends on your Windows version.
> See the BC Manager Manual, section 4 point 4, for a list of choices and further discussion.
> With all this in mind, let's go back to BC Manager:
> In BC Manager, each BCR "context" is a fixed combination of a MIDI input port, a MIDI output port and a Device ID. (And a preset file, optionally.)
> So when BC Manager tries to restore a previously defined BCR "context", it uses the previously defined Device ID number for that context.
> So if the BCR that is ACTUALLY behind the selected MIDI I/O ports has a DIFFERENT Device ID, BC Manager (correctly) thinks it's not the BCR it was looking for and reports the missing BCR as "Offline".
> To make BC Manager find a particular BCR, you should make sure that the BCR's Device ID matches the number that BC Manager maintains.
> You can set the Device ID for each BCR context from the B-Controls window via MIDI -> Options.
> You might also experiment with the "Startup detection" setting, which you can change from the main window via Options -> B-Control detection:
> This setting's default is "Verify identity of previously defined B-Controls", which is responsible for the startup behavior you're familiar with.
> "None" might be interesting for testing purposes: you then have to "connect" each BCR manually by executing "Refresh connection status" from the B-Controls window.
> However, "Scan enabled MIDI ports" might be interesting on a more permanent basis:
> It leads to a more relaxed policy, which might be more convenient in your case:
> BC Manager then finds ANY BCR (irrespective of Device ID) at ANY enabled MIDI port, and (if necessary) ADDS this BCR to the list.
> However, any "obsolete" contexts will remain in the list, so you may have to use the "Close selected" operation from the File menu to remove these obsolete contexts.
> Alternatively you can of course set BOTH BCRs to ID 1, but then BC Manager has no way of distinguishing between them, apart from the names of their MIDI I/O ports (which are fluid in your current situation). Of course this can lead to maintenance problems if you wish to install different presets on your BCRs.
> Hope this helps,
> Mark.
Mark, thanks for this extensive reply. I am currently extremely pleased with the fact that my setup is working. So I am a bit wary of disconnecting, rearranging etc. I will check later on what BC manager makes of this situation.
