My K4 is on the 1.0 System Bios.
I just experimented with the gyst of Royce's files and the concept works.
F0 40 00 10 00 04 0E 00 01 F7 - sends value 01 to the Poly Mode.
If you "look" at the LCD ... nothing happens.
But if you cycle around, the display is updated.
Especially as there seem to be no -ve NRPNs to handle.
There is some strangeness with the 1 .. 4 params .. the MinMax get huge.
I havent done the math yet to understand if this would generate either out of range Sysex, or is redundant because of the bit val0.6 masking etc.
Will gradually work thru the list at the weekend.
But to confirm, the basic first 4 work on a K4 sent on MIDI channel 1 via MIDIOX .. dont forget to translate the non $ number to hex!
$button 33 ; Source Mode .minmax 0 2 .tx $F0 $40 $00 $10 $00 $04 13 0 val0.6 $F7
$button 41 ; Poly Mode .minmax 0 3 .tx $F0 $40 $00 $10 $00 $04 14 0 val0.6 $F7
$button 34 ; AM 1-2 .minmax 0 1 .tx $F0 $40 $00 $10 $00 $04 15 0 val0.6 $F7
$button 42 ; AM 3-4 .minmax 0 1 .tx $F0 $40 $00 $10 $00 $04 16 0 val0.6 $F7
$button 52 ; Vib Shape .minmax 0 3 .tx $F0 $40 $00 $10 $00 $04 17 0 val0.6 $F7
$button 48 ; Wheel Assign .minmax 0 2 .tx $F0 $40 $00 $10 $00 $04 19 0 val0.6 $F7
$button 51 ; LFO Shape .minmax 0 3 .tx $F0 $40 $00 $10 $00 $04 28 0 val0.6 $F7
$button 3 ; Wave 1 KS Curve .minmax 0 7 .tx $F0 $40 $00 $10 $00 $04 35 0 val0.6 $F7
$button 11 ; Wave 2 KS Curve .minmax 0 7 .tx $F0 $40 $00 $10 $00 $04 35 2 val0.6 $F7
$button 19 ; Wave 3 KS Curve .minmax 0 7 .tx $F0 $40 $00 $10 $00 $04 35 4 val0.6 $F7
$button 27 ; Wave 4 KS Curve .minmax 0 7 .tx $F0 $40 $00 $10 $00 $04 35 6 val0.6 $F7
$encoder 1 ; Wave 1 Waveform .minmax 0 255 .tx $F0 $40 $00 $10 $00 $04 36 val7.13 val0.6 $F7
$encoder 9 ; Wave 2 Waveform .minmax 256 511 .tx $F0 $40 $00 $10 $00 $04 36 val7.13 val0.6 $F7
$encoder 17 ; Wave 3 Waveform .minmax 512 767 .tx $F0 $40 $00 $10 $00 $04 36 val7.13 val0.6 $F7
$encoder 25 ; Wave 3 Waveform .minmax 768 1023 .tx $F0 $40 $00 $10 $00 $04 36 val7.13 val0.6 $F7
$encoder 2 ; Wave 1 Coarse .minmax 0 48 .tx $F0 $40 $00 $10 $00 $04 37 0 val0.6 $F7
$encoder 10 ; Wave 2 Coarse .minmax 0 48 .tx $F0 $40 $00 $10 $00 $04 37 2 val0.6 $F7
$encoder 18 ; Wave 3 Coarse .minmax 0 48 .tx $F0 $40 $00 $10 $00 $04 37 4 val0.6 $F7
$encoder 26 ; Wave 4 Coarse .minmax 0 48 .tx $F0 $40 $00 $10 $00 $04 37 6 val0.6 $F7
$button 1 ; Wave 1 Key Track .minmax 0 1 .tx $F0 $40 $00 $10 $00 $04 38 0 val0.6 $F7
$button 9 ; Wave 2 Key Track .minmax 0 1 .tx $F0 $40 $00 $10 $00 $04 38 2 val0.6 $F7
$button 17 ; Wave 3 Key Track .minmax 0 1 .tx $F0 $40 $00 $10 $00 $04 38 4 val0.6 $F7
$button 25 ; Wave 4 Key Track .minmax 0 1 .tx $F0 $40 $00 $10 $00 $04 38 6 val0.6 $F7
$button 4 ; Wave 1 Fixed key .minmax 60 72 .tx $F0 $40 $00 $10 $00 $04 39 0 val0.6 $F7
$button 12 ; Wave 2 Fixed key .minmax 60 72 .tx $F0 $40 $00 $10 $00 $04 39 2 val0.6 $F7
$button 20 ; Wave 3 Fixed key .minmax 60 72 .tx $F0 $40 $00 $10 $00 $04 39 4 val0.6 $F7
$button 28 ; Wave 4 Fixed key .minmax 60 72 .tx $F0 $40 $00 $10 $00 $04 39 6 val0.6 $F7
$encoder 3 ; Wave 1 Fine .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 40 0 val0.6 $F7
$encoder 11 ; Wave 2 Fine .tx $F0 $40 $00 $10 $00 $04 40 2 val0.6 $F7
$encoder 19 ; Wave 3 Fine .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 40 4 val0.6 $F7
$encoder 27 ; Wave 4 Fine .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 40 6 val0.6 $F7
$button 5 ; Wave 1 Pres /Freq .minmax 0 1 .tx $F0 $40 $00 $10 $00 $04 41 0 val0.6 $F7
$button 13 ; Wave 2 Pres /Freq .minmax 0 1 .tx $F0 $40 $00 $10 $00 $04 41 2 val0.6 $F7
$button 21 ; Wave 3 Pres /Freq .minmax 0 1 .tx $F0 $40 $00 $10 $00 $04 41 4 val0.6 $F7
$button 29 ; Wave 4 Pres /Freq .minmax 0 1 .tx $F0 $40 $00 $10 $00 $04 41 6 val0.6 $F7
$button 6 ; Wave 1 Vib/A bend .minmax 0 1 .tx $F0 $40 $00 $10 $00 $04 42 0 val0.6 $F7
$button 14 ; Wave 2 Vib/A bend .minmax 0 1 .tx $F0 $40 $00 $10 $00 $04 42 2 val0.6 $F7
$button 22 ; Wave 3 Vib/A bend .minmax 0 1 .tx $F0 $40 $00 $10 $00 $04 42 4 val0.6 $F7
$button 30 ; Wave 4 Vib/A bend .minmax 0 1 .tx $F0 $40 $00 $10 $00 $04 42 6 val0.6 $F7
$button 2 ; Wave 1 Vel Curve .minmax 0 7 .tx $F0 $40 $00 $10 $00 $04 43 0 val0.6 $F7
$button 10 ; Wave 2 Vel Curve .minmax 0 7 .tx $F0 $40 $00 $10 $00 $04 43 2 val0.6 $F7
