SV: [bc2000] Re: BCR2000+Presonus studio one
2013-04-14 by Fredrik Stennabba
I actually found my problem, but did not remember to post it here...it had nothing to do with the bcr, it was studio one that had a function called "transmit value" and that had to be checked for every button and knob. This was intergrated within the program, so it won't help you with your keyboard...hope you get that sorted out for you!
Skickat från Yahoo! Mail på Android
To: ;
Subject: [bc2000] Re: BCR2000+Presonus studio one
Sent: Sat, Apr 13, 2013 4:55:06 PM
I can give you some help but at the same time I need it myself. I have the same problem with buttons not responding like all buttons would be programed with the same stuff. I wrote and asked Behringer about it and they told me that the problems is in my keyboard because it is sending back the same command as you just pressed so it seems like there is something wrong with the bc2000. You need to use some filter telling it not to. If you find out what filter put in where, please let me know!
--- In bc2000@yahoogroups.com, Fredrik Stennabba wrote:
> Hi all!
> I'm having some problems with my bcr2000 connected to presonus studio one and was hoping to get some answers. I tried posting on the presonus forum but they doesn't seem to exited to answer.
> Here's the deal: I hooked up the bcr and started working with making a new control panel and got down 104 buttons and knobs witch was nice. I started learning different vst parameters to different/same knobs witch also progressed nicely.
> The problem I have is that when switching between vst:s the bcr seems to get stuck on the last parameter. I know it's possible to get it to automaticly know when switching between different functions and set itself correctly. Example: I put an eq on a channel and set it like I want it to be. When I select another channel and put on an eq the bcr is stuck on the last paramaters so when touching a know the vst setting flies to last position used.
> How do I cange the bcr to auto know what the parameter is between functions?
> Also another thing, if I use cubase, I have the bcr set so that I have one knob to set volume for the selected channel and when I select another channel the same knob sets volume for that selected channel. I can't get this function to work with studio one since it seems to bind one knob to the selected channel only. That is, when I bind channel 1 to knob 33, I can't get that knob to control any other channels volume. Anyone know if this is a possible feature in studio one?
>; Any answers on this is much appreciated!
> Greetings from Finland :)
