Uploaded JD-990 presets and .ini
2012-12-06 by i_s_l_a_n_d_b_o_y_6_9
Hi all
Just thought I'd let you know I've uploaded some JD-990 BCR presets and an accompanying .ini file. The ini is incomplete, containing only system common and patch edit addresses. I'll add FX parameters asap, but I've no plans to include performance or rhythm edit. There are also a couple of photoshop files in the folder should you wish to use the overlay I made.
Cheers
Pete
RE: [bc2000] Uploaded JD-990 presets and .ini
2013-01-06 by philip watson
I just wanted to say thankyou for your time and effort in creating this JD990 data. I had abandoned the bcr idea with the jd as i did not know where to start ;)
how do you connect the bcr to the jd? I will use reaper DAW and wondered if i will need to use different modes on the bcr eg. soft synth control and then jd control?
do you run yours direct to jd.
i want this config if poss. reaper usb to bcr then i get midi to jd and control para/edits from your data.
any way, thanks again
phil.
To: bc2000@yahoogroups.com
Date: Thu, 6 Dec 2012 16:45:12 +0000
Subject: [bc2000] Uploaded JD-990 presets and .ini
Hi all
Cheers
Pete
Re: [bc2000] Uploaded JD-990 presets and .ini
2013-01-07 by Pete Gill
Hi Phil
I run the BCR in standalone S3 mode:
DAW midi out > BCR > JD.
I'm not sure whether Reaper handles sysex, but aside from that you shouldn't have a problem controlling the JD using the BCR in USB mode. You may need midi yoke or similar though.
Cheers
Pete
On 6 Jan 2013, at 18:48, philip watson <philipwatson18@...> wrote:
> Hi,
> phil.
> From: peterjonathangill@...
> Hi all
> Cheers
> Pete