$button 18 ; Wave 3 Vel Curve .minmax 0 7 .tx $F0 $40 $00 $10 $00 $04 43 4 val0.6 $F7
$button 26 ; Wave 4 Vel Curve .minmax 0 7 .tx $F0 $40 $00 $10 $00 $04 43 6 val0.6 $F7
$encoder 8 ; Wave 1 Level .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 44 0 val0.6 $F7
$encoder 16 ; Wave 2 Level .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 44 2 val0.6 $F7
$encoder 24 ; Wave 3 Level .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 44 4 val0.6 $F7
$encoder 32 ; Wave 4 Level .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 44 6 val0.6 $F7
$encoder 4 ; Wave 1 Attack .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 45 0 val0.6 $F7
$encoder 12 ; Wave 2 Attack .tx $F0 $40 $00 $10 $00 $04 45 2 val0.6 $F7
$encoder 20 ; Wave 3 Attack .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 45 4 val0.6 $F7
$encoder 28 ; Wave 4 Attack .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 45 6 val0.6 $F7
$encoder 5 ; Wave 1 Decay .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 46 0 val0.6 $F7
$encoder 13 ; Wave 2 Decay .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 46 2 val0.6 $F7
$encoder 21 ; Wave 3 Decay .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 46 4 val0.6 $F7
$encoder 29 ; Wave 4 Decay .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 46 6 val0.6 $F7
$encoder 6 ; Wave 1 Sustain .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 47 0 val0.6 $F7
$encoder 14 ; Wave 2 Sustain .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 47 2 val0.6 $F7
$encoder 22 ; Wave 3 Sustain .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 47 4 val0.6 $F7
$encoder 30 ; Wave 4 Sustain .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 47 6 val0.6 $F7
$encoder 7 ; Wave 1 Release .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 48 0 val0.6 $F7
$encoder 15 ; Wave 2 Release .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 48 2 val0.6 $F7
$encoder 23 ; Wave 3 Release .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 48 4 val0.6 $F7
$encoder 31 ; Wave 4 Release .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 48 6 val0.6 $F7
$encoder 33 ; DCF 1 Cutoff .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 55 $00 val $F7
$encoder 37 ; DCF 2 Cutoff .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 55 $04 val $F7
$encoder 34 ; DCF 1 Res .minmax 0 7 .tx $F0 $40 $00 $10 $00 $04 56 $00 val $F7
$encoder 38 ; DCF 2 Res .minmax 0 7 .tx $F0 $40 $00 $10 $00 $04 56 $04 val $F7
$button 49 ; DCF 1 LFO Switch .minmax 0 1 .tx $F0 $40 $00 $10 $00 $04 57 $04 val $F7
$encoder 51 ; DCF 1 Vel Depth .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 58 $00 val $F7
$encoder 55 ; DCF 2 Vel Depth .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 58 $04 val $F7
$encoder 52 ; DCF 1 Press Depth .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 59 $00 val $F7
$encoder 56 ; DCF 2 Press Depth .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 59 $04 val $F7
$encoder 36 ; DCF 1 KS depth .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 60 $00 val $F7
$encoder 40 ; DCF 2 KS depth .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 60 $04 val $F7
$encoder 35 ; DCF 1 Env Depth .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 61 $00 val $F7
$encoder 39 ; DCF 2 Env Depth .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 61 $04 val $F7
$encoder 49 ; DCF 1 Env Vel Depth .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 62 $00 val $F7
$encoder 53 ; DCF 2 Env Vel Depth .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 62 $04 val $F7
$encoder 41 ; DCF 1 Attack .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 63 $00 val $F7
$encoder 45 ; DCF 2 Attack .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 63 $04 val $F7
$encoder 42 ; DCF 1 Decay .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 64 $00 val $F7
$encoder 46 ; DCF 2 Decay .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 64 $04 val $F7
$encoder 43 ; DCF 1 Sustain .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 65 $00 val $F7
$encoder 47 ; DCF 2 Sustain .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 65 $04 val $F7
$encoder 44 ; DCF 1 Release .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 66 $00 val $F7
$encoder 48 ; DCF 2 Release .minmax 0 100 .tx $F0 $40 $00 $10 $00 $04 66 $04 val $F7
